Question about Actiontec (GT704WG) Router
THis router is not working for Voice over phone for ALLVOI ?????
Innoband ADLS2/2+ router
Hi. Sounds like some ports are being blocked on your device firewall. You can typically allow ports 5060 and 13000 to be opened for two-way traffic. You might have to even upgrade the router firmware if its possible and the problem persists. Worst case scenario you might even have to change the router as some routers just won't operate properly, no matter what firmware version is installed on them.
Jul 01, 2014 | Computers & Internet
Transmission problems on cisco 525g2
I beleive the maximum delay is 150ms before voice has issues. If you can plug this phone into a wired connection to validate the phone is working properly that would help isolate the problem.
You may need to setup QoS on the wireless device and router for 802.1q tagging as this is what the voice packets should be tagged as from the phone.
The Qos will assure that voice packets have top priority over all other packets.
If QoS is already set and you have additional phone connected via WiFi I would have to say that you may at your bandwith limit.
An aside note - If you are running pc's through the phone you must have the correct VLAN's and QoS configurations configured for voice and data isolation.
Jan 27, 2013 | Cisco SPA 525G2 5-Line IP Phone with Color...
No dial tone
Hi Richard,
May be your new Router is blocking the ports used by your IP Phone by default. Check with your phone service provider for Voice Port (Mostly SIP or H.323 or SCCP) and open that port in your router.
HTH
-Karthik.
Oct 18, 2012 | Linksys SPA942 IP Phone
Cisco 2851 Voice Bundle - Router - voice. No connectivity, phone, network and internet.
READ AT http://www.cisco.com/en/US/docs/routers/access/1800/1841/software/configuration/guide/b_creg.html
Apr 14, 2012 | Cisco Computers & Internet
My voice mail stopped working since BT changed its IP address. The PC where the Avaya Phone manager is installed is connected to the network through this BT router. How can I restore the Voice...
What was changed? The IP address of the phone system or the IP of the voicemail PC?
You just need to go into manager and change the IP of where the voicemail is in the SYSTEM>VOICMAIL tab.
Mar 23, 2011 | Avaya 5400 Series 5410 Phone
Have setup in this order dsl modem,dir615 router,spa2102 phone adapter,get dial tone,hear ringing when making or receiving calls but no voice,what gives??
incoming voice ports are not open on the router. the devioce uses one IP port to set up the call (ringing) and at least 2 others for audio. read the manual I'm afraid.
Nov 06, 2009 | Computers & Internet
How to connect 2wire 2700 HG-B router to voice modem motorola
that 2wire only works with DSL services, if you are using cable internet then no it wont work. If the surfboard digital voice is just a VOIP router then yes, plug the surfboard into one of the ethernet ports on the back of the 2wire.
Jun 06, 2009 | 2wire 2700HG-B Router (2700HGB)
Can't access voice tab on WRP400
If your wireless VoIP router was provided by your VoIP provider they will usually lock this option on the router since they have pre-configured the voice settings(sip server, phone number, password, codecs) before they deliver the device to your location. if you have a working internet connection already you can give your VoIP proiver a call so that they can remotely check the voice settings on their end to verify if it's working or not.
Nov 24, 2008 | Linksys Wireless-G WRP200 Router
7910 IP Phone
please check if firewall is ON on your netgear router...
Dec 12, 2007 | Cisco 7910 IP Phone
Actiontec (GT704WG) Router Logo
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
