Question about Intex Pool & Spa
Back flushing - Intex Pool & Spa
  • 62 Answers
SOURCE: Sani-Plus
float switch of level control is defective. replace same with new part
Posted on Jun 12, 2009
Malcg
  • 32 Answers
SOURCE: Kohler Toilet year old do not have flapper. It has stright pipe
This is how it is meant to work!
Short push of lever for small flush, push and hold lever for full flush.
Posted on Aug 16, 2009
  • 62 Answers
SOURCE: basement toilet won't flush. water fills the bowl
Check your flapper line to the flush handle. The flapper is in the tank on bottom. There shoiuld be a plastic line to handle or chain. :)
Posted on Sep 07, 2009
  • 119 Answers
SOURCE: The toilet continues to run after flushing, i.e.e
The fill valve is stuck on and needs replacement, checking this part every year is a good idea.
Posted on Mar 28, 2010
SOURCE: Fluids splash out when flushed
I went through this and called the help line. If the bowl is almost empty after flushing, it may be the water fill line in the fill tank (reservoir on the back of the toilet). There is a small tube that should go into the overflow tube and it adds water to the bowl after flushing. Mine was not attached to the overflow tube when I took it out of the box and the instructions did not mention to check it (or the troubleshooting guide). A picture is worth a thousand words so look for the small white hose going from the fill valve into the overflow tube:_1365.jpg
Posted on May 28, 2011
I have a 1999 Ford Taurus that would not heat, took to shop they flushed the system, replaced the water pump and it ran hot after thet flushed the system took it back they flushed the system again and
Did you have red antifreeze prior to the flushing? Ford engines are generally aluminium and should be using blue antifreeze which is suitable for aluminium engine blocks! I think the antifreeze is reacting to the aluminium.....re flush and use blue!
Dec 29, 2014 | 1999 Ford Taurus
Pool will not back flush,low pressure
did you remove old sand did you get sand down standpipe
Jun 02, 2013 | Hayward Pool & Spa
Toto neorest 500 take two flushes to work properly
Water pressure may not be strong enough or the tank is not filling up well in the back.does it have trouble on just flushing urine.
Jan 13, 2013 | Toto - Toilet - One-piece - Neorest 500 -...
Shifting at 3000 rpm 3 days after fluid and filter change
please do not tell me you had it flushed at a fast lube place,and they back flushed it. back flushing is ok with old transmission,but with the new transmission back flushing cuases the shift sensors in the transmission to close and not open
Nov 08, 2012 | 2002 Honda Passport
When I flush the tank only half empties and not enough flushing action is the result as well as the bowl does not adequately fill after the flush.
Hi, if you remove the cistern lid and flush the toilet, look at the float (back left) to see if this is rising freely when the water fills back up. Once the water has stopped filling, check the fill level lines on the large syphon in the middle of cistern. Your model of toilet has an eco flush which will be lowest line to save water, so not as much water will flush out. There is a long plastic screw on the float (back left) which you can turn to adjust the water level to the higher line on syphon (1.6 gallon flush) and turn it slowley till the water level reaches that mark. flush a couple of times to see it is filling back up to the set amount.
Jan 14, 2011 | Kohler Cimarron 2-PC Elongated Toilet with...
My truck wont blow out any hot air, just cold. i put a new radiator and thermostat in it. it is full of anti freeze
Try removing the Heater hoses from heater tubes(be careful not to break heater tubes off) then back flush heater core with garden hose(Don't use a lot of pressure). Jell from antifreeze builds up in the heater core and blocks the coolant flow. If it is easier, remove the heater hoses from the engine, that is safer. Back flush the heater from the hoses. To Back Flush (The hose coming from the water pump is the inlet)(Hose going to Manifold is outlet) Back flush outlet hose! To much water pressure may cause damage to heater core!!!! Do Not ues AIR!!!!
Sep 28, 2010 | 2001 Chevrolet S-10
Flush button won't work. 12 yr old Duravit Toilet
The push button siphon assembly is worn out. Just replace it entirely.
May 26, 2010 | Home
What to do if your nissan diesel pickup is fueled with gasoline
Drain and flush with diesel, disconnect fuel supply near injection pump, flush, hook back up, open supply, near each injector, flush, tighten back up, and vehicl shoule eventually start.
Oct 11, 2009 | 1997 Nissan Pickup
No back flush pressure
increase the tank water level half inch at a time till you have the back flush pressure.
seems like the water in the bowl is too low to create any wirlpool.
Oct 30, 2008 | Eljer Aqua-Saver 12" Two-Piece...
How do you back flush the cooling on a 2001 osmobile sillouette mini van
Use the heater hose to back flush the cooling system, they make an adapter kit for what you are doing, it's very inexpensive, it goes in the supply line to the heater core, that is the larger of the 2 hoses.
Oct 19, 2008 | 2001 Oldsmobile Silhouette
Pool & Spa Logo
11 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
