Question about Lorex Home Security
Why do my lorex cameras intermittently black out?
I have 7 of 8 channels on my Lorex system being used and each one blacks out intermittently at random times (a couple times per day for about 10 minutes). The cables and connections are fine, there is enough power reaching everything, and I have defaulted the DVR settings and reprogrammed everything. Nothing works. Do you have any suggestions upon what to do next?
  • 2,760 Answers
THIS COULD BE A FEW THINGS I CAN THINK OF
1ST ARE CAMERAS WIRELESS ? IF SO SOMETHING COULD COME ON INTERMITTANTLY AND BLOCK SIGNAL FROM GETTING TO BASE UNIT, IF THIS IS SO ONLY A SPECTRUM ANALIZER WILL BE ABLE TO TELL YOU WHAT IT IS .
SECOND IF NOT WIRELESS CK YOUR RECORD SETTINGS IN SETUP YOU MIGHT BE OVER TASKING HD DRIVE , VIDEO CAPTURE ONCE PER SECOND IS NORMAL ANY FASTER IS NOT NEEDED UNIT WON'T HOLD VIDEO IF HD IS BUSY WRITING SO IT DROPS SECONDS OFF FINAL RECORD
Posted on Dec 05, 2014
2 Suggested Answers
  • 3 Answers
SOURCE: cant access lorex DVR from the internet
i have the same trouble, and i did what u said and it doesn`t work yet:S something else????
Posted on Jul 31, 2009
With is nvr security
NVR = Network Video Recorder.
HD NVR camera systems - Lorex
https://www.lorextechnology.com/hd-nvr-camera-system/N-p3cgve
  1. Cached
Rating: 8.7/10 - ‎2,276 reviews Results 1 - 21 of 42 - Security cameras systems with HD NVR. ... Lorex HD NVR security camera systems provide stunning 4K,2K and1080p video that leaves nothing to the imagination. ... For crystal clear HD video quality that you can view from anywhere in the world, stay connected with a Lorex HD NVR camera system ...
HD IP NVR Systems ' Costco - Costco Wholesale
https://www.costco.ca/hd-ip-nvr-systems.html
  1. Cached
Find a great collection of HD IP NVR Systems at Costco. Enjoy low warehouse prices on ... Electronics · Surveillance & Security Systems. HD IP NVR Systems.
Surveillance Security Systems - Newegg.ca
https://www.newegg.ca/Surveillance-Security-Systems/SubCategory/ID-693
  1. Cached
LaView LV-KNT982A42W4 4 MP zoom HD 8 Channel NVR PoE IP Security System, with 2pcs 4 MP (2688 x 1520) and 2pcs 2 MP (1920 x 1080) Bullet Camera ...
Jul 13, 2017 | Home Security
Lorex SG 6157 need to know what the four wires go to blue black re yellow
Red & Black are PRETTY MUCH always the Transformer Pwr (12v delivered: (9V DC working...Red is positive)).
So the video should be your yellow & blue/
(I thought green (but what do I know)).
ImageSensor:1/3"ColorCMOS, VideoFormat:PAL, EffectivePixels:628Hx582V Resolution:330TVLines-SyncSystem:Internal, AES:1/50~1/1500Sec Min.Illumination:2Lux, Lens:6mmF1.8, ViewingAngle:Diagonal53? OperatingVoltage:9VDC, OperatingTemperature:-10~45degreeC Dimension(WxDxH):53x80x49mm, EnvironmentalRating:IP44
I have every confidence your cables are going someplace EVEN MORE COMPLEX you have not even mentioned. You really need to share that BEFORE DEFINATIVE answers can be given abort ONE end of your cable.
The primary question
Are you using Philips/BNC (cannon-PWR)/ connectors or the RJ45 type... using individual power transformers or Power Distribution panel... Direct to a video screen (TV monitor).. or a NVR real-time matrix... or DVR recording system
Comment back if you are serious with configuration information... If I don't know your answer straight away I can get you pointed in the right direction.
Required Pin-out, nvr, dvr, resolution, compression, remote, IP
lorex sg6157 wire pinout Bing images
Lorex SG6157P Specifications
Jan 14, 2015 | Lorex SG6157 Indoor/Outdoor Color Camera...
How do you monitor only 2 channels at a time on a lorex securtiy system ?
that can't be happen because all CCTV system dvr or nvr just split into 1/4/9/16 camera
Jun 13, 2014 | Lorex Home Security
Lorex stratus time is not correct
try to change dc battery on the main board of DVR
Apr 09, 2014 | Lorex LNR300 Series 8-Channel, 4-Camera...
Precor 9.23 Treadmill Inclines Randomly
most prob one of sensor / connection gone bad
Mar 30, 2014 | Precor 9.23 Treadmill
Printer intermittently goes offline, will come back at random. Restart does not bring it back online. It will come back online at random, no set period of time. May be online for days, or off for days. I...
I suggest that you investigate the router. You did not specify how the printer was connected, often wireless is an issue, if you are wireless, change the channel to 11. Many land line cordless phones, with the extended range, interfere on most router default channels.
The restart of the router is a pretty large clue, also connections in and out are suspect.
Feb 12, 2011 | Computers & Internet
What is the total WATT output on the Sony MHC-G101 mini hi-fi 3 CD changer, dual cassette home component system? I misplaced the owner's manual, and I want to know how much power it has. // Tks
According to page 24 of the manual, it delivers 11 Watts RMS (route mean squared) per channel into 8 ohm speakers.
Elsewhere in the manual, you'll see references to "15 watts per channel" and as much as "25 watts per channel". The 15 watt value is valid when putting up with some 10% THD (total harmonic distortion), this value is 11 times higher than the .9% THD value given for 11 watts per channel. You tolerate .9% THD now, but you wouldn't want to listen to anything with 10% THD. The 25 watts per channel is what they call "Music Power". Watts is an electrical term, "music power" is not. You could use it to compare other devices that only offer "music power" values, but the best indication of how it will perform is based on watts in RMS, into an 8 Ohm load (most speakers are 8 ohms). The lowest THD values are best.
From the manual:
AUDIO POWER SPECIFICATIONS
POWER OUTPUT AND TOTAL HARMONIC
DISTORTION:
With 8 ohm loads, both channels driven, from
70 - 20,000 Hz; rated 11 watts per channel
minimum RMS power, with no more than
0.9% total harmonic distortion from 250
milliwatts to rated output.
I hope this helped!
Nov 23, 2010 | Sony MHC-G101 Shelf System
NEED USER MANUAL FOR LOREX 4CH MPEG 4DVR
Check the exact model of the dvr and get your manual here
Cheers
TeaCii
If you own website, addlive support almost free
Realsecurity guard to watch your cctv for $1/day
Apr 12, 2010 | Lorex 4 Channel Home Surveillance System
Simulate the Shortest Job First CPU scheduling algorithm
Nice try! Find an upper-class student to give you one-on-one tutoring for your homework.
Jan 14, 2009 | Computers & Internet
Home Security Logo
235 people viewed this question
Top Lorex Home Security Experts
Henry  Thomas
Henry Thomas
Lawrence Oravetz
Are you a Lorex Home Security Expert? Answer questions, earn points and help others
