Question about Garden
Lt 2000 247.288852
I can not figure out what size the flanged nut is to remove my blades. I have the 46 inch deck.
lemmingleejn
  • 173 Answers
SOURCE: need to know what size and hoe to change belt for
If you are missing the manual, for the said model,
I have found that the simplest way, of figuring out the correct route for the belt, is to remove the deck, and hold the replacement belt above the mechanism, with the tension from the engine end.
Then 'mock up' the replacing proceedure, bearing in mind the correct direction the tensioner/s, move in.
Then it's not too difficult to figure it out the correct route.
Hope that's clear enough, good luck.
Posted on Jul 24, 2009
SOURCE: uncut strip in middle of 42 inch deck brand new
My first thought is that the blades are too short. If it cuts everywhere but in the middle, I'm wondering how it could be anything but that.
Charlie
Posted on Aug 14, 2009
mickey813
  • 472 Answers
SOURCE: sears mower 42 inch deck lt 2000 need details for
CAN YOU GET ME YOUR MODLE NUMBER FROME UNDER THE SEAT SEND IT TO 5FIREMAN@LIVE.COM
Posted on Oct 12, 2009
  • 3911 Answers
SOURCE: what size and how many blades do I need for my
Well I guess laying down next to it and taking a look under the mower deck is beyond the question. One could ask about how many teeth the horse has or just look in its mouth. However, I am going to guess 3 blades as 2 blade units usually are 42" cut maximum. Mine is 48" and has 3 blades.
Posted on Mar 24, 2010
farmerbear
  • 490 Answers
SOURCE: I need to know what
It is the same as for the Craftsman 50" deck. The Sears part number is 144959. It's available at a decent price at sears . com. Farmerbear at FixYa.com
Posted on Sep 29, 2010
When taking off the blade for replacement one side of the attachment assembly broke off. i can't figure which nuts/bolts to loosen to remove that part for replacement
The spindle assembly is usually held in place by bolts through the mower deck. The deck will need to be removed from the mower to get to them. There will be three or four of them at the base of the spindle assembly, remove these and the spindle will fall out the bottom
May 15, 2016 | Mtd Garden
What is the correct way to Install New Blades on John Deere G100 with 54"cutting deck
Do Ray:
I pull my machine up so the front tires are on a ramp. make sure the key is out of the ignition. Raise the deck to its top position (every little bit of room to work helps!) I think that the spindle nuts are 1 inch. lodge a two-by-four piece of wood between the tip of the blade that you are removing and the blade deck and remove the nut at the bottom of the blade (make sure you are turning your wrench in the correct direction!) It will take a two-grunt pull to loosen the nut. The blade should fall off when the nut is loosened. Make sure to not put the new blade on upside down! (Use the other two blades for reference). Repeat for the other two blades. Make sure that the blade retention nuts are Very Tight.
Jun 15, 2015 | John Deere Garden
I purchased a used Craftsman LT 1000 17 hp 42"
I've had to do this at least 5 times. If you look under the body, there are two supports that carry the mower deck and lift and lower it. Each of these has a nut that holds up the deck and the nut is on a stud that goes up and down when you raise or lower the lever. Put the deck in the middle of it's range, around #3, make sure the key is off, move your blades so they are on the right and left edge of the deck.
Get yourself a device to measure blade to ground height, I have a block of wood that is 3 inches long. Make sure your floor or ground is level and tires are properly pumped up. Then raise or lower the adjustment nuts until both sides are equal height.
Gary
Jun 14, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I NEED THE SIZE OF THE BLADES OFF A 46 INCH DECK THREE BLADE SYSTEM IT IS A POWER KRAFT LAWN TRACTOR I NEED THE SIZE OF THE LAWN MOWER BLADES
This is a part number.46 inch (three blade) 18 HP TMO 3400005A
MTD makes these mowers.You should be able to use those part numbers to purchase replacements.You can find online at the mtd web site,or Lowe`s and wal mart sell those,or at least some of those parts.
May 12, 2011 | Computers & Internet
Replacing fan clutch
prev.gif next.gif Engine Fan REMOVAL & INSTALLATION Except 5.2L Engines VISCOUS DRIVE FAN
  1. Remove the upper fan shroud bolts and lift the shroud from its lower securing tabs. Fig. 1: Remove the fan shroud 86743p24.jpg
  2. Remove the accessory drive belts.
  3. Remove the fan flange-to-pulley mounting nuts. Fig. 2: Remove the fan flange-to-pulley mounting nuts . . . 86743p25.jpg
    Fig. 3: . . . then remove the fan assembly 86743p26.jpg
  4. Remove the fan and viscous drive as an assembly.
  5. Remove the fan blade-to-viscous drive bolts and separate the assembly. To install:
  6. Position the fan on the viscous drive. Install the bolts and tighten them to 187 inch lbs. (24 Nm).
  7. Position the mounting flange of the viscous drive assembly onto the pulley. Install the nuts and tighten them to 18 ft. lbs. (24 Nm).
  8. Install the accessory drive belts.
  9. Insert the shroud into its retaining tabs and install the upper bolts.
Aug 11, 2010 | 1996 Jeep Grand Cherokee
Sounds like a blade is hitting something on my Cub Cadet LT 1042.
with tractor off and key in pocket check blade for straightness if straight then check by moving it up down if loose check retaining nut if nut tight then possible mandrel bearing burnt or shaft bent also check the mandrels are bolted correctly to deck lastly but least likely is a bent deck
May 09, 2010 | Cub Cadet Street Sign- tractor lawn riding...
What size and how many blades do I need for my husqvarna 21 hp riding mower with a 46 inch deck?
Mar 22, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Need to know what size and hoe to change belt for yardman 46" cutting deck for blade model # 13a0771h055
Jul 18, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
John Deere Lt 166 ride on mower
jd lt 166 has 5 different decks
3 of which have the same belt routing
1st the belt needs to be adjusted correctly to stop it from "slacking off"
then on most decks the belt is routed in between the 2 small idler pulleys and then to the engine pulley
so let me know the deck i.e. 36", 42 ", 46", 48"
different belt sizes also
kendo
Jun 14, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
46 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
