Question about Maytag Refrigerators
MBR1953XES1 water leaking and freezer light bulb works intermittenly
3 Suggested Answers
  • 454 Answers
SOURCE: Hotpoint. Water is leaking from behind light bulb
The drain hose in the back of your freezer is frozen shut. The water you see is coming from the defrost cycle. Turn off the refrigerator. Remove the floor from your freezer and remove/thaw all of the ice. Locate the drain in the back of the freezer. It may be behind the back panel. Thaw the drain until water flows freely through it. Reassemble the freezer, and you are back in business.
Posted on Oct 23, 2009
Testimonial: "When back and bottom of the freezer were off there was ice everywhere. The drain plug was frozen. Thanks for the advice."
heatman101
  • 43501 Answers
SOURCE: My Frigidaire fridge model #
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on May 22, 2011
Jeep patriot leaks water intermittenly
This could be what is referred to as a cold leak. That is a leak that only is present when the temp. drops, and the metal pipe shrinks. Also it could be the a/c leaking water. Is there coolant on the ground under the vehicle or is just water?
May 25, 2014 | 2008 Jeep Patriot
Water leaks inside food compartment
Your fan has stopped working. You need to either replace it or see if your defrost timer is working.
Jan 07, 2014 | Frigidaire FRT15B3A Top Freezer...
Freezer light bottom not working,bulb good
Warranty time, call maytag, most fridge come with 1 year warranty.
Oct 27, 2013 | Maytag Ice2O MFX2571XE 25 cu. ft. French...
Water leaking from ceiling behind light bulb near water filter in Frigidaire side by side FRS26LF8CS1
On your model the freezer is over the fresh food section and defrost coms about every eight hours. If by chance your condensate drain from freezer above becomes blocked behind that light shield the water from defrost will collect in a cup behind that shield and flow down into the fresh food section. Click Here=> Leaking Refrigerators and once done there click here=> Leaking Refrigerators, Just What May Be Happening If you have any questions about your Refrigerator I will be here or reachable here, Thanks and please rate if helpful, Sea Breeze
Oct 18, 2011 | Hotpoint HTS16HBR Top Freezer Refrigerator
Oct 22, 2009 | Hotpoint FFA60 Bottom Freezer Refrigerator
Water leaks on floor intermittenly from under middle
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine. or your plastic tubing carrying water to the door assy may have a crack (dry rot)
Nov 16, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Amana Side-by-Side refrigerator hot spot
hi tanks for the question there are heaters at the spots you said were hot and those heaters are there to prevent moist air from hitting cold surface and create warer droplets from forming on those surfaces i would remove the back of the fridge and vacuum it out that should solve your problem thanks the appliance doc
Sep 18, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Freezer leaking
Hi Cliff Claven,
Happy to help.
I would advise you on this occasion to call service.
These guys are good!
A&E factory service does most brands warranty services.
They are open 7days/24hours nation wide.
call tonight! 1-800-905-9505
I am happy to assist you!
Neil
PS. Before you leave this site please leave a "Problem Solved" rating for me on fixya.com
Jul 21, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Kenmore refrigerator leak
I have an Amana refirgerator with a top freezer and had the same problem. I turned off BOTH the frig and the freezer for 24 hours. That allowed every thing to dry out. It has been running now for a week with no problem.
Jun 26, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Water running down door & dispenser light always on......
If you trace up from the water leak it must have an origin. If it starts high level I would suspect the door not sealing allowing warm air to be chilled down cold enough to condense. If it starts around the water or ice dispenser you may have a bed connection or break in the supply lines. I am assuming this is on the freezer section. It would also account for the light as there are normally door switches for the light and fan. If you open the door on the freezer section and push on the switches you should see the light go on and off. Hope this helps, water leaks are always a pain even for engineers.
Aug 17, 2007 | Whirlpool S20DRSS33 Side by Side...
Refrigerators Logo
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
