Question about Dishwashers
Kelvinator dishwasher will not dissolve the detergent blockOn the economy or the rapid options
  • 25 Answers
SOURCE: Bosch Exxcel Auto Option/Detergent tablet does not dissolve?
It seem that your DW drain it's water by syphon action. Check if the drain hose is properly installed as a U shape; otherwise the DW can drain itself at any time, leaving the soap undissolved .
Posted on Nov 16, 2007
rylee_smith
  • 8619 Answers
SOURCE: Neff S5433 Dishwasher - Detergent tablet not dissolving
Hi!
Please run the machine without detergent for 2-3 washes. Also try using a little hot water. Also, don't used cleaner and softener together but add softener on the last rinse.
Posted on Feb 22, 2009
  • 423 Answers
SOURCE: Dishwasher detergent won't dissolve
Recommend you stop using the gel and switch to a brand name powder - like Electrosol or Cascade. Never use gel, gel packs or tablets in any dishwasher. Avoid untra-cheap, generic powders.
If problems continue, a service call, with them checking that the heating element is working is the follow up step.
Good Luck!
Posted on Apr 04, 2009
VtToolMan
  • 704 Answers
SOURCE: Dishwasher 3 in 1 detergent tablet not dissolving.
I believe that the instructions for using these 3-in-1 tablets is to place it in the open dish detergent cup, rather than in the closable compartment, since the tablet needs to get doused by a lot of water in oder to fully dissolve and be effective in getting the dishes clean.
Since the tablets are designed to dissolve more slowly, they are able to be used for the entire range of washing cycles. If it's a constant problem and you don's have an open detergent cup below or next to your closed detergent dispenser, just toss it into the bottom of the dishwasher instead.
The reason that the tablet isn't getting dissolved fully is because the door is preventing the tablet from dropping all the way out and the door is shielding the tablet from quite a bit of water spray.
Another option is to take a look at your owners manual for the dishwasher and see if they recommend these all-in-one tablets versus regular powered detergent and liquid rinse aid.
Hope that helps and best regards!
Posted on Jul 31, 2009
SOURCE: Tablets not dissolving
either there is not enough water (check water valve) or the pump filters are clogged (check and clean as necessary)
Posted on Sep 11, 2010
The door that holds the detergent does not open, so the detergent pods do not dissolve
A last option is to throw in the detergent pod manually. I have done this in the past and works well. Cant hurt to try.
Feb 22, 2016 | Dishwashers
Finish dishwashing product does not dissolve
Many dishwashing detergents need a water temperature of 140 degrees to dissolve. If your water is at the correct temperature, the only other suggestion I have is to make sure the detergent dispense is not blocked by large objects such as baking sheets, frying pans etc. If the dispenser cannot open fully, the detergent won't dissolve.
I hope one of these suggestions helps you. If it does, please rate my effectiveness. Thanks.
Jun 02, 2011 | Dishwashers
Soap not dissolving in dishwasher. stays in compartment
Hi, dishwasher detergent stays in the compartment because Bosch has designed a gap at the top of the compartment that feeds water onto the detergent before the cover opens. This has possibly been done to soften up deteregent tablets and help them dissolve.
The result is a solidified mass of wet detergent that doesn't come out of the compartment when it opens, and slowly dissolves onto the dishes leaving them coated with alkaline detergent at the end of the cycle. The residual lump of detergent is in the compartment or on the bottom of the dishwasher (refer photo).
The solution is to remove the compartment cover and look for the small gap at the top of the compartment as in the photos. Clean the surface and fill the gap with epoxy glue. This will keep the detergent dry until the cover opens, allowing the detergent to fall freely out of the compartment._1583.jpg
Jun 23, 2010 | Dishwashers
Detergent tablet not dissolving.
sometimes the dispenser doors are not designed for tablets, and they don't let enough water in to dissolve them....next time you wash; put the tablet in one of the silverware compartments....should do the trick. and leave the dispenser door for liquid detergents only.
if this is helpful please click the correct button. thanks
Jan 22, 2010 | Zanussi Dishwashers
Automatic dishwashing detergent granules do not dissolve
Did you switch brands of detergent?
You mentioned that the diswasher is old can you check the nozels of the wands to see any of them are plugged near the ends this will affect wheather the water is reaching the door.
Hope this helps
Al
Sep 11, 2009 | KitchenAid Dishwashers
Jul 31, 2009 | Electrolux Dishwashers
Hotpoint dwt 10 dishwasher - the dishwasher tablet is not dissolving and remains in the bottom of the dishwasher after running a load therefore dishes arent cleaned!
I know it sounds strange, but many times when detergent dissolve, a failed heating element is to blame. The detergent needs that water to be hot to dissolve and activate the detergent.
Recommend you check the heating element for obvious damage/failure. When you run the full cycle, does the heating element get hot? If not, replacing it is not as hard as it appears. Post back here with further questions, OK?
If the heating element _is_ working, the other possibility is a failing wash pump motor, but depending on the age of your dishwasher, replacing
May 03, 2009 | Dishwashers
The soap fails to disolve!
Having the dishwasher powder failing to dissolve is a far more common problem recently with the filing economy.  People are trying to save money by buying generic dishwasher powder rather than brand name products.  The ultra-cheap products fail to dissolve because their ingredients include bulk fillers with minerals, etc.
It is possible that the dispenser is failing to open, but that is a generally rare problem except on very, very old dishwashers. Before deciding the dishwasher has failed, go buy a box of brand name (Electrosol or Cascade) dishwasher detergent powder and only use it.
Please report back your results here, OK?  Good Luck!
Apr 17, 2009 | Whirlpool 24 in. ADG7540 Built-in...
Hi!
Feb 22, 2009 | Neff 24 in. S5456 Built-in Dishwasher
Dishwashers Logo
12 people viewed this question
Top Dishwashers Experts
