Question about Dryers
Manually turned drum and heard pop. Now dryer will not turn on at all. Breaker did not trip. I assume if the belt was broken the dryer would at least turn on.
  • 417 Answers
SOURCE: hotpoint dryer tdl32
You may be able to check the belt by turning the machine over onto its side so you have access from underneath, if this does not work you will have to remove the back panel of the machine. This is usually done by removing a number of screws which fix the back to the frame of the drier then when have removed the back you should be able to access the belt. remember to disconnect the drier from the electricity supply before you start to do either of these.
Posted on Oct 09, 2008
  • 147 Answers
SOURCE: Kenmore Dryer: Drum will rotate, but only manually
Your dryer has a belt tension pulley. Take the bottom of the back off and you will see it.
Posted on Oct 22, 2008
SOURCE: GE dryer does not run and just hums
Yes, open it. You'll probably find a broken or loose belt.
More help?, let me know.
Posted on May 09, 2009
  • 47 Answers
SOURCE: drum will not turn
YOUR BELT ON YOUR DRYER IS BROKEN. THAT IS WHY YOUR DRUM WON'T SPIN. YOU CAN BUY A NEW BELT FOR YOUR DRYER AT ANY PLACE THAT SELLS APPLIANCES.
RODNEY
Posted on May 16, 2009
Maytag317
  • 1136 Answers
SOURCE: maytag dryer won't turn on
Hi, The first thing to check is the thermal safety located in the back. UNPLUG the dryer. emove the rear panel and locate the fuse on the blower housing middle left. It is white and in 1/4" wide and 3" long with twowire going to it. You can test continuity to it. If it has continuity, it is ok. This is
the most common problem. If II can assist you further, please let me know.
Thanks
Vic
Posted on May 17, 2009
My drum stopped turning. Heating element is fine. Timer is fine. Push start button is fine. I can spin the drum freely and manually. Possibly heard a large pop. Any suggestions?
If you heard a loud pop, then I would definitely say that you have a broken belt. As far as the blower not working as well, if you are having drying times that are taking longer, then you should check your vent line for blockages or build up of lint. Hope this helps!
Jun 27, 2015 | Dryers
I have a GEW9250P ele dryer that the lights come on but it doesn't work.
-You heard the motor turn but the drum no turn>>> Broken belt or slip off.
-It turn but no hot. Possibly the breaker is pop 1 leg. or control switch is dirty, burn contact.
Good luck
Mai Lor
Oct 30, 2014 | Whirlpool GEW9250P Electric Dryer
My white knight tumble dryer wont start
Nothing works or drum fails to turn (tumble dryers)
Ensure that the power supply to the dryer is switched on, the timer is set to the desired drying time and the door is correctly closed. If you have a condenser model, also check that the bottle is empty and is fully pushed into the machine.
http://www.whiteknightrange.co.uk/whiteknight/faq.html
The first thing to establish when troubleshooting the clothes dryer is whether the dryer will start or not. If it won't, start by checking the outlet and the circuit breaker. Is the dryer plugged in or has it tripped the circuit breaker? If the breaker has been tripped, flip it back on and try the dryer again. The drum should turn without a problem.
If both plug and breaker are fine, you'll need to inspect the door switch as you continue to troubleshoot the tumble dryer. When you close the door on the dryer, a plastic peg should click and operate the switch which allows the dryer to work. The peg might be bent or broken, in which case it won't connect with the switch. You can try to straighten the peg, but if it's broken, you'll need to replace it. If the peg is fine, the switch has probably failed and will need to be replaced.
http://www.doityourself.com/stry/troubleshooting-a-clothes-dryer-drum-doesnt-tumble#b#ixzz3FOOQgtAT
Oct 06, 2014 | White Knight Press Genuine Tumble Dryer...
Kenmore dryer model 110.63112100 drum does not turn
Check both of your circuit breakers if the dryer is electric. Though the heating elements are 240v, the motor and electrics are 120v and connect to only 1 side of the plug. The breaker for that side may have tripped.
When you press the start button on the dryer, are you able to hear a motor turning (humming) faintly? If you can, and the drum doesn't turn, this is an indication that the belt has broken, jumped off its track, or the tensioner / idler pulley is either broke or skipped over the belt.
Jul 01, 2010 | Kenmore Dryers
Dryer drum will not spin. motor hums when button
either the belt is broken that turns the motor or thr idler tension pulley is bad, if it were a motor problem the breaker most likely will trip
Nov 01, 2009 | Dryers
Belt broken, drum wont turn manually
if your drum will not turn manually, then the motor is seized up, or a sock is caught in the blower wheel...
Sep 15, 2009 | Dryers
Dryer started up as normal, but, midway through cycle, it stopped running. Timer was still going, but dryer is not spinning.
Can you hear the motor turning? If yes, it probably has a broken belt that drives the drum. If no, check the house electrical power panel to reset the dryer breaker(maybe, only one of the breaker pair tripped). If breaker trips again, you have an electrical short in the dryer cabinet somewhere, usually in the heating element in back of the drum. Good luck!
Jul 09, 2009 | Dryers
May 09, 2009 | GE Profile DPSB619ED Electric Dryer
Dryers Logo
22 people viewed this question
Top Dryers Experts
