Question about Music
Esquema eletrico behringer ep4000 - Music
Esquema eletrico behringer nu3000
I have a nu3000 that was linked in the wrong strength is 110volts
linked in 220volts burned the two fet source (transistor) T1 and T5 can someone tell me an equivalent for putting in place
Jun 13, 2013 | Music
I have a pair of Behringer B1800x-pro subs that I am hoping to power with my EP4000. Would it be best to run one per channel or would it be better to run them in series with the amp bridged?
Run one per channel... DO NOT forget to use an electronic crossover feeding the amps as the speakers are rated only up to 300HZ so you need a low pass feeding these or you may burn them up. Some people are using the DriveRack crossover module for example to prevent sending highs to the subs and smoking them.
Sep 21, 2011 | Behringer EUROPOWER EP4000 4,000-Watt...
Want to run 2 subs of 1 amp ep 4,000 in bridge mode.
You can do that but your subs will have to be monsters or you will blow them out as bridged mode will drive 2400 watts RMS into 4 ohms. Many speakers are rated in peak or program power... these are FAKE specifications. with this amp in bridged mode each of two identical speakers would have to be rated at 2400 watts program or about 3600 watts peak each to survive... When rating speakers and amps ALWAYS compare RMS values... and for safety use an amp of 80% of the RMS rating of the connected speaker or speaker system.
Aug 28, 2011 | Behringer EUROPOWER EP4000 4,000-Watt...
I need the diagram of behringer europower pmh1000
Here:
http://elektrotanya.com/behringer_pmh1000.pdf/download.html
Scroll down to "get manual" and click on it to download. Ignore other download links for viewers on the page.
Jul 12, 2011 | Behringer Europower Pmp1000 Powered Mixer...
I need a circuit board for a EP4000...
If the board has not been burned up, one should troubleshhot the bad components.
If you need to replace it call Behringer at 1-425-672-0816. Have the board number including any revision number to get the Behringer actual part number. They will give you and incident number as well for you to call FullCompass who distributes the spare parts now. You can find FullCompass phone number via Google.
Dec 13, 2010 | Behringer EUROPOWER EP4000 4,000-Watt...
I need an owner manualfor a Behringer pmp 3000 16 channel mixer
You can download the manual by clicking this link
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa
Jan 15, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Music Logo
212 people viewed this question
Top Music Experts
Michial Gueffroy
Are you a Music Expert? Answer questions, earn points and help others
