Question about Asko 24 in. D3250 Built-in Dishwasher
Asko 1796 F2 problem
My Asko recently decided to give me an F2 error message. I gather this means that the water's not draining. Can you suggest a solution?
  • 1 more comment
  • Anonymous Nov 25, 2008
    live yo life how u see it me and my bffe....................
  • Anonymous Apr 13, 2009
    a light that usually indicates that a hard wash is running is lit with loud beeping noises, and the drain is constantly running. it only stops when the circuit breaker is shut off. I looked this up in the manual, it indicates that it is and error code because there is too much water in the machine, i tried to empty the filters and add more water, but the problem is not solved. I will probably call a service technician to solve the problem, which is what it says in the manual.
  • Anonymous Mar 12, 2014
    D 3142 feilmelding f2
I had the same problem. The pump was clean. The overfill protection was tripped.I moved the dishwasher ,laid a towel under it and helt the mashine from side to side until the water was gone. Then i started it.OK
Posted on Oct 09, 2007
  • 641 Answers
It sound like you have a blocked or a malfunction pump. Remove the pump from the machine and check whether you have a clogged inside the pump or in one of the pipes connected to it. In case all is clean, you should replace the pump.. Good luck !
Posted on Aug 27, 2007
SOURCE:
What does F2 mean
Hello, Welcome to FixYa. To answer your question..."What does F2 mean ?", the good news...It is likely nothing very serious, but the "resolve" requires some investigation on your part. F2 means the control has indicated a overfill. This is meaning the overfill switch is indicating an overfill has been detected. Whether the unit has actually overfilled or not remains to be seen. It may in fact have been caused by a long drain or backed up drain. I'm presently on my iphone so I can't post the pertinent info to resolve the error directly, however if you copy and paste this link to your browser all the info will be there and it will apply to your model Asko as well. http://www.fixya.com/support/t7832382-f2_mean Either that or visit my profile page and you'll see other post relating to the Asko F2 error, its meaning and remedy. Hope this helps, let me know and good luck. Regards, Macmarkus :)
Jan 17, 2011 | Asko 24 in. D3250 Built-in Dishwasher
F2 overfill. how to reset?
Welcome to FixYa.
Based on your description "f2 overfill. how to reset?" It is likely nothing very serious.
The "F2" with Asko dishwashers means the control is indicating an overfill has been detected...but I gather you know that based on your post.
Whether the unit has actually overfilled or not remains to be seen, but to reset it is fairly simple...if nothing else is at fault.
**before proceeding turn the dishwasher power off via the home breaker panel, or unplug it from the wall if that is possible...most are hard wired to the home electrical...safety first**
The first thing to do is remove the toe panel/kick plate and inspect the base for water. If water is present, with the aid of a sponge, towels, or a wet-dry shop vacuum, absorb the water from the base.
By way of removing the water from the overfill basin should "reset" the unit. If the unit works fine after resetting the power/breaker it can likely be chalked up to a drain back-up or obstruction in the drain hose or pump.
Try this and let me know what you find and I`ll assist you in moving forward if necessary.
Thanks for choosing FixYa and good luck.
Regards,
Macmarkus :)
Nov 15, 2010 | Asko D1776 Stainless Steel Built-in...
What does the F2 Error mean? I got that error thsi morning. The engine was buzzing so I turned the power off. I have cleared what appears to be calcium and/or soap build-up in the 3 filters and in the...
The F2 error means the tray underneath the unit has filled with water. You will need to pull out the dishwasher (remove 2 screws at top left/right when door open that prevent tilting). Unplug and pull out dishwasher. Remove 4 screws on bottom rear panel and you will see tray underneath. Sponge out water and F2 error will reset.
However, you should not get water in this tray. There may be a faulty valve, pump or leaking pipe. Run diagnostic mode (described in user manual) to see if leak occurs during filling, draining or circulating.
Sep 19, 2010 | Asko D1876 Dishwasher
F2 error message after dishwasher backed up when draining. Asko brand.
Hi
Thanks for using FixYa. Error F2 in your Asko Dishwasher means high water level. This error occurs due to plugged/bad water pump and/or a bad inlet valve. If the water pump and/or water inlet valve are bad it should be replaced to resolve this issue. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 26, 2010 | Dishwashers
Asko 3350 F2 fault meassage keeps flashing
you have a blockage try the drain spigot under the sink or the pump may be blocked.
Apr 23, 2010 | Asko 24 in. D3350 Dishwasher
My Asko dishwasher is not draining. Code F2
drain plugged, hose kinked or discharge pump bad
Jan 19, 2010 | Asko D1976 Built-in Dishwasher
Asko Dishwasher F2 Error Flashing
F2 flashes, and wll not stop runing. No water in pan. help
Sep 29, 2007 | Asko D1776 Built-in Dishwasher
F2 Error Message on my Asko D1776
F2 error message means that you have a high water level problem that could be caused: - A plugged or bed water pump - A defective water inlet valve (stay open) Good luck !
May 21, 2007 | Asko D1776 Stainless Steel Built-in...
F2 error message flashes, cannot reset.
Try to find out from where water leaking from (pump or inlet valve). The leaking one, should be replaced. Good luck !
Apr 22, 2007 | Asko D1976 Built-in Dishwasher
Asko 24 in. D3250 Built-in Dishwasher Logo
458 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
