Question about Refrigerators
Edina vending machine manuel setting cooling control
3 Suggested Answers
guru_fixya
  • 944 Answers
SOURCE: I have a Fridgerare which
This problem could occur due to various reason.First you have to resolve for the cause of the issue.
First Check the back wall or floor of the freezer section for frost.The Freezer(evaporator) fan is running?.This fan problem is very hard to detect.
The DC motor for the fan wears out the RPM's are effected.It gives the illusion that it is running fine,but it don't have enough force to supply air circulation for both the freezer
and the refrigerator See weather the condenser coil for
blockage from dust and the condenser fan is running.
1)Defrost timer
Usually the defrost timer could solve this issue.It may be located below or back of the refrigerator.Some times it may be located in the side to for side refrigerator.
Locate the timer and rotate the clutch head screw clockwise until you hear one audible click. That puts the system into defrost mode. If the system restarts after 30-35 minutes.
Then there is no problem with Defrost timer.
2)Temperature control
Understand the flow of cold air is from freezer this is controlled by Temperature control unit.The temperature looks like the below diagram
Remove the front knob
There will be a pair of wire type connections attached with Temperature control unit.
Set the ohms setting on your multitester to X1 and attach one probe to each terminal. Turn the temperature control to off or to the warmest setting if there is no off position. The multitester should give you a reading of infinity if the control is on off and a reading of near infinity if there is no off position. Then turn the control to the coldest setting and retest. Now, the multitester should give you a reading of zero. If both of these tests are not passed, the control needs to be replaced.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Aug 29, 2010
I was told that freon leaked and the evaporator has tobe replaced and the refrigerator need to regas. But I cannot find a technican to do the job.They all say they do not do jobs like this.
Posted on Jul 08, 2013
Tip
Vending Machine Supplier
About Us : <br>Upton vending A largest vending machines company in UK, that provides wide range of vending machines in North Yorkshire at affordable rates,well known for customer satisfaction.Our best services are <b><a href="http://www.uptonvending.co.uk">vending machine companies</a></b>,vending machine, snack vending machine, drink vending machine,commercial coffee machines in UK..<br>Contact Us : <br>The Vivars<br>Selby<br>North Yorkshire<br>YO8 8BE<br>Tel: 0 1757 629112<br>Fax: 01757 294600
on Aug 17, 2013 | Nu-Dell Manufacturing Vending Machines Ad...
I have a fmr14 combination vending machine thats notcooling
It probably needs regassing but may have a leak. a fridge engineer should advise.
Aug 25, 2014 | Retail Supplies
The vending on my maytag skybox stopped working
What do the led's do when you try to dispense a product?
May 05, 2014 | Maytag SkyBox MBV1976A Beverage Dispenser
Genesis go380
how come my Genesis will dispense two chocolate bars at a time? Is this a setting of some sort?
Aug 13, 2013 | Selectivend Combo Vending Machine for 14...
What are the two red led lights on a skybox circuit board for? Mine are lit up and the unit won't cool. Is that an indication of what is wrong? If so, any idea what it is?
The red lights on the board indicate it is working properly. The purpose of the board is to control the dispensing of the beverages, and has nothing to do with the cooling process. You have a cold control (thermostat) inside the refrigerated area. The cold control is like a switch that sends 120vac to the compressor when cooling is needed. The failure of the unit to cool would be either a bad cold control, compressor, or compressor start relay. Testing of live electrical circuits should be left to a qualified service technician.
Oct 05, 2011 | Maytag SkyBox MBV1976A Beverage Dispenser
I have the same problem with my Antares vending machine. Do you know what the model number is on that Frigidaire freezer? I want to buy a new evaporator but can't seem to find it.
You need to contact Frigidaire Parts Division. You need an evaporator for their EDINA Model FMR7. The part number is 216701200. It should cost approx. $100.00. This should be all you need. Good luck.
David
Mar 08, 2010 | Refrigerators
My Edina cold soda vending machine which was made by Frigidare is not getting cold. The previous owner (my neighbor who I trust) said it had always worked fine. It had been in his garage, unplugged, for...
I have some of those machines. What happens to them is that the evaporators, which are made out of steel, rust out in approx. 7 years. This allows the R134A to leak out. If you can peek back through to the back wall, you will see where the rust has run down. The solution is to order a new evaporator from Frigidaire at around $100.00 and get someone to change this out and recharge the unit. Before turning it over to the mechanic, you may want to remove the vending module which includes the inner doors and plastic shelves. This can be done in 15 minutes and makes the job easier for the mechanic which can save you money. You should end up with less than $300.00 for the total cost of the repair, but since these machines are rather popular, they can be had on ebay fairly cheap. Sometimes you can pick up new machines for five or six hundred dollars. These are the same as the Antares machines which are made by Edina. I hope this helps.
Jun 18, 2009 | Electrolux Refrigerators
Refrigerators Logo
15 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
