I purchased a dirt devil pool vacuum many years ago and the handle has cracked and I need a replacement handle, plus I need filters for the filter cartridge. I am having a hard time finding anyone that has these parts, any suggestions on where I can find the replacement parts?
SOURCE: HEPA Filter
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618630&thid=730623
HEPA Filter
Posted by jenski66 on Jul 02, 2008
My vacuum came with a sponge over the filter and the directions said I could wash the filter. Do the directions mean to wash the black sponge or the actual filter? Is the sponge part of the filter or is it trash?
Filter F27
Dirt Devil Purpose Cleaner for Pets
Upright Bagless Vacuum
Model #1LY2108-000
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Typically the top filter of which is the sponge is washable but the HEPA filter is not, it can be brushed off and vacuum off with another vacuum, but the best filtration is to replace the HEPA filter and to wash the sponge filter, if the sponge filter get to bad then replace the sponge filter as well. Or, you can check with your local vacuum cleaner dealer in your area or to contact the manufacturer’s website and or phone #. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://royalvacuums.com/ Customer Service 1-800-321-1134
Hours are: 8:00 AM to 7:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
SOURCE: Replacement FIlter for Dirt Devil CE6000
My filter fell apart on my dirt devil featherlite CE6000. I have only used this 4 times.Where can I find one? I have looked at several stores.
Sincerly,
Pennie Silverman
SOURCE: I recently ( approx. 2-3 months ago ) purchased a
Hi sounds like your line is stopped up somewhere , check ur suction an make sure your brushes are spinning, if they are try a wire clothes hanger to the hose at the bottom hose to dislodge anything that mite be stuck
SOURCE: I have a Dirt Devil Featherlite Bagless vacuum and
Try installing a new belt. also check for a clog in the hose.
SOURCE: I have a dirt devil featherlite carpet shampooer.
Hi There,
We actually do carry the foam filter for your Dirt Devil Featherlite (also manufactured as the Easy Steamer) carpet cleaner.
According to the Dirt Devil parts diagram for the CE6000, your machine takes the following foam filter. Here's a direct link to the filter on our website:
Dirt Devil Featherlite, Easy Steamer Foam Filter Part#
1-700750-600
Here's a link for the parts diagram for your Dirt Devil Featherlite CE6000 carpet cleaner. This will give you all of the part numbers, and drawings for each part on your machine should need any further parts:
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/dirt-devil-easy-steamer-featherlite-ce6000-parts-diagram.pdf
I hope this helped. If you have any further questions or concerns, please feel free to use the comment field here on the repair page to contact me, I'm always happy to answer any follow up questions.
If you found this repair helpful, please be so kind and rate the repair helpful and / or leave feedback for me. Thanks so much!
Chris Jones
GoVacuum.com
Testimonial: "That is it! Thank you so much. God is soooo good!!!"
