Question about Saws
Need help identifying my band saw
Yesterday I bought a new band saw with the label "Grizzly model: G1015," The problem is that I do not believe that the label is correct. So it has a green plastic cover with a yellow switch plate. 14" clearance. 25" height, 28" length. Designed with a sanding option, woodcutting option and metal cutting option. There is great information on the motor. It is an RJ Toyang, modle TME 202.1, 1/3 HP, 4 poles, 1720 RPM, 60 Hz, 115 V, 7.5 A, Rise 60, Ph 1. Any info would be great!
bigg t
  • 640 Answers
SOURCE: Hobart A200T General Info / Back cover plate gasket
I'm a service tech for hobart,I'll type your serial number into our database and see what it brings up.The changes that have been made---older units use a mechanical start switch on the motor,the new units use an electronic start switch.the old units center shaft and gears have changed.the older units dont have bowl guards and the new units do.(this is a cage that goes around the bowl).The gasket that your talking about is just that--a thin paper.The paper wears and you get that symptom you describe and its normal.I'll get back to you.
Posted on Feb 21, 2008
  • 8197 Answers
SOURCE: Need Manual for Delta Bench Band Saw 28-185
Posted on Jan 11, 2009
  • 10865 Answers
SOURCE: What size a step pulley required for the motor ?
here is the chart you need to answer your question. please mark this as a fixya! thanks
Posted on Mar 12, 2009
  • 5 Answers
sometime you can get lucky on ebay. thats one place you check. the best thing about it that it's nation wide. i found alot of odd items in there.
Posted on Jun 24, 2009
  • 2176 Answers
SOURCE: Motor has started t0 smoke and trips circuit breaker
On the motors I deal with there is a series of numbers that identify the shaft size, hp and all other requirements. I would try and contact a local Grainger and see if they can help, if not try in the yellow pages for a motor repair shop in your area and sometimes they can get you one. Good luck
Posted on Jul 18, 2009
Grizzly g4030 bandsaw vise adjustments
Is that an old saw ? Check your manual or call a tech support.
Jul 03, 2013 | Saws
Grizzly bandsaw repair parts
The only suggestion I have is call the manufacturer of the saw . If you want to read some facts about band saw, visit this blogging site.
Jul 03, 2013 | Saws
Need help identifying my bandsaw
I made a research on google and I found Brico BS360 band saw . However, I am not pretty sure about this since there is no any other information came out. Photo of the band saw would really help. Just try posting this to different forum site .
Apr 16, 2013 | Saws
I am searching for a 78 inch shopmaster band saw blade?
You might be able to make an 80" blade work if you have enough adjustment. Here are some 80" blades from Grizzly.
Good luck
Jun 01, 2012 | Saws
I need a manual for my floor model band saw
I have this same saw. Many of the parts are compatible with the Grizzly G1012 18" band saw. The manual can be downloaded from the Grizzly site. If you need a part not listed, call them. They are very helpful. I have a few parts arriving in a couple days. Try this link,
Jan 09, 2012 | Saws
Mt 18 inch horizontal band saw is not cutting square
Thicker metal shows greater blade / saw adjustment errors. A simple 1/64 or 1/32 wont show much on an 1/8 thick piece of metal when cut.
Those numbers will double quickly as the cutting blade travels through thick metal.
Metal band saws seem to be trickier to adjust and fine tune because the blade seems to be twisted into the roller guides.
The downloaded manual for the saw that looked most like mine at helped my adjustments a lot.
The saw quality is also a factor.
Dec 18, 2010 | Saws
Wood like to clean & update my rockwell model 14 band saw need a download of this saw
try there web sight, if I'm not mistaken, Delta bought out rockwell and they should be able to help. I had an old rockwell table saw and the man shaft that the blade attached to was missing.I contacted delta with the model number of the saw and they faxed me a blue print of the shaft and we machined a new one and the saw still works great.
Jan 18, 2009 | Delta 28-060 14'' Band Saw Blade 93-1/2''...
Saws Logo
55 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
