Question about Dishwashers
How to reset kenwood dishwasher kdw60x10
No hot water
2 Suggested Answers
SOURCE: Hi Kenwood dishwasher kdw60x10 -
I have the same problem :( e1 fault and full of water, I have check pressure and drain for blockages too.
Posted on Jun 03, 2011
E4 showing on the panel KDW60X10
The Kenwood KDW60X10 shows the E4 code when there is a water leak or a problem with the float switch (or it's PCB board connection). This could be a leak at the tank, the hose, or that the drain pump's anti-flooding system has been tripped.
Disconnect the dishwasher from power and the water line. Look for signs of a water leak under the unit. If the hose is leaking, you may be able to replace or reseat the drain hose. (Also make sure that there are no kinks in the hose.) Note: sometimes the leak is in the plastic where the drain hose connects to the dishwasher. That is harder to fix.
If the tank is leaking, replace the entire unit. For the other possible problems, you should consult a repair tech to narrow down the issue. Float switches are easy enough to replace; the PCB board and the anti-flooding system are not as easy to reset.
The manual for your dishwasher is available here: http://www.partmaster.co.uk/company/partmaster/manuals/Kenwood%20KDW60X10.pdf .
I hope this helps.
Apr 12, 2012 | Kenwood Dishwashers
I am looking for a user manual for the KDW60X10 dishwasher.
Please click on the link below to download the user manual for the Kenwood KDW60X10
You will need to have Adobe Reader or another PDF file viewer installed on your PC to open the file.
http://get.adobe.com/reader/
Regards,
BElectric
May 25, 2011 | Dishwashers
Hi Kenwood dishwasher kdw60x10 - runs cycle then stops showing error E1 - still full of water.
May 14, 2011 | Dishwashers
What men cod e4 on dishwosher kenwood kdw12st3a
Hi
Error e4 on Kenmore usually occurs when there is drain clogging or due to debris stuck in the bottom of the dishwasher. Drain out the excess water from the dishwasher, now remove the mesh and the filter. Now, check and remove any food material or debris stuck. Now pour 1-2 litres of luke warm water and let this water drain. After this replace the parts and run the dishwasher on eco mode without any tablets or soap. Try this 2-3 times and then reset the dishwasher by unplugging it for 5-10 minutes.
Please post back for any further assistance.
Daniel
Jul 21, 2010 | Kenmore 15762 Dishwasher
How do i reset the dishwasher when light is flshing but not run
Hi
To reset the Dishwasher when the light is flashing press in sequence normal wash, heat dry, normal wash, heat dry, normal wash, heat dry three times within 6 sec all the lights will come on then hit cancel. What that did is reset the control and clear that fault. Keep in mind that D/W does not heat its own water your incoming water temp should be 120. The D/W will maintain that temp. When starting your D/W first turn on your hot water till it gets hot then start your D/W this insures your unit fills with hot water and not cold.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 12, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Bosch SHU3300 dishwasher stuck on hot water intake (w/ no power)
It sounds like the fill vlave is stuck open. This can happen if your pressure is low or if the machine is old. I would start by replacing the vlave.
May 12, 2009 | Bosch 24 in. SHU5305UC Built-in Dishwasher
E1 fault on kenwood dishwasher kdw243a
error code E1 refers to "lack of water inlet pressure" the valve the elctrically lets in the water might be at fault
Jan 18, 2009 | Kenwood KW85 Air Conditioner
Dishwashers Logo
12 people viewed this question
Top Dishwashers Experts
