Question about GE WSXH208A Front Load Washer
My washing machine
Hello, I wonder if you would be able to help me, i have a Creda washing machine. Everytime i do my washing throughout the cycle a springy noise is made, when the durm rotates. kind Regards, Bayly
  • 641 Answers
Open washer's rear panel and look for a released or a malfunction shock absorber Good luck!
Posted on Aug 27, 2007
Creda Simplicity 1000 (w100fw) - Drum does not rotate
you could try fitting new motor brush kit it wears down after 4/5 years and need replaced....please leave feedback
Apr 08, 2010 | Creda W100FW Front Load Washer
Manual for westinghouse lt959s
Hi, our lt959 is tripping the power mid cycle. just wondering if any one can help...
Dec 18, 2009 | Creda Washing Machines
Hi.My washing machine will not rinse or spin the clothes and am wondering wether it could be the double cellanoid valve as this has been mentioned in chatrooms and forums?
Even if the valve were faulty, it would not stop the washer from spinning.
You can double check this, by selecting spin only, if it does not spin then
I would recommend that you locate and clean the filter, and also check the carbon brushes in the motor, as both these factors have a bearing on it performing correctly.
Please leave any comments you may have regarding my suggested solution.
Thankyou.
Nov 24, 2009 | Creda W100FW Front Load Washer
Creda W100FW Front Load Washer. access to service drain plug?
Hi.
Remove lower rear cover of washer, locate pump, and remove large hose attached to it, remove and clean filter inside hose, check pump for possible blockage.
Please rate my solution.
Thanks.
Apr 19, 2009 | Creda W100FW Front Load Washer
Washing machine tripping elec's
Sounds very much like the program PCB (printed circuit board) needs replacing.
A job for a qualified engineer I'm afraid.
Sorry.
Feb 27, 2009 | Creda W120VW Front Load Washer
Creda 1000 Superspeed, stacked: Motor does not run
Sounds like you have motor problem, I suggest u check the brushes in the motor, most likely cause of problem.
Also check that the belt is still on the motor.
Dec 03, 2008 | Creda W100FW Front Load Washer
Washing machine fuse blows every couple of washes
the machine is pulling to much power.check to see if it is on a 15 or 20 amp outlet. you said you replaced the fuse. the amp size should be on it. if it is a 15 amp fuse,plug the machine into a 20 amp circuit and see if the fuse blows then. it shouldn't since it wasn't blowing everytime on the 15 amp circuit, but never put a 20 amp fuse in a 15 amp socket! the fuse can handle the load[ no pun intended], but the electrical wire would burn not blowing the fuse, thus causing a fire.
hope this helps.
wg
Feb 17, 2008 | Creda W100FW Front Load Washer
Creda eco washing machine won't spin
it is the carbon brushes in the motor. there cheap and easy to replace. go on give it a go
Dec 11, 2007 | Creda W100FW Front Load Washer
Freezer before Rinse
you hav'nt said if it drains. the problem just may be that you have plumbed drain hose onto a spigot on the sink drain and spigot is blanked off
Apr 24, 2007 | Creda W120VW Front Load Washer
GE WSXH208A Front Load Washer Logo
41 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Sal De
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
