Question about Rowenta Krupps& Programmable Coffeemaker (FME2-11)
Krups Looking for a water level indicator. Mine is broken and now water leaks from the area.
Where is the water sensor
There are two of them mounted in the middle of your face one each side of your nose. You observe the water level with them by looking at the water level indicator on the front of the coffeemaker.
Oct 25, 2015 | Krups FME2 Coffee Maker
How do I rest a krups 8200
Probably the magnet that indicates the water level to the electronics inside is not floating any more. Either replace the tank or wedge something plastic underneath the magnet to trick that the tank is always full. You will then need to check water level visually and not wait to be told.
Sep 20, 2014 | Krups Coffee Makers & Espresso Machines
How do I increase water temperature on Krups KP 2100
Heat the cup before you use it, run hot water over it, or boiling water. The machine does not make very hot coffee otherwise.
Sep 22, 2012 | Krups Dolce Gusto KP 2100 Espresso Machine
Water is leaking from the bottom
I was successful at fixing my Krups Electric Kettle for $4. In my case the water was leaking from bottom somewhere close to the heating area. I think that a small hole was created in the seal around the heating area in the bottom of the inside of the kettle. One can try to find the general location of the leak by putting a small amount of water in the kettle, place the kettle in a larger pan, and tilt the kettle so that the water is slightly higher than the heating area in one area only noting the position where the water level is above the heating area. Leave it for a while and check for leakage. If there is none, rotate the kettle a few degrees so that you have a new high point and look again for leakage from the new area until you find the area where it is leaking. Alternatively you may wish to put a sealant around the entire area, 360 degrees, around the top of the heating area. You mayl have to remove the strainer first to get your hand in the kettle to apply the sealant.
I went to my local hardware store and looked for sealants that were:
1. Potable (ie safe since you will be using the water for coffee, tea, and other applications that you ingest).
2. That will withstand heat up to at least 250 degrees Fahrenheit. Remember that water boils at 212 degrees.
I found epoxies that required mixing two compounds but decided that this would be difficult to deal with and apply. In the end I bought "PC Plumbing Epoxy Putty" from PC-Products. This met both requirements and was easy yo use. You take the putty and roll it between your finger just like you did in kindergarten with the clay and make a thin string that you could position in the crevice around the top of the heating area. You may either cover the area where you found the leak or the entire 360 degrees. You will note a somewhat foul smell of the putty. The manufacturers says that it will cure in 3 hours. I found that the smell went away when it completely dried and hardened after 3 weeks!.
I will assume that the same solution is applicable to leaks in other areas of the kettle. I have also found that there are equivalent electric kettles much cheaper than Krups. I would certainly check the construction to see if there is one with less of a chance to develop a leak.
But the bottom line is that it cost me $4. I just finished testing the Electric Kettle and it is fine, not leaking, and the instant coffee did not have any bad smell.
Meir Elazar
Feb 11, 2011 | Braun Kitchen Appliances - Others
The kettle leaks at where teh handle attaches at the bottom
Join the club ---I'm taking ours back this afternoon to BB&B. It's still under warranty and we have the receipt.
Nov 14, 2010 | Krups FLF2 Cordless Electric Kettle
Krups kettle leaks at base of pot
Unfortunately it's unfixable. A few recent Philips models do it as well and it's worst in hard water areas. Basically the cause is that a tiny bit of water gets into the bottom seam each time the kettle is used and leaves a residue behind when it dries out. Over time, the residue builds up and forces the seam apart so the leak gets worse.
All you can realistically do is hope that it's still under warranty and demand that Krups replace it, preferably with a different model. If they won't then you may have to exert whichever consumer rights exist in your country, but one way or another you need to stop using your kettle (it's dangerous!) and replace it with another.
May 21, 2010 | Krups FLF2 Cordless Electric Kettle
Krups electric kettle leaks
You cannot fix it when they split like that.
Apr 01, 2010 | Krups Stainless Steel Electric Kettle...
Krups KM7000 grinds but won't brew, warming plate no heat. Is this repairable, (perhaps a fuse?) or is it junk. Bought the machine in March 2008
Mine had the same problem ... all the lights are on, but no heating on the plate, and no dripping of water.
After a weekend on the workbench, I've mastered this machine. The KM7000 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. I'll be happy to advise you to fix this, or fix it for you. Write me at KM7000@flightsystems.biz.
Oct 30, 2009 | Krups KM7000
Krups fmf 5 water leaks from the bottom of coffee maker
I took the bottom off mine and found that a hose that connected to to the water level tube had become disconnected.
In order to get the bottom off you need a Torx internal tamperproof pin (6 lobe) screwdriver to get the 5 screws out.
Jul 23, 2008 | Krups FMF5-14 Stainless Steel 10-Cup...
Rowenta Krupps& Programmable Coffeemaker (FME2-11) Logo
12 people viewed this question
Top Rowenta Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Rowenta Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
