Splendide comb o matic 6000 lwd 1054 m
Clothes do not dry as they should
gittos73
  • 244 Answers
SOURCE: Hello, I had an issue with the door opening on my Comb O Matic 6200
no most washers you can open the door by 1st unplugging it take the lid off now place your hand flat move it down on the inside of the washer the side that your door catch is situated now when you feel the interlock if you fiddle around with your fingers you will be able to open it some have a cable going to the inside of your interlock pull on this and that will open the door just got it have patience while you fiddle with it you will get it may take a few minutes but it will happen
Posted on Sep 24, 2007
SOURCE: Splendide 2100 no longer dries clothes
We had the same problem with our splendide 2100 top loader. If you remove the top cover, you will find 2 circular like black discs (the size of a dime) on the right hand side about 6 inches from the front. You need to push those down (with a very small blunt object) to reset them. Please make sure that you unplug your washer/dryer before you attempt this. Good luck.
Posted on Nov 01, 2008
  • 3 Answers
SOURCE: Splendide Comb-o-matic 2000 how do you vent it to the outside
Use 2.5" plastic pipe & elbow to replace aluminum elbow & hose with spring inside. Air velocity is higher, lint blows out without collecting.
I used wood router to remove part of exhaust connector on rear of dryer to better fit elbow. Elbow interior was smoothed to prevent lint sticking. Elbow was mounted with silicone sealant and 2 screws. Pipe was glued to elbow as normal glued pipe connection. Pipe end was cut even with side of dryer.
After Spendide was installed in RV, a union was stuck in from outside RV. Union slides on to pipe without sealant so Splendide can be removed from RV. Union better fills outside vent fitting than bare 2.5" plastic pipe. Temporary seal aroung union was made of urethane foam scraps, common shipping stuff from a computer monitor box. After 2 years of temporary, the foam is now considered permanent.
Original problem was constant lint problems in hose and slow drying. With pipe, not hose, lint is rarely cleaned and drying is much faster.
Posted on Jan 28, 2009
  • 864 Answers
SOURCE: Doesn't completely dry clothing
Make sure lint filter is clean and vent pipe and outlet are not clogged.  If the clothes are getting warm then the element is working.
Posted on May 30, 2009
SOURCE: My motor yacht's Splendide Washer Dryer combo has
Thor Appliances - www.thorappliances.com - and LG both have machines that can replace the Splendide.
Posted on Aug 05, 2010
Hi I am looking for splendida combo 6200 handle part. do you have it for sale?
www.splendide.com
1-800-356-0766 #5 (503-656-2280)
503-722-9202
service@westlandsales.com
Monday-Friday, 7:00am - 4:30pm (PST)
for parts and service.
Sep 09, 2010 | Splendide Comb-O-matic 6200 Non-Vented...
My motor yacht's Splendide Washer Dryer combo has nerver dryed the clothes
Aug 04, 2010 | Splendide Comb-O-matic 6200 Non-Vented...
Will not dry. On the dry cycle the cloths get
check lint trap if plugged clean it maybe vent is plugged.
Dec 21, 2009 | Splendide Comb-O-matic 6200 Non-Vented...
Reset
Unplug for 40 minutes to reset the ECU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | Splendide Comb-O-matic 6200 Non-Vented...
Need power button for Splendide Combination Washer & Condenser Dryer, model WDC1025MCEE or 6000
Try these sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Apr 02, 2009 | Splendide Comb-O-matic 6200 Non-Vented...
Need operating manual for Bendix WDC1025 Washer dryer combonation
This is the same machine or nearly identical machine as the Splendide Comb-o-matic 6100, for which you can find the manual here:
http://splendide.com/request_manual.htm
Mar 31, 2009 | Dryers
Dec 26, 2008 | Splendide 2100 Vented Washer-Dryer
WDB1043M Bendix Washer/Dryer
I had the same problem. Then I discovered that the Bendix USA WDS1043 / WDC1024 is the same, or almost the same, as a Splendide Comb-o-matic 6000. You can find an extensive parts manual at
http://www.splendide.com/service/Combo_PartsBreakDown.pdf
and an owners manual at http://www.splendide.com/manual_wdc1024m.pdf
I think Splendide is still in business, in which case they may also be able to supply parts for the Bendix WDS 1043 M - check them out at
They can also supply a replacement washer/dryer combo when your present unit finally dies.
Good luck with a great washer combo!
Colin
Jul 28, 2008 | Tricity Bendix WDR1040W Front Load Washer...
Sep 24, 2007 | Splendide Comb-O-matic 6200 Non-Vented...
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
