Question about Freezers
How many cubic feet is danby upright freezer fu20w and is it frost free?
3 Suggested Answers
woodchuck789
  • 4059 Answers
SOURCE: Re: danby upright freezer 20.1 cubic ft., model #
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Posted on Oct 13, 2009
  • 73 Answers
SOURCE: I need to know the cubic feet of my upright frost
get a measureing tape measure inside dimensions multiply them together eg: a freezer with an inside dimension of 2' X 2' X 3' would equal 12 cubic feet if want an exact value measure in inches 24" X 24" X 36" = 20736 and divide by 1728 will give you cubic feet cool eh.. where did I get the 1728? (12 X 12 X 12) =1728 converts cubic inches to cubic feet Good Luck let me know when you pour that cement pad for under your shed I tell you how many yards to order
Posted on Oct 23, 2009
Frigidaire frost free contents are thawing
Check your t'stat setting. If it is older than 10 years it is probably the compressor. As cheap as they are now, you would be better off with a new one. Labor and compressor would run an easy 200 dollars. Then you would looking at other things breaking after that.
Jan 29, 2013 | Frigidaire 17 Cu. Ft. Frost Free Upright...
Can you tell me how large (in cubic feet) this freezer is?
Is this a trick question? It is 20.3 cubic feet according to your question. This may be the capacity or the size of gross measurement ... you have not indicated.
Please ask the actual question you want to know ...
Thank you
Mar 22, 2011 | Kenmore Freezer 20.3 cu. ft. Frost Free...
I need to know the cubic feet of my upright frost free frigidare freezer Model # MFU17F36W6
Oct 23, 2009 | Freezers
Oct 13, 2009 | Freezers
Danby upright freezer 1166w top and bottom shelves frosted in none on middle shelf could i have a problem
Probably there's a freon leak (refrigerant) that has to be fixed (remember this is a seal system and shouldn't leak)and then recharged.
Oct 05, 2009 | Danby 4.7 cu. ft. / 133 liter Upright...
Can I put my Danby upright freezer in the garage? - it is not frost free.
It is always best to keep these types of equipment in the 60-80 degree ambient.
Sep 22, 2009 | Danby 16.7 cu. ft. / 473 liter Upright...
How many cubic feet is this freezer
After looking over their website, which is not very helpful, it appears that it would be approximately 5.0 to 5.2 cubic feet. It seems that in most cases, the model number contains the size. Check it out at Danby.com
Hope this helps.
May 18, 2009 | Freezers
We have a 20.3 cubic feet Kenmore upright frost free freezer we purchased in May 2003. We noticed the meat was beginning to thaw one afternoon. We hit the quick freeze button and that seemed to fix the...
This sounds like a bad thermostadt, since the quick freeze button does work. But it should be much colder than 32 degrees. It may also be the motor, since it runs for brief periods of time after plugging it back in.
I'd say best bet here is to call a repairman. (sorry...)
May 10, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Noise Problem
Is it a frost free freezer ? if it is it sounds like the evaporator fan motor making the noise
Aug 29, 2007 | Danby 16.7 cu. ft. / 473 liter Upright...
Freezers Logo
105 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
