Question about GE J Series 20.6 cu. ft. Top Freezer No-Frost Refrigerator TBX21JABWW
Tbx21ji refridgerator has water inside the bottom of fridge. it keeps happening
  • 3 Answers
Mine did the same thing. Pull refrigerator out so that you can access the back. Take off lower dust cover , it's black and has several small screws. Once removed, you can see a pvc pipe running from top to bottom. Remove screw from clamp that holds pvc pipe vertical. Remove pvc pipe from top of refrigerator, then remove the top piece that was attached to pvc pipe. You may need to turn 1/4 turn counter clockwise to remove. Once removed, clean these 2 pieces thoroughly to remove any blockages. Install in reverse order and hopefully this fixes your water problem. This pvc pipe runs to a pan that water pools in and evaporates. If the water can't get here, it has to go somewhere.
Posted on Aug 22, 2014
4 Suggested Answers
HVACRH20
  • 237 Answers
SOURCE: GE refridgerator
If the unit has an ice maker or water dispensor, etc. there's always a chance a connection is loose or a valve is leaking by. If no other water is hooked up to the refer, then the defrost cycle water that should drain down to the bottom underneath pan is what is likely. You may have to take the inside rear panels off to see if the drain line is plugged up, that would allow water from the defrosting of the coils to drip inside the fridge vice outside like it should.
Posted on Jan 02, 2007
  • 193 Answers
SOURCE: I need a owners manual for the GE French door,
go to ge.com to download
Posted on Oct 03, 2009
  • 256 Answers
SOURCE: We have an old GE
Normally on the older models the door seals start to fail. If that happens, condesation builds up in the fridge and water starts building up. You will not always be able to see exactly where the seals are perished, but once changed, your problem should be solved. Hope this helps
Posted on Aug 22, 2010
Water dripping inside KTLA22EMSS01
Your freezer actually cools your fridge. It sounds like you have ice build up in your freezer behind the back panel. You should be able to unscrew the back wall inside your freezer. A hair dryer should help defrost or keep it open for a few and use a screwdriver to remove the build up of ice. The ice has made its way down the vent and when it hits the fridge it is above 32 degrees so it is melting. Hope this helps. I manage rental properties and have had it happen on a few occasions.
Aug 16, 2012 | KitchenAid Refrigerators
My refridgerator leaks
either there is a pub hole in the giving on the ein or our just is not tightened enough at the connection. is there water ay the bottom if the fridge cause usually there is so reservoir to keep water cold ay the back boutin of the fridge. youre going to have to look for water and follow the trail. remember water cant flow upwards so lllllll for the leak above the highest place you find water
Jan 08, 2012 | KitchenAid Refrigerators
Water on the inside floor of the refridgerator,
remove back panel from freezer and unglog hole where it collects water. its glogged
Feb 11, 2010 | Maytag MSD2756G Side by Side Refrigerator
GE regrigerator not cooling or freezing
first defrost it by turning it off for 1\2 to 1 full day,put towels on the floor to catch the water,when a refridgerator gets frosted up it cant circulate the cold air,and if its one with the freezer on top then the cold air cant blow down into the refridgerator,check inside the refridgerator at the top where the thermostat cover is there will be a vent hole,it could have ice built up so much that its totally blocking the air flow.This usually happens when hot food is put in the refridgerator and causes steam,or the refridgerator runs too much caused by bad door seals,or the cooling fins on the back or bottom underneath plugged with dust and the freon gets too hot causing condensation inside the freezer which causes it to frost up,a plugged drain hole will back up water and freeze,the fan in the freezer may have stopped working,which is about a $60.00 part,and finally a bad defrost element (about a $40.00 part)which is a glass tube inside the freezer with a coiled up wire inside it that heats up at certain times to defrost any ice build up,(which is the last thing to check)
May 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice and water on the bottom shelf
the blower motor of your fridge which is located at the back panel of your fridge is not running
Mar 06, 2009 | Refrigerators
Puddles of water in Fridge
you may want to check your door seal, air leaking thru the door seal causes condesation,also make sure that the drain tube is clear under the defrost element in your freezer.
Dec 18, 2008 | Refrigerators
Is there a water resivior/catch under the TFR22PR refridgerator?
towards the bottom inside the fridge, you will find a gulley with a drain in the middle. this drain is blocked. push something flexible down the drain till water flows away freely
Oct 20, 2008 | Refrigerators
Fan keeps freezing
HI .did you pull the fridge, away from the wall, and clean out the drain tube ,at the back. if not pull fridge away from wall, find the drain tube, and clean. thanks the appliance doc
Aug 04, 2008 | GE PDS22SBRLSS Bottom Freezer Refrigerator
GE refridgerator
Jan 02, 2007 | GE GTS12BBPLCC Top Freezer Refrigerator
Refrigerators Logo
143 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
