Question about Sears Easi-load Lighted Slide Viewer
How do I remove battery case to replace batteries
Calculator will not turn on. How do you replace the battery? it is a TI30xa
The TI-30Xa uses two A-76 lithium batteries. Comparable battery model numbers include:
Duracell® D357
Eveready® 357
Maxell® LR44
Varta® V13GA
To replace the batteries:
• Remove slide cover. Place calculator face down.
• Using a small Phillips screwdriver, remove screws from back case.
• Remove back case.
• Remove discharged batteries.
• Install new batteries positive side up, as shown on diagram inside case.
• Run a coin across the reset pad on the upper right hand corner of the printed circuit board.
• Replace back case, and then replace screws.
• Press [OFF], [ON/C], [ON/C].
Note: The calculator cannot hold data in memory when batteries are removed or become discharged.
Feb 16, 2011 | Texas Instruments TI-30XA Calculator
Change batteries
1. Remove slide cover. Place calculator face down.
2. Using a small Phillips screwdriver, remove screws
from back case.
3. Remove back case.
4. Remove discharged batteries.
Caution: Avoid contact with other calculator
components while changing batteries.
5. Install new batteries positive side up, as shown on
6. Replace back case, and then replace screws.
7. Press OFF ON ON.
Caution: Dispose of old batteries properly. Do not
incinerate batteries or leave where a child can find
them.
Your calculator cannot hold data in memory when
Feb 02, 2011 | Texas Instruments TI-30XA Calculator
Directions for changing battery
2. Using a small Phillips screwdriver, remove screws from back case.
Caution: Avoid contact with other calculator components while changing batteries.
5. Install new batteries positive side up, as shown on diagram inside case.
7. Press: [OFF] [ON] [ON].
Caution: Dispose of old batteries properly. Do not incinerate batteries or leave where a child can find them.
Your calculator cannot hold data in memory when batteries are removed or become discharged.
Nov 27, 2010 | Texas Instruments TI-30XA Calculator
How do you open a TI-30Xa in order to replace the battery?
• Remove back case.
Oct 07, 2010 | Texas Instruments TI-30XA Calculator
Change battery
For up to 1000 hours of operation, use Panasonic
LR-44, Ray-O-Vac RW-82, Union Carbide (Eveready) A-76, or equivalent battery types.
For up to 2500 hours of operation, use Mallory 10L14 or D357, Union Carbide (Eveready) 357, Panasonic WL-14, Toshiba G-13, Ray-O-Vac RW-42, or equivalent battery types.
3. Pull off back case.
7. Press ' ! !.
Battery Information
The BA Real Estate calculator cannot hold data in
memory when the batteries are removed or become discharged.
Aug 18, 2010 | Texas Instruments BA Real Estate...
How to change battery on a swatch skin watch
  1. Place the watch in case holder. Place the watch in the case holder, if you have one. If you do not, place it on a soft cloth.
  2. Check for room to work. Check to see if there is room to attach the adjustable case wrench and rotate it 360 degrees. If not remove watch band.
  3. Remove case back. Fit the adjustable case wrench into the slots on the case back. Tighten it down until it is snug. Be careful not to slip with this tool as it can scratch the case back of your watch. Work slowly. When it is unscrewed gently pry up the case back taking great care not to damage the internal gasket. If the gasket gets damaged it will need to be replaced with the battery to retain water resistance.
  4. Remove battery. The battery will be held in place by some type of retention device. It will need to be removed. Some clips will be removed by using tweezers. Some clips may be moved using a screw driver, and some simply bend out of the way slightly. Remember how it was removed as it must be put back in place exactly for the circuit to be completed after battery change. If the clip is removed, place it and any screws in a paper cup to prevent loss. Remember how the battery was seated, plus (positive) side up or down etc. it needs to be replaced correctly to work.
  5. Test battery. Using the battery tester check the battery. If it is dead move to next step, if it is not take the watch to a jewelers for inspection.
  6. Clean and inspect battery box. Inspect the battery box the battery came out of. If there is corrosion take it to jewelers for inspection. If there is light dust it may be cleaned with a clean soft cloth.
  7. Buy battery. Use the numbers on the battery and buy a new one. Occasionally the number will be obsolete and you will be referenced to a replacement battery in the battery charts. This is the time to also replace the gasket if you need to. Check with a watch maker or jeweler, or the watch company to buy a replacement. We cannot stress enough how important this gasket is to a water resistant watch, without its integrity your fine watch may no longer be resistant.
  8. Replace battery. Using the plastic tweezers if you have them, or fingers wearing cotton gloves, replace the battery. Never use bare fingers as finger oils may corrode or short out the new battery. Carefully replace the retention device as it was remove.
  9. Replace case back. Make sure that the gasket is in place, and not pinched or caught in the case back when you set it in place. Screw down the case back using your fingers until it is tight and needs the case wrench. Attach case wrench as before and tighten down the case back.
  10. Reset and clean watch. Using the appropriate method reset the watch. Use the polishing cloth to clean off any dirt and finger prints.
OR...take to your local jeweler/watchmaker who has the appropiate tools and let them do it for you!!!! :)
Aug 14, 2010 | Swatch Skin SFK254 Watch
The batteries aren't working anymore, how do you replace them?
  • Remove back case.
The TI-30Xa uses two A-76 lithium batteries. Comparable battery model numbers include: Duracell® D357 and Eveready® 357
Aug 12, 2010 | Texas Instruments TI-30XA Calculator
How to replace a battery on a ebel watch?
The most water resistant watches will have a screwed down case back and crown for maximum water resistance, both of which are backed by internal gaskets. These are the types this articlde will concentrate on. To change the battery in a water resistant watch you will need:
  • Adjustable case tool
  • Case holder ' + google_ads[0].line1 + '
    ' + google_ads[0].line2 + ' ' + google_ads[0].line3 + '
    ' + google_ads[0].visible_url + '' + ' Ads by Google'; } else if (google_ads.length > 1) { s += 'Ads by Google
    '; for(i = 0; i ' + google_ads[i].line1 + '
    ' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
    ' + google_ads[i].visible_url + '
    '; } s += ''; } document.write(s); return; } google_ad_client = 'pub-8735055091446807'; google_ad_channel = '5953492595'; google_ad_output = 'js'; google_max_num_ads = '2'; google_ad_type = 'text_html'; //google_image_size = '468x55'; google_feedback = 'off'; // --> google_protectAndRun("render_ads.js::google_render_ad", google_handleError, google_render_ad);
  • Small screw driver
  • Polishing cloth
  • Cotton gloves
  • Small tweezers
  • Plastic tweezers
  • Soft clean cloths
  • Battery tester
  • Paper cup
Aug 10, 2010 | Ebel Sportwave Gent 100m Water Resistant...
I need to change the battery on the tI30-xa calculator. I need to know the size and how to change it.
Remove slide cover. Place calculator face down. Using a small Phillips screwdriver, remove screws from back case. Remove back case. Remove discharged batteries. Caution: Avoid contact with other calculator
components while changing batteries. Install new batteries positive side up, as shown on diagram inside case. Replace back case, and then replace screws.
May 19, 2010 | Texas Instruments TI-30XA Calculator
Need to replace battery on TI-30XA. What is No.
It's cheaper to buy the new one. On amazon they are pretty cheap. take a look Amazon com TI 30X. cheers
Aug 24, 2009 | Texas Instruments TI-30XA Calculator
Sears Easi-load Lighted Slide Viewer Logo
37 people viewed this question
Top Sears Video Cameras Experts
J.D. Browning
J.D. Browning
Tony Parsons
Tony Parsons
Are you a Sears Video Camera Expert? Answer questions, earn points and help others
