Question about Coffee Makers & Espresso Machines
Gaggia unica clogged coffee spout - Coffee Makers & Espresso Machines
mirran
  • 515 Answers
SOURCE: need part
Contact Saeco service center and ask for spare part number: 223700550
Here are info to USA:
Saeco USA Inc.
7905 Cochran Road Suite 100
Glenwillow, OH 44139
Tel. 440-528-2000
Fax 440-542-9173
E-mail: info@saeco-usa.com
Visit the Web: www.saeco-usa.com
Posted on Jul 28, 2008
  • 5 Answers
SOURCE: gaggia classic -no steam from spout
I had almost the exact same thing. The fuse for your frother is out. If both the frother and the brew head won't heat, then it is your Thermal Fuse. There are two different fuses inside the machine. Take the top off, and find both fuses. Take a piece of wire and connect it to each end of the fuse. Now turn the power on. If it heats, then that is the fuse. If no results, try the other fuse. Either fuse should be cheap. My thermal fuse was $1.98. Good luck!
Posted on Jan 14, 2009
SOURCE: Espresso doesn't come out of the front spouts.
I'm having the same problem, did you solve it?
Posted on Nov 02, 2009
SOURCE: Clogged shower disc
We have the same machine -- the Italian grocer who sells us our coffee recommended the following and it worked really well for us:
use a blowtorch -- we have one of those kitchen ones for creme brulee and the like -- however, you will notice slight blackening of the disc -- otherwise the disc is fine. Shine the disc in the light to ensure all holes clear. Blast it again if necessary -- gets hot so ensure you have protected your hands etc...
Posted on Apr 28, 2010
SOURCE: Jura-Capresso Impressa Z5 - left coffee spout is
I had similar problem, Jura told to open a paper clip and push it up into the four holes on each spout. This worked the first time I had the problem. But now have one side not flowing again and the clip is not helping.
Posted on Aug 29, 2011
My Gaggia Unica won't grind the coffee beans, it just whirs and stops making the drink
More than likely the machine is stuffed with coffee grind. Need to take it apart and clean it. See https://www.youtube.com/watch?v=JQbP2v8C-sA
Sep 20, 2014 | Gaggia Unica Bean To Cup Coffee Machine
Why does no brewed coffee comes out? bypass preground does work
- coffee-channel is stuck.
check google for calibrating/cleaning your gaggia.
Aug 27, 2014 | Gaggia Titanium Espresso Machine
Gaggia unica red triangle flashing at same time as green cup
Hi there My experience tells me that when a red light flashes on a coffeemaker it is one of three things: It needs water to be able to make more coffee The "bowl" that the compressed coffee goes in ids full and needs emptying It needs cleaning I would start filling the waterholder, Then emptying the compressed coffee holder If neither works, then start the cleaning prosess Best of luck and enjoy your coffee Kolbrun
Sep 18, 2013 | Gaggia Brera Coffee Maker
After completing a descale the machine no longer pumps water through the shower head thing (the bit where you screw the coffee holder bit on. Sorry about my technical jargon. The machine still pumps out...
The water spray head is clogged up with pieces of scale. You'll have to take it off and rinse it out. If necessary, use a pin to pick the scale out of the holes in the spray head.
Nov 27, 2010 | Gaggia Classic Espresso Machine
Coffee sprays from portafilter spouts while pulling shot
Either the group gasket is dirty or damaged. Also check the basket for damage.
Jul 21, 2010 | Gaggia Classic Espresso Machine
Gaggia Syncrony "ventilate"
You need to push the hot water button on the machine panel to allow water to run out of the steam wand. After a few seconds the machines ventilate message should clear.
May 04, 2010 | Gaggia Syncrony Espresso Machine
Where can I purchase a replacement dispenser shute for Gaggia Synchrony Logic Type SUP 020 Ser.#9005GA40015808? Many thanks.
Check the site at importika.com they have a list of repair areas any one of them will have a spout in stock.
Mar 10, 2010 | Gaggia Syncrony Logic 74884 Espresso...
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
