Why wont my sears large capacity model#110 91511100 top load washer wont drain or spin
  • 156 Answers
SOURCE: washer wont drain or spin just hums and then blows fuse
bad motor
Posted on Feb 25, 2008
SOURCE: Whirlpool Heavy Duty Super Capacity Plus top loading washer
i see water around the bottom outside of my whirl pool heavy duty spuer capacity washing machine...in the spinning cycle it appears to be going out the drain hose and drainning ok???
Posted on Aug 25, 2008
huuum
  • 750 Answers
SOURCE: frigidaire washer model FWX833AS1 top load
Hello Lcl2610.
welcome to Fixya,
My name is Huuum,
How old is your machine?
I have found some reasons of what may be the matter!
List of thinks to check
1.Defective Lid Switch
Check lid switch for proper operation. Check the switch for continuity. If it is found to be open, replace the switch assembly.
2.Faulty Direct Drive Coupling
The Direct Drive (motor) Coupling may be broken. Many Whirlpool/Kenmore brands washing machines utilize a small, relatively inexpensive direct drive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other.
It can wear out over time or fail under overloading conditions. This protects your transmission from excessive loading.
3. Faulty Water Level Switch
If the water level switch is not resetting once the water is drain, power will not be available to operate the motor during spin. Check the water level switch for proper operation.
4.Will not drain and displays F/02
The error code F/02 will be displayed if the drain time exceeds 8 minutes. Press pause/cancel twice to remove display. Check the pump filter and wiring connections on the pump. If all looks good, replace the pump.
You may want to use a pro, rather than attempt this project your self.
Let me know how it goes!
Thank you Huuum.
Please remember to leave a rating
Posted on Oct 21, 2008
jumptrout51
  • 3361 Answers
SOURCE: washer does not spin
You must replace the direct drive coupling between the motor and transmission. About $30.00
Posted on Mar 10, 2009
honeymokey
  • 3113 Answers
SOURCE: Maytag washer, model: LAT8415AAE top loader. Washer fills with water but will not start agitating,spin or drain.
Check lid switch. Most will not run with lid open and the switch may not be pressed down when door is closed
Posted on May 17, 2009
My model 20632 990 Kenmore Super Capacity clotheswasher wont spin or drain
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Oct 12, 2010 | Kenmore Washing Machines
My washer starts of just fine but when going in spin cycle its slow and wont drain belt looks good,its just looks like the motor wont go into high speed
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Sep 06, 2010 | Westinghouse WWS833ES Super Capacity Top...
My washer overflows. it wont stop putting water
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (110.########) and you'll see a list of major sub-components with diagrams and parts.
(The 110 means that it was manufactured by Whirlpool, you also need to enter the 8 digit model number)
Also see the Whirlpool / Kenmore Service Manual for these washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It has testing procedures as well as a good description of how the washer works.
It sounds like a defective water level switch or water inlet valve.
See the following for how to release the console and cabinet on these machines in order to get to the switch for testing.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
Basically, what happens is:
When the washer is turned on, the water inlet switch is closed allowing water to flow thru the inlet valve. When it senses that the machine is to the level selected by the water level dial, the switch opens shutting the inlet valves.
If the switch or valve is defective, water will continue to enter the machine.
The Whirlpool Service Manual has testing procedures (basis continuity tests with a multimeter) for both the switch and valve.
May 10, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore heavy duty extra large capacity washer will not drain or spin. model #13212200
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.13212200&pathTaken=partSearch
If it neither drains nor spins, the first thing to check is the Lid Switch. This prevents the machine from draining and spinning if the lid is open.
I assume that you cannot hear the motor trying to turn.
See the following for how to access the console and Lid Switch connection.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=6f8112b458c05fcc8f6d1a4139b9a723
Following is a Whirlpool installation and maintenance PDF on top load, direct drive washers. It has a description of how to by-pass the switch.
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, remove the two plastic clips from the console,
remove the two screws under the clips, tilt the console back, unplug the switch and using an short piece of insulated wire,
jump the two outermost contacts on the connector coming from the console and plug the washer back in.
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
Apr 25, 2010 | Kenmore Washing Machines
What is the capacity of the Kenmore Model 110 Series 70 Heavy Duty Plus washer (circa 1985)? It is finally time to replace it. Sorry to see it go!
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Many of the Sears parts sites for washers have a section where you can see PDF versions of their manuals. Look to the right of the main sub-components list and you may see it.
Oct 17, 2009 | Kenmore 24032\24036 Top Load Washer
Water wont drain out of washer
If the washer will agitate and spin but won't drain, the problem points to the pump.
See the following for how to remove the pump on top load, direct drive washers.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=134&osCsid=54a38ed7736cb193900d050b98aa7947
Check the discharge hoses and see if there is an obstruction in the pump itself.
Oct 16, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite King Capacity wont agitate or spin
Following is the Sears Parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.20952992
Following is the Whirlpool / Kenmore installation and maintenance PDF for top load, direct drive washers. It includes troubleshooting and testing sections for both the motor and capacitor.
Oct 06, 2009 | Kenmore 15864/15862 Top Load Washer
Water still in bottom of tub after drain/spin cycle
I removed the drain hose from the bottom left rear corner of the washer & cleaned a large amount of gooey sludge from the bottom of the drain inside the washing machine.
Feb 14, 2009 | Kenmore 12502 Top Load Washer
Won't spin or drain
Check to make sure your lid switch is working.
Nov 17, 2008 | Kenmore 22422 Top Load Washer
Tub will not drain or spin
Dear customer,
i recommend you to kindly check the following parts of the washer..
  • Inspect the drain hose for kinks
  • Test the timer control
  • Test the lid switch (some models)
  • Inspect the water pump
  • Inspect the drive belt (belt drive only)
  • Inspect the motor coupler
    • Inspect the agitator
    • Inspect under the washer for soot (clutch)
    • Test the motor
    • Inspect the pulley
    • Test the transmission
    • Inspect the pump coupling
    hope u find it useful. thank you.
    Jul 06, 2008 | Admiral AW22 Top Load Washer
    Washing Machines Logo
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
