Question about Ovens
Kitchenaid oven melted yellow plastic
2 Suggested Answers
  • 10865 Answers
SOURCE: Melted plastic lid in oven - how can I remove it
Any oven cleaner, like easy off will work on this but it may take more than one application. You can actually begin with your hair blow dryer and a putty knife by heating the plastic up enough to scrape most of it off. Then let the oven cleaner do the rest.
Posted on May 20, 2009
The plastic ties were left on the oven rack. One melted . How do I get the plastic off the bottom of a self cleaning oven?
Warm Method Both Good Housekeeping and the website Hunker describe this method for self-cleaning ovens. Hunker warns to NOT use the "cold method" which is reserved for other types of ovens. And the Good Housekeeping site says if the method proves unsatisfactory, that the floor or bottom plate of the oven might have to be replaced.
(That said, I suspect if you pull out oven racks and apply some ice to any plastic on it, the plastic might become brittle enough that tapping it with a spoon and prying at it with something wooden or finger nails might remove a lot of it. No scraping with the spoon!)
Here is the primary process for the oven.
Self-cleaning ovens require heat to remove the melted plastic. This method also works on heating elements with plastic on them. Step 1 Turn the oven on to the lowest heat setting. Only leave the oven on long enough to make the plastic soft and pliable.
Step 2 Scrape the melted plastic with a wooden utensil such as a spatula or spoon. The wood protects the surface inside the self-cleaning oven. When you get all off that you can, the self cleaning feature may burn off the rest. That WILL be smokey and exude an unpleasant smell while it does it. Open windows and keep pets out of the area (and yourself) while it goes through the clean cycle. Do NOT use a screw driver to try and remove the plastic.
Aug 26, 2017 | Ovens
A black plastic meat container melted all over the bottom of the oven ,can I self clean the oven once it cools will it come clean?
not safe, the plastic will most likely release toxic fumes when heated that hot Try warming the oven until the plastic is soft, then scrape it off.
Apr 20, 2016 | Ovens
Melted plastic on heating coil
you can not remove the plastic safely please replace the heating element
Sep 30, 2013 | Frigidaire (FEB30S7D) Oven
I have a kitchenaid KEBC208 Built in double oven. The cooling fan makes noise. It stays on long after the oven is turned off and we sit in the kitchen and have to listen to it while we eat dinner. Can you...
Hello. look in the yellow pages of your phone book for appliance repair. Find a store that sells or repairs kitchen aid. There are several possible causes for the problems you site. Only a trained repairman with the proper scanners and tools can isolate and fix your oven.
Aug 28, 2009 | KitchenAid KEBC208 Electric Double Oven
Oven door locked, can't get plastic cover of control panel off
you have to first remove the side trim there should be some screws in the side usaly 2 but sometimes 4 ---you could have replaced just the fuse for less than 20 dollers
Aug 09, 2009 | KitchenAid Architect® KEBS277S Electric...
May 17, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Stove smokes when i turn the oven on
on the oven's smooth surface you should use a razor blade and scrap off the plastic (when cooled).. if the plastic melted on the burner, you may need to replace that particular element from a local appliance part store. easy to do.
Apr 20, 2009 | GE JKS05 Electric Single Oven
Cant find oven light switch
the switch is part of the latch assy, it most certainly is, it is quie possible, htat the heat of a self clen cycle, has melted/malformed the plastic latch housing causing the "Plunger " to become dislodged, and is sitting within the opening somewhere. bit it is ddefinalty part of that assembly
Jan 21, 2009 | KitchenAid Architect Series KEBC107KSS...
My GE Microwave/Oven Combo Unit JKP85B0A3BB has a melting chamber
It is one unit. You can not replace just a microwave.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Dec 01, 2008 | Ovens
Gas oven - - melted plastic inside
You can remove the bottom oven panel and look under it. All you have to do is remove the oven racks and locate the screws that hold the bottom panel in place. MOST ovens only have two of them. Once you have the crews removed, the panel slides back a bit, then lifts up. If there are any heavy deposits of melted plastic, remove it like you did before. Any residual material can be taken off with some fine emery paper. Wear a dust mask and vacuum all the dust out of the oven. DO NOT use this method on the oven wall as it may scatch it. This is only for anything that may have dripped below the oven pan. You may have an odor to the oven for a while, but as long as you have nothing else melted inside this should go away. Try running it on a cleaning cycle AFTER you've inspected the oven & cleaned out the remaining plastic. This will burn off anything left behind. I hope this helps you.
Feb 12, 2008 | Ovens
Ovens Logo
42 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
