Question about Xantrex Technology Xantrex Prosine 2.0 Hardwire & Gfci True Sine Inverter Charg - Inverters
Is there a schematic diagram available for Prosine 2.0 inverter/charger?
3 Suggested Answers
  • 5 Answers
SOURCE: my prosine 2.5 charger inverter intermittent
First try blowing it out the unit with compressed air to see if there is large amounts of accumulated dirt inside, look for black soot on the center of the air outlet side.
Intermittent problems are the hardest to troubleshoot.
If you need more help contact me at sunyout@gmail.com
Thanks.
Posted on Jan 12, 2010
SOURCE: Xantrex Prosine 1800i "DCDC Shutdown" when connecting AC Load
Hi
Did you find a fault or get it repaired as I have a very similar fault with a Statpower (Xantrex) Prosine 24v 1800i 230v inverter the only difference is that mine faults out with no load on it
Thanks
Posted on Aug 24, 2011
My Prosine 2.0 display panel displays Panel Fault: Memory error and the display error as well as all lleds are off. The unit looks as if it has no power to it. I reset (power off.power on) the prosine and...
This is a know and widespread problem with the Prosine 2.0, yet when you call Xantrex, they want to charge you to return, repair and/or replace the remote panel. Shame on you Xantrex.
Sep 06, 2010 | Xantrex Technology 806-1800 Prosine...
Where can I buy or get a Prosine 2.0 remote repaired ?
Nowhere (if not under warranty for replacement). They are a known problem. Prosine inverters are almost impossible to repair (Even one of their local authorized repair shops said even they could not do repairs on the Prosine although it was relatively easy on other models.) Have to order the display from Xantrex directly and they don't have many left. from
Mar 25, 2010 | Xantrex Technology Statpower Prosine 2.0...
Battery shutdown
the batteries needs to be charged properly or the battery is due for replacement
Jan 19, 2010 | Xantrex Technology Statpower Prosine 1000,...
Hi Schnupfy,
Well, it may be advertised as 1800 watts, but that is a peak. While the 230 VAC may be dead on target, don't expect it to run a mig welder.
Sustained high output is totally dependent upon the power source. What it's doing is protecting itself. DCDC Shutdown indicated 'An overload or system Fault'
Possible problems that would cause this:
  • The load is too high (what is the load?)
  • The power source is intermittent or weak
  • The power source is run through a distribution panel or isolator (Voltage drop)
  • The wiring from the 12VDC source is too long for the gauge used
Click here for a PDF copy of the manual. It is quite well documented.
BEST REGARDS,
MIKE
Dec 18, 2009 | Xantrex Technology Xantrex Xantrex Prosine...
My prosine 2.5 charger inverter intermittent
Thanks.
Sep 14, 2009 | Xantrex Technology XANTREX PROSINE 1800...
Cooling fan running constantly.
the cooling fins are clogged, u need to get a small vacum and clean the area
May 09, 2009 | Computers & Internet
Xantrex Technology Xantrex Prosine 2.0 Hardwire & Gfci True Sine Inverter Charg - Inverters Logo
67 people viewed this question
Top Xantrex Technology Electronics - Others Experts
Jimmer_9
Level 1 Expert
richie46
Jay Plesset
Are you a Xantrex Technology Electronics - Other Expert? Answer questions, earn points and help others
