Question about LG Refrigerators
Lg premium ez digital
Ice maker does not work because lever in the ice boy stays up, signalling the ice box is full, while the ice box is actually empty. As a result no new ice is made.
HVACRH20
  • 237 Answers
SOURCE: Ice maker won't stop making ice
OK, there's two possible issues but you have to figure out what is happening. Does the ice maker continue to make ice forever and would fill up the whole freezer section in time OR does the ice maker just "over make" ice that overfills the bin which then falls out? If the ice maker just keeps making ice you need the motor module replaced but if it can be turned off by moving the lever up then you need the "modified lever assy." that is on our service bulletins.
Posted on Dec 26, 2006
  • 183 Answers
SOURCE: IC6 ice maker
No, completly deforst the freezer for 24hrs this will resolve the problem, i know its frost free, but still try to defrost this usaully resolves this fault Regards Advisor
Posted on Aug 21, 2007
woodchuck789
  • 4059 Answers
SOURCE: tHE ICE MAKER IS NOT WORKING
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Posted on Jul 01, 2009
SOURCE: lg refrigerator LFX25960SW
do not purchase lg refrigerators or products. they are junk!
Posted on Jul 12, 2009
SOURCE: How do I reattache the DA61-03561 Guide Ice Full lever?
I have the same problem.
You will likely need a new one.
You can verify this as follows.
Remove the Ice catcher (using the lever on the right side).
There is a white Philips new the lower left front of the hollow area.
This screw holds down a long plastic cover.
After the screw is removed the cover can slide 1/2 inch towards the doors, then it can be removed.
Notice the little white hooks on the back that slide onto tabs (for when you replace this).
Reach to the back left of the hollow area - there is a cable that goes to the ice maker.
Free this cable.
On the top of the ice maker there is a little tab.
Press this tab and the ice maker can be slid forward 1/2 inch, then it can be lowered.
On the right side of the ice maker you will see a depression with a square depression in it, with a Philips screw in the center. This is where the Ice Full guide goes. You will likely notice it has broken off.
Posted on Jul 19, 2009
What is the problem that ice maker is not working. Why the ice cube cannot make? Even I changed the water filter.
There are two solenoid valves usually at the bottom of fridge in the back. These valves control the water to ice maker and water dispenser. They are replaced as a set. This is the first place to look. Generally this valve goes bad and solenoid does not open when ice maker signals it to open.
Oct 06, 2016 | Viking VCSF036DSS
Lg freezer ice maker making ice but not dispensing
I have the same problem. I am getting tired of having to clear it out about once a week. I take the ice holder out and empty it in a large bowl and remove any large, melted together pieces, then replace it. It works fine for a while.
Mar 17, 2017 | LG LSC23924ST Refrigeration : Refrigerator...
Lg ice maker not working I have water
Hi, Have you checked if the Ice level lever is down?
Mar 03, 2014 | Neff K3965XO Side by Side Refrigerator
Lg icemaker stuck
You have an overflow of ice building up in the reservoir. Turn off the maker and use the contents until 3/4 are used up. Turn on again and stop when near full. Check to see if the LEVEL of the refrigerator is correct. The BOX may be tilted forward and an adjustment made.
Feb 26, 2014 | Refrigerators
Ice cube dispenser
make sure the ice maker lever is in the down position, when removing the tray the arm was probably moved to the top(off) position as if the tray was actually full which would shut off the ice making process
Aug 30, 2012 | LG LFX25971ST Bottom Freezer French Door...
Lg premium EZ digital. Digital display for fridge temp moves on its own can not control ice and water selections digital panel uncontrolable
Sounds like contamination inside the controller. Unfortunately this usually means replacing the controller.
Apr 20, 2012 | LG Refrigerators
I have LG side-by-side fridge freezer (GRL197NIS) with a Premium ez digital ice maker. When the ice cube or crushed ice is in operation the ice gets backed up inside the dispenser/door as the 'spring...
The answers gave me the confidence to have a look and on mine the arm had come out of the catch the other end from the solenoid.I just had to push it back in. So grateful thank you very much. It's not been working for about 18 months and I couldn't afford to pay someone for something that was just a luxury. A BIG THANK YOU!!
Aug 05, 2011 | LG 25.2 Cu. Ft. Side By Side Refrigerator...
Lg premium ez digital i have a lg premium ez digital fridge freezer the interior light bulb has expired. how do i replace it please.
Unscrew it from the socket. counter clockwise. remove it entirely. screw in new bulb, clockwise
Sep 29, 2010 | Freezers
The lever is stuck on my LG ice dispenser
You'll need to replace the whole ice maker system. Problem exist in the mechanical box connected to the lever which once opened is almost impossible to re-assemble. Cost around $95.00
Aug 06, 2009 | LG LRSC-26922 Side by Side Refrigerator
Ice maker not working
Depending on the ice maker style, they typically work off a motor timer. The timer motor rotates to set up the ice making process... starting with letting water into an empty ice mold tray, allowing ample time for that water to freeze and then to rotate that mold so that the cubes fall out into the bin. In conjunction with that process, a small heater is turned on to release the frozen cubes from the tray. The 'ice tray full' lever signals the system to stop making ice so you may want to verify that the lever is down and not causing the ice maker to stop, If that's down then I suggest you monitor the position of the motor gearset underneath an access cover. With power applied, the gears should rotate and cycle thru an ice making process. If it does and ice fails to fall out, your heater may be defective. Hope that helps...
Jun 22, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
Refrigerators Logo
159 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
