Question about Garden
Mitsubishi meiki GM132P engine
Engine surges
2010 dlp mitsubishi tv is not working after power surge even though it was on surge protector. Have replaced power supply board and lamp. Now it gives error code 5 red flashes then 7 yellow.
some one will have to answer the tv faults
I just want to remind you that the average surge protector is only good for the one hit
after that it still passes power but has no surge protection
Feb 20, 2016 | Mitsubishi Televison & Video
Oxygen sensor problem on mitsubishi outlander 2004
If the car has a check engine light on you may want to have the code checked, as this may point you in a direction as to what is causing this issue.
It could also be a bad EGR valve if the vehicle surges.
Hope this helps you out,
1aauto.com
Jul 10, 2012 | 2004 Mitsubishi Outlander
Have a 4M41 engine in the 2007 mitsubishi triton and when under acceleration between 2000 - 2600 rpm the engine hunts or surges and then clears after 2600 rpm. It is more noticeable in 3/4/5 gears only...
It needs a programming check of the accelerator pedal via ecu of the engine. All previous activity of the system is recorded in the ecu which can be corrected in the dealership of mitsubishi.
Mar 28, 2011 | 2001 Mitsubishi Montero
What is surge absorber? what is the function of
Hello,It is protection from overcurrent to power input (lighting strikes or unreliable electric service to house).Mandatory on computers,hd tv's any sensitive electronics.
Oct 27, 2010 | Mitsubishi MXZ30TN Air Conditioner
Had a power surge and now the lamp notification is on steadily
This is a common problem and usually shows up when power is interrupted. The capacitors in the micro, digital, and power supply have to be replaced. In my shop, we prefer to send the chassis to Mitsubishi and they repair it. Do you have a local authorized Mitsubishi service center near you?
May 28, 2010 | Mitsubishi WD-52725 52". Rear Projection...
95 eagle summit surging problem
check the idle control valve that can sometimes make the engine surge.
Jan 08, 2010 | 1996 Mitsubishi Eclipse
92 mitsubishi libero, engine surges downward in cold air, when accelerator pushed engine suffocates. difficult starting cold.check engine light on when warm, runs fine in warm weather or city driving
DIFFICULT STARTING CAR IN COLD.WOULD BE A THERMO - TIME SWITCH.THE THERMO TIME SWITCH CONTROLS THE AMOUNT OF TIME THE COLD START VALVE IS HELD OPEN BY MEASURING THE COOLANT TEMPERATURE AND UTILIZING A TIME FUNCTION TO PREVENT AN OVER RICH CONDITION.THIS COULD BE MOST OF YOUR PROBLEM.BUT SCAN IT TO SEE WHAT PCM CODE YOU ARE GETTING.
Sep 07, 2009 | 1996 Mitsubishi Eclipse
1990 Mitsubishi Galant - Engine Troubles
The first step is to borrow a scan tool to read what the error engine code that resulted in a check engine light.
Look the code up particularly for your engine and you will most likely find the fault.
You can report this Check engine code on this website and get some ideas for repair.
If the car was driveable you could take it to your friendly auto parts store where many of the stores will read the code complementary.
Hope This Helps?
May 12, 2017 | 1990 Mitsubishi Galant
Surging
A lot.
Fuel cut off valve
Wire harness
Pump.
Etc..
Jan 25, 2009 | 1995 Mitsubishi Mighty Max
Garden Logo
81 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
