Where can i get a wiring diagram for 57915.331 duo therm camper ac
SOURCE: thermostat wiring for second ac unit
I replaced one unite with another and the wires are differance colors the old unites wires are red,purple,yellow,bleck and white the new one have orange,brown,cream,darkpurple,and white
Posted on Aug 02, 2008
motor1258
  • 6674 Answers
SOURCE: duo therm air conditionning/furnace thermostat in RV
Checked all breakers & fuses in panel ?
Posted on Aug 14, 2008
dealt_soul
  • 296 Answers
SOURCE: how many amps does ac draw?
Im taking this is a RV Heater and Air.
Amps 14.7 cooling (at 95 degrees ambient), 12.7 Heating w/optional heat strip
Posted on Jan 20, 2009
SOURCE: rv air conditioner leaking
I have the same problem....it is a negative pressure problem holding water inside the unit until it overflows the pan and runs into the duct system. why this occurs....I don't know....I cant find a problem with my air return, but as soon as you turn in off, the water comes gushing out the drains on the unit. I resolved this....temporarily....by twisting up a paper towel into a wick, and placing one end up into the drain tray, with the other end lying well out into the exterior case. This lets the water wick out and keeps the tray drained. I don't understand the problem and don't know what the permanent fix will be, except maybe cutting a hole and placing an intake vent directly below the unit.
Posted on May 11, 2009
  • 127 Answers
SOURCE: a duo therm thermostat (p/n 3105058) was removed
a. Remove the cover of the thermostat.
b. Connect the RED wire from the air conditioner
to the “RC” terminal on the thermostat.
c. Connect the “YELLOW” wire from the air conditioner
to the “Y” terminal on the thermostat.
d. Connect the “BLUE” wire from the air conditioner
to the “H” terminal on the thermostat.
e. Connect the “ORANGE” wire from the air conditioner
to the “G” terminal on the thermostat.
f. Push the thermostat wires into hole in wall and
fill excess hole with insulation.
g. Mount thermostat base to the wall with screws
provided.
h. Check all thermostat wires on base to ensure
they are completely clear of the bimetal coil of
the thermostat. Adjust if necessary.
i. Replace thermostat cover.
If nothing operates on the air conditioner, remove the
return air grille assembly and verify the red, orange, yellow
and blue wires are properly connected (red-to-red,
orange-to-orange, etc.).
Next, disconnect the red wires and check for 12 volt
DC between the red wire from roof section and the orange
or blue wire from roof section. If no voltage received,
refer to Section F2. If voltage is received, the
problem lies with the thermostat or thermostat wires.
Next, disconnect all 4 wires (red, orange, yellow and
blue) from the thermostat. With the thermostat set on
COOL mode, FAN mode set on AUTO and HIGH, and
temperature selector set lower than the room temperature. Check for continuity between terminal RC (red wire)
and terminal G (orange wire); and RC (red wire) and
terminal H (blue wire). If continuity is achieved on each,
proceed with the next step.
Set fan switch to LOW. Continuity should NOT be present
between terminal RC and Terminal H, but present between
the other terminals (Y & G) and terminal RC.
If all of the previous checks are good, the thermostat is
good, do not replace it. If any one of the previous checks
are not correct, replace the thermostat.
Posted on Jun 29, 2009
Need a wiring diagram for duo therm thermostat in a 1994 Kountry Star motorhome
didnt specify model number of stat --can notify domestic they make the duo therm products
dometic com
Aug 31, 2016 | Heating & Cooling
I have a jayco pop up camper with a Duo-Therm BriskAir roof top a/c. im having problem with it leaking water inside of the camper? Is there a drain hose? Or wat do u think is wrong?Thanks
Yes there are drain holes in base of upper unit (on roof), which may be plugged. Couple of questions though to see if we can better troubleshoot this for you.
-Do you remember seeing water (condensation) running off roof before when AC was used?
-Have you cleaned filter inside at ceiling lately?
May 17, 2011 | Dometic Rooftop RV Air Conditioner
Duo Therm dripping water in camper when shut off. My Dometic Duo Therm Ducted AC drips quite a bit of water when shut off after running for several hours on hot humid days. The condensate lines are open....
Remove the filter at ceiling and run the AC on cool etc, and see if you can feel cool air leaking across to return air inlet where the divider between cold and return is. Check along all edges, etc for any cool air . Careful of wiring, but you should be able to get hand in there and feel especially around the edges where it should be sealed tight. Quite often a leak in that area causes cold air to enter return air and causes excessive condensation. Another thing to check is look way up inside opening for return air, with a flashlight and see if any dirt/dust on coils and fins of evaporator, and if so, needs to be cleaned off with a vacuum, and brush attachment. Let me know what you find.
Jul 10, 2010 | Dometic Rooftop RV Air Conditioner
Have a duo therm ac and the low ac and low fan not work -
Thermostat on wall, or manual controls at AC? Did it work for you on low before now? Reason I ask, is that normally they are only a 2 speed fan ( low and high) so if it's a wall thermostat and has been changed from original, perhaps it the way the thermostat is wired.
Jul 05, 2010 | Dometic Rooftop RV Air Conditioner
Replacement Fan Motor
Try Johnstonesupply.com. Use the information you provided above.
May 06, 2010 | Dometic Rooftop RV Air Conditioner
A duo therm thermostat (p/n 3105058) was removed because it would not operate the air conditioner/heater in a firan fireside camper. it was knocked loose from the wall damaging it.the thermostat is for use...
provided.
Jun 15, 2009 | Dometic Rooftop RV Air Conditioner
Compressor will not stay on
do you know if the fans are running constantly? and if so when the compressor comes on it trips out and the fan remains constant? i would like to know the running amps are they correct.
Jun 08, 2009 | Heating & Cooling
Heating & Cooling Logo
21 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
