Question about Arris SURFboard Gateway SBG6580 DOCSIS 3.0 Wireless Cable Modem
Nest keeps losing internet connection
Hooked up a nest thermostat but it keeps losing connection. It does reconnect on its own but is off and on
I am trying to replace my Totaline P374-1000 thermostat with a Nest. The Nest needs 110 or 120 volt, but there is no sticker on the P374. Can you please tell me?
Your Totaline 374 almost certainly is running on 24 Volts transformed from somewhere near your furnace, boiler or a/c unit. You will probably need to find that and run new wiring for your NEST. I suggest you consult with a professional electrician or HVAC tech if you are not experienced in such things. Transformer probably looks like this:
Jun 25, 2018 | Heating & Cooling
How to replace my RV coleman-mach thermostat and upgrade it to a newer wifi thermostat like a NEST or ECOBEE?
I am familiar with a NEST thermo. The color of the wires on the RV should conform to AC standards of which there are none.
Power to the device is a serious consideration. Contact the manufacturers support BEFORE purchasing. Discuss their product in your proposed application.
The residential standard power is 24 vac. If your RV provides this voltage, then installation is straightforward. The NEST may have a solution to this if it is a problem in your application.
With the problems involved, I would have to recommend the PROFESSIONAL installation option mentioned in the NEST directions. If you have the tools, skills and knowledge to resolve any issues then do it! I can vouch for the NEST thermostat's durability. It has been subjected to rough handling, changing homes and power outages.
I love my NEST and it is much smarter than needed but I can check and set it from any internet access. Nest Learning Thermostat 3rd Generation Stainless Steel Works with Amazon...
Oct 11, 2017 | RVs
I want to connect a NEST thermostat with WiFi to my Lennox furnace. The existing iComfort by lennox has 4 wires, R, I+, I-, and C. Where would these connect on the Nest?
They don't. And why would you want to trade it out??? You are currently running off the communicating terminals. If you are going to install a nest you will have to match the nest wiring with the legacy/24volt terminals on the furnace control board and likely the outdoor unit will need rewired as well. Not extremely difficult but why??? The nest is not what it's cracked up to be!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Sep 12, 2017 | Heating & Cooling
How to set my Nest learning Thermostat. I don't have a manual , I'm 85 yrs. old . Haven't been using it because I was afraid I didn;t know how to stop it.
I am a Nest Pro installer. The bast way would be to call Nest at: 855-469-6378 They will be able to walk you through it better than I can on an internet chat board. The will pick up in less that 5 minutes most of the time.
Sep 02, 2017 | Heating & Cooling
How to set Nest Learning thermostat?
I am a Nest Pro installer. The best way would be to call Nest at: 855-469-6378 They will be able to walk you through it better than I can on an internet chat board. They will pick up in less that 5 minutes most of the time.
Was going to change out trane xr402 for a Nest. When I couldn't install the nest because I have a 2 stage furnace I put the xr402 back on but now can't get a display
Nest does have a 2 stage stat, but they are pieces of junk just like the single stage ones. Because you did not turn the power off you blew the internal 5 amp, car style, blade fuse. TURN POWER OFF and remove electric panel of furnace and locate fuse. BTW the single stage nest would still work but you will lose your efficiency rating. Always turn power off when messing with wires.
Jul 23, 2017 | Heating & Cooling
Rookie question:I have a 12yr old Goodman model GMP 050-3 furnace w/ Honeywell thermostat.I want to a Nest digital thermostat but red line doesn't have enough juice to power the Nest. My options?
I'm guessing your blue wire is your common and red is hot. You need a voltage meter. Should have 24 volts with R&B. If not either you blew the 5 or 3 amp fuse when hooking up or your wiring is wrong. If there is an outlet close you can test red to ground and see if you have 24. If you do have 24 blue is either not common or its unhooked or shorting on something. Good Luck!! Fuse would be internal , car style, turn power off and open furnace to inspect.
Apr 03, 2017 | Heating & Cooling
New Nest thermostat, Model 2.8 Software version 4.0.1 keeps getting a low battery and shuts off and shuts down the furnace. Please help.
Do you have a common wire? The nest thermostat needs the common 24V C wire installed to keep the battery charged fully. Nest should tell consumers of this problem, but they don't. Its required for any powered thermostat. Even the new fancy Honeywells with touch screens etc..
Gotta realize the battery cannot run the display and wifi plus all the sensors for very long.
Jan 23, 2014 | Nest Learning Thermostat 2nd generation
Arris SURFboard Gateway SBG6580 DOCSIS 3.0 Wireless Cable Modem Logo
191 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
jimmy Leo
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
