Question about RCA RAS1863P WIRELESS SPEAKER WITH AIRPLAYR [RAS1863P] -
How do i pair this product to ipad2
Rca ras1863p
How to install keypad for my ipad2 keypad0713see200
if its a bluetooth key board go to the settings on your ipad turn on your bluetooth click find devicesand locate the key board tap on it and put in the pairing code (usually 0000 or 1234) that should allow you to pair your keyboard and ipad
Feb 27, 2014 | Apple Audio Players & Recorders
Connect iPad2 to set
Refer the user manual to this RCA Tv, for more details
Oct 08, 2013 | RCA TruFlat 27F520T 27" TV
Jam2 speaker will not go into pairing mode so i can pair it with my ipad2
On my Jam2, pushing and holding the play button puts the device into pairing mode. Nothing in the instructions suggests this, but it definitely works. You'll know it's gone into pairing mode when the blue indicator light begins flashing quickly.
Sep 08, 2013 | Radio Communications
Can I buy Microsoft office for a ipad2 or for a kindle fire
Microsoft Office as of today is not yet available for the iPad. There are a few alternatives that you might want to check out:
CloudOn App: http://itunes.apple.com/us/app/cloudon/id474025452?mt=8
iWork for iOS: http://www.apple.com/iwork/
Apr 16, 2012 | Microsoft Office 2003 Basic Edition...
Ipad2 can find Jabra BT2080
I'm assuming you meant "Ipad2 cant find"
Some Bluetooth device cant be detected by The ipad as it states here in a review of the product
"We tested the iPad with several Bluetooth mono headsets, and while we were able to pair some of them with the iPad 2, we were unable to direct any of the iPad 2's audio to the headset, nor were we able to use the headset's microphone with applications that accept microphone input."
Aug 31, 2011 | Jabra BT2080 Bluetooth Headset
Trying to hookup XM radio to RX-397; no sound. Which inputs should I be using?
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Yamaha-RX-397-Receivers-manual/id/320ag614/t/2/
Anything that has a headphone output can be adapted to feed an RCA cable pair for standard stereo to any audio device with a standard RCA input (except PHONO). Get a cable like the one described here: http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
Of course, if your XM device has standard RCA outputs, use RCA cables without adapters.
May 27, 2011 | Yamaha RX-397 Receiver
How to pair philips shb6100 with ipad2
First, in order to pair the iPad to a Bluetooth device you need to make sure the Bluetooth device is discoverable. Refer to the instruction manual for the device (which you can find online usually if you lost it) on how to do this. Typically, it just involves holding down a button for a few seconds. Next, you need to turn the iPad's Bluetooth capability on. Go to Settings by touching the Settings App icon that looks like gears. Within Settings, select General and then Bluetooth. Once you are in the Bluetooth screen, press the on/off switch to turn Bluetooth on. Make sure it reads "on". Once you turn on Bluetooth, you should see the discoverable Bluetooth device show up on the screen as part of a list. Select the device you wish to pair with the iPad. Depending on the device, it may prompt you for a password. Refer to the Bluetooth device's product manual for this password. Hope this helps
May 18, 2011 | Philips Televison & Video
How can I connect a portable device laptop, mp3 player, ipod to the rca blue ray home theater model number RTB1023????
and connect it into any available analog input EXCEPT "Phono". AUX, in your case.
Apr 29, 2011 | RCA Audio Players & Recorders
RCA RAS1863P WIRELESS SPEAKER WITH AIRPLAYR [RAS1863P] - Logo
24 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
