Question about Cooktops
Harper wyman kool lite # 6520 where do I find a replacement?
2 Suggested Answers
  • 10865 Answers
SOURCE: Hi, I need to find
Hello. Generally, the best local source for LP gas valves is your LP gas provider, give them a call. Also, there are several other sources including http://www.kitchenstuff.com/items.asp?Cc=HS1077, and local plumbing supply houses. J.
Posted on Jul 09, 2010
How do I replace the jgp636 igniter switch?
How do I lite a whirlpool electric gas stove?
Dec 31, 2012 | GE Profile JGP636 Gas Cooktop
My Viking Range top has 4 burners and the automatic ignition on the left two burners do not wok. Can hear clicks and gas but no ignition. Can manually lite them. Any ideas?
Sorry to read about your problem, I hope this helps you out.
your lite tube may be clogged, or take a needle and clean the hole's next to the lite tube on the range grills..
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 19, 2010 | Viking Cooktops
My ge monogram stove top burner( model zgu366h)continues to ignite. even after the flame is lit
If you are saying the clicking continues you must move the burner knob past the LITE position.
If it continues clicking with the knob past the LITE position the ignitor switch behind the knob is bad.
Nov 30, 2010 | GE Cooktops
Hi, I need to find a place to purchase a Harper-Wyman model 5853 LP gas valve. Thank you. Dave
Jul 09, 2010 | Magic Chef 30 in. 8241RT Gas Cooktop
Looking for a manual for Russell Range cooktop Model #SFC-36-6.
I have the same Cook Top RUSSELL RANGE 36-6 with a defective spark Module. part # kool lite 6521
I found the owner in SAN FRANCISCO Russell Zipkin
Now under SELECT APPLIANCES 1 888 235 0431
They were of no help at all.
Feb 26, 2010 | Cooktops
Magic chef rv oven burners work fine oven pilot hard to get lit and when it does lite the oven burner will not lite can you help me
thromo stat bad the tempature knob has a gas valve attached to it along with two gas lines you will have to remove the oven to acess all lines as they run on the backside of the case remove the burners and gas input line copper line remove gas supply tube to all burners remove valve and take to dealer they need the numbers off the vavle for exact repacement not just the numbers off the stove itself east fix with simpl hand tools thermost has a themocouple attached to burner assembly and this is your problem bad part is themocouple is built into thermostat and is no serviceable only fix is to replace "thermostic gas valve"
Apr 08, 2009 | Magic Chef 30 in. 8241RT Gas Cooktop
Clicks occur in "low" position instead of "lite" position
Sounds like the switch electric sending unit needs to be Ither cleaned and dry good or replced. It's not hard at all, They are located under the knob switches, you will have to remove the knobs and the top cover, they look like a small square box wit a hole in the middle with two wires on the sides, just unplug the wires and lift the box off the switch rod. cleane them and dry them good and put them back.......that should do it.....Good Luck
Eddie Rentas
Tupper LAke NY
Jul 16, 2008 | Cooktops
Hot surface indicator lights
go to cheapapplianceparts.com. The replacement light kit is there.
Nov 22, 2007 | Jenn-Air 30 in. CCE3401 Electric Cooktop
All burners won't ignite when knob turn to LITE
how lite a eletric gas oven when power lite dont work
Jul 03, 2007 | Whirlpool GLT3014 Gas Cooktop
Cooktops Logo
439 people viewed this question
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
