Question about Sangean RCR-22 Clock Radio
Standby button Where is standby button to turn off nap?
I got a used LCD1932 Lloyd's TV/Monitor. The top has a standby button, turns it on, but u hit same button to turn it off, it has red standby light that stays on, does that mean it's always on standby
It's normal; if the set do not show a screen at this time. The red light indicates that the set is in standby mode, and it will off, when you hit the standby button again, and the scree will get live.
Oct 15, 2014 | Televison & Video
Tip
Digilogic DVDVCR2 Region Free Code Would you like your Digilogic DVDVCR2 to be...
Would you like your Digilogic DVDVCR2 to be region-free and play all DVDs? Here are the steps to make your Digilogic DVDVCR2 region free:
  1. Press the Standby button on your remote control to place the unit into Standby
  2. Press the Standby button on your remote control to turn on the unit
  3. Press the Open/Close button on your remote control to open the drive tray
  4. Press the Clear button on your remote control
  5. Press the 1 button on your remote control
  6. Press the 3 button on your remote control
  7. Press the 6 button on your remote control
  8. Press the 9 button on your remote control
  9. Press the 0 button on your remote control
  10. Press the Open/Close button on your remote control to close the drive tray
  11. Press the Standby button on your remote control to place the unit into Standby
  12. Press the Standby button on your remote control to turn on the unit
Your DVD / VCR combo is now region free.
__________________________
Is your Digilogic DVDVCR2 locked in SAFE mode? View my other Digilogic tip to unlock SAFE mode.
on Apr 07, 2010 | Televison & Video
Receiver stays on stand by
Turning On and Standby
On the AV receiver, press the [ON/STANDBY] button.
On the remote controller, press the [RECEIVER] button, followed by the
The AV receiver comes on, the display lights up, and the STANDBY indicator goes off.
To turn the AV receiver off, press the [ON/STANDBY] button, or press the remote
controller's [ON/STANDBY] button. The AV receiver will enter Standby mode.
If you have any trouble using the receiver, a simple reset could solve your problem.Note that resetting the AV receiver will delete your radio presets and custom settings.
To reset the AV receiver to its factory defaults, turn it on and, while holding down the [VCR/DVR] button, press the [ON/STANDBY] button. "Clear" will appear on the display and the AV receiver will enter Standby mode.
Hope you are satisfied with my solution.Your valuable feedback would be appreciated.Thanks for choosing Fixya.
TinuAlbinAlex
Jun 15, 2011 | Onkyo TX-SR307 A/V Receiver
The "on" light is always green, even if turned off. Why?
It occurs when your wii in the Standby, but WiiConnect24 is enabled with Standby Connection is enabled. the content can also be received when the Wii is left in standby mode.
WiiConnect24 can be turned on or off via the setup setting. While the console is in standby, the power LED indicates the current status of the standby connection,
  • Red indicating Standby - wiiConnect is off,
  • Yellow indicating Standby - Connect mode is on. If you hold the power button for 3-4 seconds, the Wii goes into standby mode with Standby Connect off. and WiiConnect24 will not operate until the console is turned on.
  • Green ...
Jan 18, 2010 | Nintendo Wii Console
Service menu
How to Enter Service Mode
1. Turn on the main power switch to place this set in standby
mode. (LED will light in red.)
2. Press the buttons on the commander as follows, and enter
service mode.
PRESS these buttons in sequence
ON SCREEN DISPLAY---> (DIGIT 5) ---> (VOLUME +) --->STANDBY
Method of Cancellation from Service Mode
1. Set the standby mode (Press “ (TV STANDBY)” button
on the commander), then press “ (TV STANDBY)” button
again, hereupon it becomes TV mode.
Thanks
Oct 29, 2008 | Sony KP-53HS30 53" Rear Projection...
Unlocking my DVD Player
Try this,it should work....Rod
To change the current region setting on this player
Jul 16, 2008 | Durabrand Televison & Video
Satellite A10
you have to enable it in the power options in control panel!
There is a standby option the enable it
Feb 13, 2008 | Toshiba Satellite A105 Notebook
DVD player stuck in standby mode
Bad caps in the power supply is causing this. C17 (10v,470uf), C17,c14 (10v,1000uf) and C18 (10v,470uf). Replace with same capacitance values but 25 volt rating 85 C. Just fixed mine half hour ago works great.
May 27, 2007 | Onkyo DV-CP500 Multi-disc DVD Player
Sangean RCR-22 Clock Radio Logo
41 people viewed this question
Top Sangean Audio Players & Recorders Experts
Mark Schmit
Mark Schmit
Are you a Sangean Audio Player and Recorder Expert? Answer questions, earn points and help others
