My kul model ku32085 is not draining water
Not drainig water
2 Suggested Answers
SOURCE: kul ku32085 manual needed
found!
http://ftp.cargilusa.com/pictures/usermanual/KU32085%20%2803%29.pdf
Posted on Jul 08, 2011
Water keeps drainig
Follow this link to Washing Machine Repair manuals:
http://www.appliancerepair.net/washing-machines-forward.html
It's saved me a bunch of $$$'s on washing machine repair
Feb 16, 2013 | Roper Washing Machines
Water not drainig away
Check the voltage on the drain pump/valve when the program comes to the drain cycle. if present then the pump/valve must work to drain off the water. If so remove the pump , back-flush and clean. If faulty you must replace.
if voltage is not present then the program controller unit is faulty and needs a check as there is no output to work the pump/valve.
Apr 09, 2011 | Dishwashers
The water is not coming out of the clothes
Hiya,
2 simple checks for you with this problem often when there is excess water left in your cloths after a wash its due to a reduction in the outlet (waist) so i would surgest checking the waist pipe & drainige connections for excess lint as this can reduce the amount of water getting out & leaving it in your cloths or machine.
Hope this helps
Apr 23, 2010 | Kenmore HE2 Plus Front Load Washer
My washer has a little water left in the bottom of the drum and the washer has a smell of mildew. The pump is pumping great but isn't finishing the job. What would be the problem?
Hiya,
sometimes you can get a buildup of lint in the drainige system try checking the waist pipe & drainige pipes if you have a build up of lent in them or if the waist pipe is pushed to far down a drainige this can reduce the amount of water escaping & leave it in your machine or cloths the smell would be a sign of old water so those would be my surgestions to try & soilve this problem.
Hope this helps
Apr 23, 2010 | Washing Machines
My washing machine is not finishing a cycle and is not pumping out the water. It will start a cycle, but then it will stop half way through, and the "delay/start" button will flash red. Please help
i had same issue turned out pipe was blocked and washing machine gave up trying to get rid of water, so would stop, cleaned filter, uncloged drainig pipe and was good to go
May 12, 2009 | Hoover Nextra HNF 3157 Front Load Washer
Hotpoint - Drainig Issue
if you have a garberater you need to remove the drain pipe and clean out
Feb 19, 2009 | Hotpoint 24 in. FDW60 Free-standing...
My Hoover Nexta washing machine is not drainig water
First empty machine by lowering waste pipe into a large bowl or bucket. Then remove kick plate from bottom front & you will see the filter. this will have a small screw which needs to be loosened then unscrew filter and check for coins etc.If this does not fix come back for other options.
Nov 20, 2008 | Hoover Washing Machines
Ruud central air system
Install a condensate pump if you don't have one. Check to make sure it works if you have one and clean it out.
Jun 08, 2008 | Ruud Central System Air Conditioner
Miele 24" incognito
if it is draining and not drainig all the water out I think you can increase your drain time.Also check to see if drain hose has fallen make sure it is tied to under counter top.
Nov 21, 2007 | Miele 24 in. G646SC Plus Free-Standing...
HELP!!!!!!
Before spinning, washer draining water aut & than start spinning,,,,if motor runing without drainig water, chek the belt, if belt is OK,and runing pupm, chek the pump,,,,disconnect hoses and clean pump... if washer do not draining & spinning, replase lid switch..... If you need instruction how to replace lid switch, i will post you instruktion....
Sep 01, 2007 | Maytag Performa PAV2200
Heating & Cooling Logo
42 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
