My wascomat washer has error code 01e - Washing Machines
4 Suggested Answers
SOURCE: error code 10E and 01E
Code 01E: Water level becomes too high;
Code 10E: The drain is clogged, or the drain pump is blocked/defect.
Possible solutions:
- Check if the drain is blocked with something, and clean it;
- Check if the drain pump works, replace it (if necessary);
- Replace the Water Level Control unit.
Posted on Feb 12, 2010
SOURCE: what is meaning of error motor shortening in wascomat washer
change the inverter
Posted on Jan 22, 2011
  • 19 Answers
SOURCE: My wascomat washer W125 every thing run good exception it not spin itself . Every begin time cycle spin I have to push the button on overload protect then it spin.
try replacing your timer on it
Posted on Oct 05, 2012
Testimonial: "Thank your solution . I replaced all component . I found problem in coil start of electric motor. Motor need rebuilding . Please help me where can repair motor. "
Dryer shows error 8-overheating in or out air. I run thru the reset sequence but it continues to show the error code.
Your thermocouple is reading high, which could be a multitude of factors. We'll go through them from easy to hard:
First, check your dryer vents and make sure they are clean and that you have proper air flow coming in and out of the dryer.
Next, make sure that your motors in your dryer aren't running too hard (check for how easy it is to rotate the drum and the fans when the dryer is off).
If you're still facing problems, try cleaning your heating element, and finally replace the temperature sensor. If none of those things work, you're facing an internal computer issue which isn't likely user serviceable.
Nov 02, 2015 | Wascomat Parts Wascomat 986918 Washer...
Wascomat w655s what is error code E13 ?
www.teetersproducts.com/.../Used%20Equipment/.../Wascomat%20-%20...
Jul 13, 2014 | Wascomat Parts Wascomat 973957 Washer...
Wascomat W-125
Search craigslist, ebay, and google the part number to try and find a used replacement part. Search for refurbished electronic control boards companies online.
Feb 07, 2014 | Wascomat Parts Wascomat 990251...
Wascomat dryer error codes
Check the following link: http://www.laundrynation.com/manuals/wp-content/uploads/2011/05/wascomat_dryer_selecta_control_programming_manual.pdf
On page 13 it identifies the E 08 error as overheating air (inlet or outlet). Chances are, it is the outlet that has gotten gunked up from lint or other material. Pull the vent tube off, vacuum out lint traps, clean the outlet tube, reset the machine. If the dryer is linked with other dryers on a multiple-link vent system, cleaning the vent lines may be necessary to avoid the problem.
Feb 06, 2014 | Dryers
Got a exsm680cl washer and it reads error drain not draining
Check the leveling of the machine, if not use a spirit level and use rubber sheets to keep it firm. If the drain hose is detached the water must freely flow out in this case. If not adjust the slope.
Also check the drain pump to open and work with good action. If not you need to remove and clean the filter and reset the pump
Jan 21, 2013 | Wascomat Parts Wascomat 432 251902 Washer...
What do I do when error code reads E 15 . Dryer runs for a few seconds than shuts down. I've tested micro switch and i'ts fine.
Post some pictures of your pilot assembly. I think this might be one of them spark sensor deals where the pilot lights and then detects flame then relays that back to the control for igniton verification. OR just try and clean up the electrode with steel wool and see if the flames stays lit is what I would try.
Jan 07, 2013 | Wascomat Parts Wascomat 231754 Dryer...
Error code 10E and 01E
Possible solutions:
Feb 22, 2009 | Electrolux EW1000i Front Load Washer
Washing Machines Logo
184 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
