Question about Maytag Washing Machines
MVWC200XWO On Spin Cycle Inner Tub Bang Violently
onthejob5130
  • 640 Answers
SOURCE: spin cycle very loud,
spin surpport defective,,,this part is under warranty,,lifetime warranty..contact whirlpool for replacement of spin basket,,onthejopb
Posted on Feb 07, 2009
jeffjohn01
  • 4 Answers
SOURCE: Shook Violently first time on spin cycle
Make sure you take out the four shipping bolts on the back side or you will surely damage the tub and it will shake and vibrate terribly.
Jeff
Posted on Mar 12, 2009
venexcsd
  • 1185 Answers
SOURCE: During the final spin cycle, water is leaking inside the machine
You have a problem with the pressure switch cutting in too early before all of the water has drained away from the outer drum
There is either an obstruction in the outlet pipe or pump which is not allowing the water to discharge fast enough.
The machine is then spinning with too much water left in the outer drum added to the water which is being expelled from the clothes equals leaking
Take the hose off the back of the machine and put it in a sink , make sure it is secure and do a rinse cycle
Watch the outlet and make sure it is a strong flow if it is weak then you have probably got an item of clothing stuck in the pipe from the drum to the pump and a strip down is required
One more thing there is a small plastic bottle attached to the back of the outer drum this has tube which leads to the pressure switch
Make sure there is no congealed soap in the Air Bell as it is called
Posted on Jul 05, 2009
  • 151 Answers
SOURCE: I have a GE top load washing machine. During the
there are springs under the machine that attatch to the tub in 3 to 4 places if one of these springs break it will cause the tub to bang.
Posted on Dec 24, 2009
SOURCE: the drum shakes violently and is very loud during spin cycle
There are 2 shock absorbers/springs attached to the drum. If one of them breaks it will cause a loud banging noise when you wash heavy loads. This is an easy fix. The part is about $22.00 and it is accessed throught the front bottom panel.
Posted on Jan 04, 2010
Why does the inner tub for the LG washing machine tub not spin when the tub is full?
not sure I understand you, but ur drum should or does not spin when full as it is set that way, first the drum drains most of the water then it goes into spin?
Jul 29, 2014 | LG Washing Machines
Shakes violently during spin cycle from back to
I had this problem with my front loader as well. It is probably the mounts or "level shocks" on the bottom of the unit under the tub. I have a Kenmore by Frigidaire and had to replace the "level shocks". I only paid about $43.00 and was not that hard to put on. Look under your machine and see if the shocks are connected to the tub. Check under the top panel also to see if that particular model has mounts up there too.
Mar 12, 2010 | Maytag NFW7200TW Front Load Washer
Dec 22, 2009 | GE WBSR3140DW Top Load Washer
Washer bangs loudly in middle of spin cycle
Make sure the back spring is still on the back of the tub. That tends to come off sometimes. Check all the other springs while you're down there too. You can balance the unit if you tilt the back side of the washer and then set it back down. it has auto leveling feet. What's happening is once the water is all drained out, the unit will enter the final spin cycle and spin very fast putting the unit off balance so the tub bounces around.
Good luck, let me know if this helped.
Aug 10, 2009 | Kenmore 23012 Top Load Washer
Spin cycle very loud,
Feb 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Violate shaking in spin cycle
Yes you need to remove the agitator to do this and there is a nut that holds the tub down these come loose alot from the factory alot of times you can remove the nut and put lock tite on the treads and re tighten and be fine but in most of the cases you need to replace the spanner nut and the split ring under ther tub at the same time to take care of the problem the split ring isnt that hard to replace you just need to remove the splash gaurd from the top of the tub and several brackets that hod the header on and just lift inner tub out and there on the transmission is the split ring it looks just as it says just a little ring with a split in it replace these and it will solve your problem but you will need a special tool to tighten the nut back due to the room in the tub (center nut spanner tool for a g/e)
Jan 08, 2009 | GE Washing Machines
Noisy clothes washer
I am thinking there may be an object caught between the inner and outer tubs...perhaps something came out of a pants pocket and was "flung" overboard into the outer tub. If you remove the top, and push the inner tub (moving tub) to one side, look with a flashlight for a foreign object. the noise will be fine until high speed kicks in and begins to disturb the sleeping object into a frenzy.
Jul 25, 2007 | GE WHRE5260E Top Load Washer
Washing Machines Logo
19 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
