My crazy fit massage machine fuse blew, we replaced the fuse plugged it in there is power to the base but no power to the display unit
2 Suggested Answers
  • 209 Answers
SOURCE: Hotpoint WD51 fuse issue
is it the motor that got hot?, if so then check the motor carbons for wear, as these heat up when worn, also if the carbons are fine check the pump and filters for blockages, this makes the motor spin while water is still in the machine causing the motor to overheat, and subsequently tripping and blowing the fuses etc hope i have helped a little
Posted on Sep 25, 2007
I have a crazy fit power massage machine and it cuts off when u turn up to level 6 .
Why not try the contact at the web page for the machine. They may have an answer.
Crazy Fit Vibration Plate for Home Crazy Fit Massage
I noticed the following article as I was Googling information about this machine. It probably predates this machine. Just something to think about.
Shake your way to skinny Experts fear risks
Sep 03, 2017 | Washing Machines
What causes microwave to blow new fuse?
The only thing inside a microwave oven that draws enough current to blow a fuse is the magnetron that generates the microwaves to provide the cooking power. Based on the age of the unit (approx 15 years) it is most likely best to just replace it as repairs at that level are not cost effective. Newer units cook better and faster using less power these days.
Jul 02, 2015 | Sharp Microwave Ovens
My crazy fit machine just stopped then sparked from plate and blew my house fuses. what could b wrong
Dead short in electrical wiring, remove plug from wall socket. Need someone capable of testing electrical wiring.
Apr 28, 2015 | Exercise & Fitness
Why does my crazy fit massage vibrates violently as soon as you turn it on
It would be helpful to have more detailed info, but I;ll take a stab
at it... Usually, when a motorized device vibrates voilently (more
than designed to), it is due to missing parts or being out of
balance in the recriprocating mechanism. Try going over the
machine, again, with this in mind. If you can find another working
machine, make a comparison (perhaps in a local gym?)
Good luck !
Aug 19, 2014 | Sunny Health & Fitness Crazy Fit Massage
Why does the belt keep coming off my Crazy Fitness Massager? I bought this machine second hand so I'm not sure if the belt is the original. It has a Jiali 230J on it. The belt doesn't seem wide enough? Can...
Your pulleys may be misaligned (shafts must also be perfectly parallel) or the belt is possibly too long. Drive belts for fitness equipment here: http://store.beltpalace.com/fitnessbelts.html
They have a phone number to call on their website, too.
Ribbed Fitness Drive Belts for Elliptical Machines PJ Metric and...
Aug 09, 2014 | Sunny Health & Fitness Crazy Fit Massage
Display not lighting up at all
The display / control units are sensitive to voltage surges and it was most likely damaged when the fuse blew.
Apr 28, 2014 | Bosch Classixx WFO 2866 Front Load Washer
Bosch 2467/GB/06 no display no go
Check power on wall with some other gadget, check plug fuse....
Apr 27, 2013 | Bosch Classixx WFO 2466 Front Load Washer
I have a crazy fit massage machine that comes on ok and you can program it but as soon as you press the start button it trips the electric anyone any ideas ?
You have it plugged into teh wrong breaker possibly, see what breaker in you power box controls the washer, and plug it into an outlet that uses a bigger breaker, possibly 35AMP or so.
Sep 27, 2012 | Washing Machines
Crazy fit won't stop vibrating when it has power to it
1) You must test the switch stop.
see the diagram for to fix it.
May 10, 2012 | Sunny Health & Fitness Crazy Fit Massager
Crazy Fit Massager Body Vibration Exercise Machine Repair Manual/Troubleshoot guide
I have a problem with my crazy fit vibration machine it turns on fine but wont vibrate and the belt looks fine and it lights onn up control board but half of the numbers on the light up and missing :/
Aug 30, 2010 | Sport & Outdoor - Others
Washing Machines Logo
75 people viewed this question
Top Washing Machines Experts
