Question about Drills
Bosch psb 400 re electric drill just stopped - Drills
joboo1
  • 257 Answers
SOURCE: BOSH PSB 600 RES drill will not restart
Hi, Sounds like you have a pinched wire somewhere. When you say you somehow make it work are you bending the powercord, shaking the drill or what? Any of those things would suggest a pinched wire or broken switch. Make sure the switches for reverse and hammer work in both directions. You say it is relatively new and there is no smell so I would not suspect the brushes and it doesn,t sound like it is running long enough to overheat anyway. The best advice I can give you is that the drill needs to be opened and examined, and if you have an ohm meter check all of the connections from the power cord to the trigger. If you don't feel comfortable with that then you may want to return it under your warranty or you may want to do that anyway. Good Luck!
Posted on Feb 05, 2009
  • 4 Answers
SOURCE: I can't change the bit on my Bosch PSB 650 RE drill
see if there's not secured to the shaft with a screw inside at the bottom of the bit. try to slack it by turnig it clockwise. then catch a 19 mm. open end spanner in a bench wise put the shaft with its two flat sides in the spanner and with a pump pliers catch the bit and unscrew the bit turning counterclockwise this time
Posted on Oct 06, 2009
  • 10865 Answers
SOURCE: A bit is stuck in the chuck of my Bosch drill
Hello. Wrap a towel around the chuck and use a pipe wrench or a pair of channel locks to put a little force on the chuck. J.
Posted on Jul 19, 2010
SOURCE: How do you replace the chuck on a Bosch 650 RE
while holding the drill like a gun, hold the lock button REALLY tight and pull the black part to the right really hard. this will unlock the chuck and if you keep twisting the black part to the right it will loosen it enough so that you can remove it
Posted on Jul 25, 2010
muntejaya
  • 10421 Answers
SOURCE: I bought a Bosch PSB
Please check your carbon brushes and replace them if necessary
Posted on Jan 11, 2011
How do I replace the motor on a Bosch PSB 24v 2E Drill?
the motor is coverred with rust and when you tried it,you fried it,go to ebay and buy a used one
Apr 27, 2015 | Bosch Drills
How do you remove the keyless chuck on a Bosch PSB600 RES drill?
Here's a link to an exploded view:
Bosch PSB 600 2 0603338003 Spare Parts
If you need more help - you should contact Bosch directly:
Contact Bosch
Apr 14, 2015 | Bosch Drills
What grease is used in a Bosch Hammer drill PSB 400-2?
Contact Bosch at 1-800-241-3848. Parts and a breakdown can be found at toolpartsdirect.com also.
Jan 03, 2013 | Drills
My Bosch 24v PSB 24 VE-2 has suddenly stopped working. The battery charges ok but when fitted into the drill , the drill makes a faint whining noise but fails to work. Any ideas ?
Hello
The motor windings in the drill are bad or have a bad connection.You may also try cleaning the battery contact points with a pencil eraser.
Jun 25, 2011 | Bosch Drills
Jan 03, 2010 | Bosch Drills
Drill keeps on stopping and won't restart
Check the cord...sometimes if the brushes are not seated well or if there is a cut in the cord you will run into that problem....If it is not that then possibly you just have a faulty drill
Jan 04, 2009 | Drills
Drills Logo
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
