Question about Amcor 9,000 BTU AutoDrain NanoMax Portable Air Conditioner KF9000E
Amcor KF9000E compressor quits after a minute
Bought an apparently reconditioned KF9000E unit and worked fine for season so bought a second....now each unit shuts off after a minute or so with a compressor light blinking. even if I disconnect the rear hoses. airflow is good, but why did both go bad so quickly? They were purchased from "Ollies Discount Barn".
SOURCE: Unit Cools for two minutes and takes a three minute break.
I am having the same issue, the exhaust fan that blows the hot air out of the home is most likely not working. I am having a hard time finding a replacement fan motor
Posted on Jul 23, 2008
  • 11 Answers
SOURCE: MAY AMCOR KF9000E PORTABLE AC THE COMPRESOR LIGHT
**** Yo CoUcH *****
OBAMA NATION!!!
Posted on Aug 30, 2009
  • 259 Answers
SOURCE: The AMCOR NANOMAX KF9000E is
It should be under warantee I would bring it back to the store for a exchange.
Posted on Mar 21, 2011
SOURCE: Parts for Amcor Portable Air Conditioner
need a window kit for amcor kf9000e.
Posted on Jun 09, 2011
  • 4736 Answers
SOURCE: my amcor plm-14000e a/c is
Your Amcor unit has been plagued with problems, which Amcor recognizes, but short of telling the consumer to return it for a refund, does little else, as far as repair is concerned..
The problem you're having is a common one for your model. The automatic full device has failed and the water collected in the condensation pan overflowed and wound up staining the ceiling below. If the Exhaust hose is not positioned properly (no kinks or downward bends) , most of the condensation should be evacuated out thru the exhaust duct. However, if it's extremely humid, the condensation goes into the collection pan and supposedly evaporates fairly quickly.
There are a couple of things you can do, to resolve this:
Depending on how long you've had the unit (it carries a 1 year Warranty) and still have your proof of purchase, you can return it for repair or replacement (at Amcore's option).
Pay for having the sensor replaced and repaired by Amcore or their designated repair center. Or order the part and replace it yourself.
Check and drain the condensation pan regularly. Which may be inconvenient, but cost nothing.
Raise the unit about 2 feet off the floor onto something really sturdy (the unit is heavy), attach a hose to the drain hole on the back lower left of the unit and drain the water into a 5 gallon bucket. Depending on how much and how cool you run the unit, the 5 gallon bucket would be good for 24 hours, before needing to be emptied.
Whichever step you decide to take, is yours to make. However, just to be on the safe side, if your unit is still in warranty. I would start with Amcor, first.
I hope this helped you. Please let me know. Thanks.
Posted on Jun 13, 2011
KF9000e. Why does compressor cycle at short intervals?
Yes. due to low rpm of fan motor in the condensor copil. or dirty condensor coil. I If so, replace fan capacitor.
If all good, check the seating of condensor set. It needs minimum 2mtrs open space for air throw. If not due to overheat compressor gets short cycling on and off.
Sep 07, 2015 | Amcor Heating & Cooling
KF9000e. Why has it stopped blowing cool air?
Depending on the age of unit either filter blocked needs cleaning or freon low is fan blowing do you have outside of unit clear of obstacles these are all things to check also remember if it's 100 outside AC will only drop air temp 20 or so degrees
Aug 17, 2015 | Amcor Heating & Cooling
Where can I buy the Amcor kf9000e power circuit board controller?
Hello there.
You really need to get the Power board Model number if you can read it off the board. Then try putting that number and the words 'power module' in to your search engine. Sometimes people carry spares by board numbers. alone.
From what I can tell , it looks like one of the only places to get parts for this are on Ebay.
How about Amcor themselves if you are in USA ? Worth a phone call.
Sep 22, 2014 | Amcor 9,000 BTU AutoDrain NanoMax Portable...
Amcor KF9000E portable air conditioner manual
My amcor kf9000e has stopped blowing cool air. What could be wrong with it?
May 18, 2012 | Amcor AF9000E Portable Air Conditioner
My unit keeps fluxuatng between cold air, then warmer air. It will start cooling then the unit seems to dim then amp back up sending out non cooled air.
Your compressor is drawing locked rotor amps. If the unit dims and then turns off a few seconds later, your compressor is going out on the internal thermal overloads. It could be a bad start capasiter or bad winding in the compressor. If you don't know electricity, it is not something I would recomend a DIY to fix.
Sep 28, 2010 | Amcor PLM-14000E Portable Air Conditioner
Your parts can be found at amazon, click here and take a look: Finally charging for our multi device world. I hope this was helpful. Cheers
Apr 30, 2010 | Amcor AF9000E Portable Air Conditioner
Amcor 9,000 BTU AutoDrain NanoMax Portable Air Conditioner KF9000E Logo
80 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Michael Youngman
Michael Youngman
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
