Question about Mitsubishi 2012 Outlander Sport SE AWC
2012 mitsubishi outlander
Fault code p1773 and u0121. how to repair it?
    Scholar:
    New Friend:
  • 94 Answers
P1773 -
Type Powertrain - Manufacturer Controlled DTC - Manufacturer Controlled Description AT - lock-up clutch not engaging
Cause Wiring, clutch pressure control solenoid B, ECM
or you can ask the 24 hrs live technical support http://www.spobd2.com/, they will like to help you, good luck
Posted on Sep 13, 2013
2011 Mitsubishi Outlander XLS V6, with light on of SERVICING ENGINE SOON CODE P0305.
code p 0305 is misfire on no 5 cylinder ===causes , injector , fuel pressure , injector wire--ecm---mechanical fault
Sep 15, 2017 | Mitsubishi Cars & Trucks
I have mitsubishi outlander giving error code P17777 and its driving only on first gear Mitsubishi Outlander 2.4 4x4 Model year 2008
i checked into your problem and it seems to be that the problem is in the transmission and the controllers are going against each other and shorting out so the best thing to do is to see a transmission shop for repairs
Dec 16, 2016 | Mitsubishi Cars & Trucks
How can blower motor be replaced?
2008 Mitsubishi Lancer HVAC Blower Motor Install How To ...
? 9:07
https://www.youtube.com/watch?v=PKZ2oIFHIdc
Apr 18, 2012 - Uploaded by LVzx2
All you will need is 15 minutes max, a short phillips head ... 2008 Mitsubishi Lancer HVAC Blower Motor Install How To .... If so , sounds its obviously not a direct replacement and or not for your car which could be the problem.
2008 Mitsubishi Outlander XLS Blower Issue? - YouTube
? 0:35
https://www.youtube.com/watch?v=rK81xZtc5Jk
Nov 14, 2012 - Uploaded by Jeff Mack
Intermittent noise that will occur during colder weather. ... 2008 Mitsubishi Lancer HVAC Blower Motor Install How To - Duration: 9:07. by LVzx2 21,758 views ... How To Replace 2003, 2004, 2005 & 2006 Mitsubishi Outlander ...
Dec 30, 2015 | Mitsubishi Outlander 08 2008
2012 Mitsubishi outlander sport does not start in cold weather
Your imobilizer activates when its cold this should be recalled its a black box3x3 behind a panel in your glove box mitsubishi knows about this
Jan 24, 2014 | Mitsubishi Outlander Sport Cars & Trucks
P0488 fault code on a 2008 outlander
just had this on my 2007 2.0 did outlander, replaced the egr throttle body which cleared fault code p0487 which i also had, but p0488 was a little more tricky to find out what it was, after searching the internet i checked the fuses, sure enough a 15a fuse had blown, about 6th from the right as you look at the fuse box with an engine symbol identifyng it. changed the fuse cleared the fault code job done, it seems a broken egr throttle body will blow this fuse according to my research. hope this helps someone.
Jul 10, 2012 | Mitsubishi Cars & Trucks
P1773 engine code
P1773 is a late addition to 09 Lancers CVT system.
The code is a ghost code; it does not specifically indicate a problem, it indicates evidence of a problem. When this code comes on, it is to signify that the CVT computer has detected an abnormality in the ABS computer, but
you will need a scan tool to test the sensor wires properly; and as of right now, Mitsubishi dealers are the only places with full ABS access on 08+ Lancers.
Feb 15, 2011 | Mitsubishi Outlander Cars & Trucks
How do i reset my check engine light in my2006 mitsubishi outlander.
When the check engine light comes on, on about any vehicle it is a trouble code you can take it to autozone, napa or some similar autosupply house and they can read the code and tall you what the problem is or you can take it to a mechanic of your choice and they can do it there, if they reset and there is a problem that isn't repaired the light will go off for a short period then come back on again. I had this problem with one of my vehicles and the check engine light would not go off until I had the problem repaired which was the cooling system failure telling the vehicle that it was running hot when it wasn't causing it to shut down.
I hope this help you.
Please don't forget to rate/vote on my advice or place a testimonial..
Wicked Angel
Dec 06, 2010 | 2005 Mitsubishi Outlander
Mitsubishi 2012 Outlander Sport SE AWC Logo
269 people viewed this question
Top Mitsubishi Computers & Internet Experts
Shaukat Bhutto
Level 1 Expert
Alun Cox
Are you a Mitsubishi Computer and Internet Expert? Answer questions, earn points and help others
