Question about Freezers
Rs261mdrs I changed the water filter on my fridge and when I install the new one, water will not come out. I put the old one back in, and water won't out of it anymore either. Water will come out when the filters are not in. I held down the dispenser for almost 30 minutes to clear air out of the line, but to no avail. It was working fine till I tried to change the filter--Any ideas on what the problem could be? Thanks-Kate
    Master:
  • 481 Answers
Need to verify that the water solenoids valve is getting energized and opening
Posted on Jul 24, 2017
Master_Tech
  • 770 Answers
SOURCE: Water pours down the back(Internally) ofmy Liebherr Frost Free Fridge freezer.
It is most likely a broken water tank in back wall of refrigerator section remove the crisper drawers you will see the tank it holds about 1.5 gal of water to keep it chilled for the dispenser. check all around it with the water on and someone getting water out of the dispenser at the same time check the seams closely. you should find the leak there let me know if not we may have to look into the water inlet valve
Posted on Feb 12, 2008
SOURCE: samsung water filter rs21 dcns
Hold down the "ice type" and "child lock" buttons (bottom button on the left and the right) together for about three seconds. The light will change back to green.
Posted on Oct 12, 2008
  • 63 Answers
SOURCE: Frigidaire won't make ice & dispenses only about 4 oz. cold water
Water frozen in the freezer supply line - you need to thaw out the freezer. About six hours, door open, turn freezer OFF. You'll need a cooler with dry ice for your frozen food. 99% certain it'll work after that.
Posted on May 26, 2009
SOURCE: LG LRSC26923TT, water dispenser not working
I have a LG GRP207TUJA side by side freezer, which has a water,ice,crushed ice dispenser. There is a button to select which mode of dispenser. The freezer just appears to be cycling through all the selections all by itself and make the bleeping noise as it moves from one selection to another...any ideas
Posted on Feb 10, 2010
  • 153 Answers
SOURCE: gsh25jfta bb GE refrigerator stopped dispensing
Water line in door frozen.
Posted on Feb 17, 2010
I would like to not use the filter.do i need a bypass plug to water filter on ffhb2740ps ?
Yes, you can get them on Amazon. for around $ 17.00 get the number off the filter before ordering one or two as the case maybe
Aug 26, 2014 | Frigidaire FFHB2740PP 26.7 cu. ft. French...
Samsung french door refrigerator wont disense water after replacing water filter
Put the old one back in and if water works, then the new filter is blocked. Buy another filter.......
Jan 11, 2014 | Samsung RF4267HARS 27 cu.ft. French Door...
Water flows very slow out of the dispenser on my samsung refrigerator
Try replacing the filter again, If it works again then you might want to think about putting some sort of water softener system in your home
Dec 08, 2013 | Samsung 26.0 cu. ft. French-Door Bottom...
How to chage the water filter
Shut off water supply first. I believe you have to prep the filter in water prior to installing. Follow those instructions. When you take the filter off, simply be careful as you unscrew the holding mechanism and put the new one on just reverse of how you took off the old one.
Jan 22, 2013 | Hoshizaki Freezer Commercial Ice Machines...
My Maytag side by side with water dispenser and ice maker doesn't work. We bought a house - never lived in - and the fridge and freezer work fine. We replaced the water filter and find that no water comes...
The sadle valve is located on the copper pipe where the tube attaches to your water pipe in the house. Shut the water off at the saddle valve. Remove the hose from the rear of the frig on the water inlet valve and put it into a pail. Tunr the water on at the saddle valve and see how fast the water comes out. Some times if the saddle valve is installed on the bottom of the copper pipe they will get corrosive and restrict water flow. Open and close the valve several times to make sure it is clear and reinstall the hose to the rear of the frig. Turn the water back on to see if it works.
Dec 29, 2009 | Freezers
Orange light in the shape of a leaking bucket. Side by side fridge/freezer with ice maker and water dispenser
I think you are referring to the water filter alarm. When it first starts coming in, you only notice it when you blink. As time passes, the color becomes more pronounced....If this is right, we'll move on from here, if not, please re-post, and please don't mention the village idiot (me).
The alarm can come on if a high differential pressure is sensed across the filter, or it can come on at pre-programmed times. If the fridge is relatively new, and the quality of the water is good, you can reset the alarm. On my model, I hold down the "ice type" and "child lock" buttons for about 5 seconds. The actual filter is located in the fridge, on the upper right hand side. These filters are somewhat expensive. I say that to say this....You can extend the life of your filter by installing an in-line filter between the wall water valve and the back of the fridge. This will act as a pre-filter for the Samsung filter. They cost usually about a quarter of the cost of the Samsung filters, and are easily replaced. Should you decide to replace your filter, Ebay is a very good source at a less than retail price.
Hope this was what you needed...regards --W/D-- Please feel free to rate this solution!
Jul 28, 2009 | Freezers
Q: Does the water for the ice maker go thru the in-fridge filter?
the water should go thru the filter first then to everything else.
Jan 02, 2009 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Samsung water filter rs21 dcns
Aug 06, 2008 | Freezers
Poor tasting Ice
There could be a filter installed. The filter usually looks like a long tube about 6-10" long and about 1-3" round.
Try to located the water line. This will be either a copper or plastic tube about 1/4" diameter and will be going into your fridge from the back of the unit.
The filter could also be located at the point of where the water is being supplied from. Possibly under your sink or it could of been tapped into another line in the basement if you have one.
If you located a filter, you will be able to see if you would be able to remove it and replace it on your own. It usually takes a couple of wrenches, but MAKE SURE YOU SHUT THE WATER SUPPLY OFF FIRST before attempting to remove it or else you might have to go swimming. (Actually it's a small tube, so not a lot of water will come out, but you still need to shut off the water supply to the fridge. Then you can bring the old filter into your local hardware store and get a replacement.
I hope this helps.
Good luck.
Mac =)
Mar 20, 2008 | Freezers
Freezers Logo
258 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
