Question about RCA HD52W56 52" Rear Projection HDTV
Tv volume can't hear anything
    Top Expert:
  • RCA Master
  • 75,276 Answers
Check its speaker first. If found OK, check and replace damaged component/s at its audio output section circuit. If you are not sound in electronics, contact any service technician.
Posted on Jul 13, 2013
I can not hear the sound on my Sylvania tv.
is it only with the xbox? how did you hook it up/
Feb 18, 2015 | Sylvania Televison & Video
My tv volume is on 100, however, you still can't hear it
first is turn it down to a lower level:
look to see if sound with a DVD connected to a rear input.
look in menu to see if speakers are switched to OFF.
look also if set has external speaker hookup set not set to external.
failing you have a audio circuit problem in the TV.
Nov 06, 2012 | Magnavox 26" LCD TV with Built-in DVD...
Volume isn't working
unplug the tv for a couple of minutes and plug it back in it will reset it...thats worked for most people.
Sep 11, 2012 | Spectra Logic Hello Kitty 13" TV
Cell phone speaker for ear doesn't work but speaker phone does.
Make sure all the volume is up. If you sill don't hear anything, speaker or wires might be faulty. Needs servicing.
Jan 29, 2012 | LG Cell Phones
I have a sharp tv with the volume at its highest but i can't hear anything
Hello
Check its speaker first. If voice coil of the speaker or tis cone paper has damaged, speaker will produce a dull low sound output. If the speaker is found OK, check the audio output section of the unit. This section circuits can be located inside the TV circuit board. look for any loose or bad soldering terminals at the audio output IC. It is best to resolder all the suspected solder points by applying a little more solder, withut making any solder bridge short in between adjecent solder terminals. If this also does not help you, replace the audio output IC. It is damaged. OK.
Dec 26, 2011 | Sharp 13VT-R100 13 in. TV/VCR Combo
Low volume on my panosonic
If you are using a cable box or other device upstream, look into it's volume. Typically source units would like to be 30 to to% volume, with the tv or stereo being the final control. What happens is the source volume gets turned too low, and then the final unit (tv or stereo) has to have so much volume to hear anything, distortion and poor sound result. Start with both midway and you should be good to go.
This presumes that you toggled any buttons that said mute or attenuate...
Oct 26, 2011 | Panasonic TCP42C2 42 in TV
Have to turn the tv up to 100 to hear but it works fine when playing a dvd
When your watching tv you must be using a cable box or a pvr that has it's own volume control. Make sure it's volume is at it's max and then use only the volume of the tv.
Jul 06, 2011 | Daewoo Televison & Video
I have a pioneer vsx 517 receiver. The volume on the fm setting plays just fine but when switched to tv sat i have to turn the volume all the way up to hear anything. It work fine before. just trying to...
That would depend on where the (unidentified) TV audio comes FROM. If it's the analog output of the TV, the TV has a volume control hidden somwhere in a menu. Or you could select the FIXED output so its volume control has no effect on external use of the audio.
If the TV audio comes from a Cable Box analog output, IT might also have a control that varies the volume out. Disable it.
Jun 29, 2011 | Audio Players & Recorders
I can't hear anything when I plug in the headphones in the headphone output in the back, I can only hear something when I turn the volume up to 100, but still, what I can hear is very low... Please...
Check the impedance of your headphone, which should match with the specified impedance in the user manual. The impedance of your headphone is very high.
sonsunny
Jun 16, 2011 | Samsung B2230HD LCD TV
There is no volume coming from my RCA television
chick the speaker, if the speaker working. try to replace sound ic
Jul 10, 2007 | RCA 32V420T 32" TV
RCA HD52W56 52" Rear Projection HDTV Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
