Question about GE Profile PSS26PSTSS Stainless Steel Side by Side Refrigerator
Freezer forming ice stalagtite under ice tray
The ice compartment on our GE profile PSS26PSTB side by side is leaking water such that is it creating ice stalagtites under the ice bin. The ice measures about 16 inches long. Everything in the freezer appears to be staying very cold - so it is strange that this is happening. There is also ice forming near the bottom of the refrigerator behind the second bin from the bottom. Any help would be appreciated
  • GE Master
  • 10,291 Answers
Sounds like the ice maker is allowing too much water in to the tray. There is an adjustment screw under the front cover of the ice maker. A 1/8 turn at a time counter clockwise will shorten the time the water delivery solenoid is open. It is possible that something foreign is keeping the solenoid valve to stay open too long, so it should be inspected too.
Posted on Jul 28, 2017
  • 126 Answers
SOURCE: Ge profile leaks from front of freezer
your drain will be plugged under the tray. there is a hose that runs to the drip tray. the back cover comes off you can then get at the hose
Posted on Dec 14, 2007
SOURCE: GE top freezer ice maker leak
I have the same problem -
Posted on Aug 11, 2008
  • 219 Answers
SOURCE: ge profile water/ice fridge side under bottom drawer
take out the back panel in frzzer side use a steamer to clean out your drain hole
Posted on Mar 19, 2009
  • 531 Answers
SOURCE: 16 month old GE Profile
see if the back wall inside of freezer have ice if so you have to change tiker board or check your doors if closing
Posted on Mar 31, 2009
  • 2699 Answers
SOURCE: GE Profile PSS26PSTB refrigerator ice melts inside icemaker
when you open the freezer door do you hear the fan blowing,you could have a bad evap fan motor,also if there's ice on the back wall you have a defrost problem,take off the inside back wall of the freezer where the ice is,you need to shut the control off and melt out all the ice,g.e. has had alot of problems with their computer boards which is a very expensive part number WR49X10152 around 200 bucks,look behind the kick plate on the bottom of the fridge and hopefully the tech sheet will be there,it will tell you how to put the machine into defrost,do this first before you melt anything out or before you touch the control,i think you click the lite switches together 5 times to make it go into defrost,it should tell you on the tech sheet,if ithe heater doesn't come on you need to read out the heater with a meter to see if it's good also read out the defrost thermostat,you have to check the thermostat while it's cold if the t-stat warms up you won't be able to check it, you should change out the t-stat anyway so you can cut the wires going to the t-stat,bypass it by connecting the wire directly to the heater and click the lite switches 5 times and the heater should come on,if it does leave the heater on to help you melt it out.so if the fan is running on the freezer side,click the lite switches 5 times and the fan should shut off and then you'll know it's in defrost,the heater should come on ,if the heater and t-stat read good and it won't go into defrost then it 's the board,also you can take out the board in the back of fridge ,unplug it first and look at the board for burn marks on the back or on the soldered spots,the board tells it when to go into defrost and melt the ice off the coil and like i said g.e.has had a lot of problems with the board,if you need any more help let me know,good luck
Posted on Mar 24, 2010
How can I stop my icemaker from making a block of ice? At the front of the ice bin, a block of ice is forming as though wateer is drippping into the bin.
Open the freezer and remove the ice bucket. You should now see the tray were the ice cubes freeze, check to see if it is fractured or leaking and the position of the water outlet pipe to the ice tray. If the water pipe is firing water out of the tray just readjust it.
hope this helps you.
Jun 23, 2010 | GE Profile PSW26P Stainless Steel Side by...
We have a ge profile refrigerator and there is water leaking on the left side under the freezer. The inside of the ice tray has tan colored gunk on the ice and the bottom shelf of the freezer has a 1/2 in...
manually derfrost fridge/freezer,clean with bicarb only...... dry as best you can.(important) clean drain hose fill freezer from top with any spare space filled with foam in plastic bag(s)looks awful but works a treat (cheap too)invest in a freezer thermometer minus 20C IS BEST.....
Feb 07, 2010 | GE Profile 20.7 cu. ft. CustomStyle...
Psc25mstass freezer not cooling
I had a problem where the temperatures in both refrig and freezer wouls fluctuate. Would not geep ice cream frrozen in top of freezer but temp gauge would read 0. Even stranger would have stalagtites forming from the top shelves in the freeser (big ones). Still under extended warantee so tech replaced the mother board and iit is functioning well now.
Sep 30, 2009 | GE Profile Arctica 25.4 Cubic Feet...
GE Profile Side by side- lines from custom cool covered with ice
I can't give you a solution but I can tell you that we have exactly the same situation. The freezer seems to work but we come back and water has dripped from the ice holder and formed a classic stalagtite (or is it a stalagmite?) Obviously something has melted. We have also found items in the freezer melted - yet the digital readout said it was 3 degrees! Arghhhhh. Glenn in Delaware
Apr 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maler water leaking
Found that ice had accumulatd in the refill cup that prevented the water from filling the mold so that it spilled over into the frezzer compartment
Mar 25, 2009 | GE Refrigerators
Our ge profile is leaking water above the icemaker, help
Sounds like the inlet water valve for the icemaker is not shutting off 100%. That would result in either A.) a block of ice plugging the tube where the water passes through from the outside of the freezer into the freezer compartment, or B.) an ice waterfall in the freezer into the ice bin and/or down the back wall of the freezer compartment.
Solution to either: replace water valve and remove ice with the aid of a hair blower.
Sep 01, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leaking - GE Profile Refrigerator, Model: TPX21PRX
Check to see if the drain at the bottom of your freezer is plugged. When the refrigerator goes on defrost, the water has to go somewhere. Look below the coils in the freezer section and see if there is ice in the drain.
Jul 15, 2008 | GE Profile 20.7 cu. ft. CustomStyle...
Leaking water
In back of the refrigerator behind a removable panel you will find a hose going into the drain pan under the refrigerator. Check and make sure there is no obstruction in the hose which would back up water into the freezer. After the drain hose is cleared the freezer should be defrosted and ice cleared from the drain area in the back. You can direct some hot water with some bleach in it through the drain to insure it flows into the pan.
Jun 15, 2008 | GE Profile PSW26P Stainless Steel Side by...
Sep 05, 2007 | GE GSS25JEMWW Side by Side
GE Profile  PSS26PSTSS Stainless Steel Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
