Roland VersaCamm SP 300-V linear encoder setup
My linear encoder went bad so I purchased a new one and had directions set on how to install and reset up the linear encoder. The installation was a success but when do the setup trying to get into Service Mode it's a disaster. I've done just as the directions said "unload media then, turn on the sub power while pressing left arrow, down arrow, and right arrow all at the same time." My printer then tells me, "Printer in protected mode." What does this mean and how can I get it into service mode?? Help! Because I'm still using my printer. It prints like new again but it will shoot up service code errors like it did before installing the new encoder. I need help someone please. You can email me at qualityst@yahoo.com or I will check back soon. Thanks all!
SOURCE: Resetting Epson Stylus Photo RX700 inkjet printer
Unfortunatel;y the SSC utililty doesn't work on the RX700. It does, however, work on every other printer we have tried.
Posted on Nov 12, 2007
Maanita
  • 1142 Answers
SOURCE: PRiNt SP00lER
1. Go to Start > Run and type in services.msc then press Enter. 2. In the window that opens find "Print Spooler" on the right 3. Right-click "Print Spooler" and select "Properties". 4. Click on the "Recovery" tab and change all 3 drop-down boxes to "Restart The Service". 5. Make sure the 2 text boxes underneath say "1" in them. 6. Click Ok until you are back at the Services window, close it and you're good to go. 7. Go back into the properties of the "Print Spooler" tab and be sure to click Start to restart the Print Spooler service and it will restart the service immediately.
Posted on Jan 22, 2008
Mix-it-up
  • 832 Answers
SOURCE: I cant to move my DCP-115 to the maintanance mode
First button is MENU then start b/k copy then 4x arrow-up....
Posted on Mar 01, 2008
  • 64 Answers
SOURCE: Check printer ##331 CANON FAXPHONE B95
HI your problem in fixing unit change it and your problem will be solved
Posted on Nov 08, 2008
  • 56 Answers
SOURCE: I need a printer service manual for a TallyGenicom
you can get 1 from this site:
http://au.tallygenicom.com/support/download.cfm
Posted on Mar 09, 2009
I have a roland sp-540v, trying to print on banner material with black backing. Keeps on getting message to setup sheet while everything is loaded correct. The sensor is probably not picking up black.
Could you try
(1) Temporarily stick a white strip over the sensor where it detects the media or
(2) On the length of the media or
(3) Even staple same sized white media below the black one which you can un-staple after printing.
kindly ignore if these are (s) tupid answers
Mar 23, 2016 | Roland VersaCAMM VP-540i
Carriage are disconected
How to stop BN20 from beeping due to one empty ink cartridge. Need to purchase replacement.
Aug 05, 2014 | Roland VersaCAMM SP-540V
Distorted printingting
hello
try to clean the Encoder strip of your sp540, gently with alchool isoprophilic
i add a video explaining (the procedure and the result is the same for sp540) i hope this is helpfull. good luck
Feb 04, 2014 | Roland VersaCAMM SP-540V
Continuosly getting pinch roll error (invalid right position) on Roland versacamm sp-540v
if the problem is persists you have to replace the data cable connected to the head ( this cable goes foward and backward with the movement of the heads and sometimes it brokes ) i had the same problem and the solution is this.
Jan 31, 2014 | Roland VersaCAMM SP-540V
I need a driver for Roland VersaCAMM SP-540V for windows 7
IF I CAN REMEMBWE YOU CAN DOWNLOAD IT FROM THE ROLAND SITE
Nov 17, 2013 | Roland VersaCAMM SP-540V
I have roland verscamm 540v when i sub switch on
hello m f azam
have u solve the problem already?
Aug 20, 2013 | Roland VersaCAMM SP-540V
I need drivers windowS 7 for Roland VersaCAMM SP-540V
hello
i add a video explaining how to install sp540v in win7
u need to install the Intercon-NetTool (that u can download from the Roland website) to allow the comunication with the plotter. its all well explained in the video. good luck
Feb 27, 2013 | Roland VersaCAMM SP-540V
SETUP SHEET PINCHROLL ERROR INVALID IF RIGHTPOS
i had a similar problem with my sp540 and the solution was the strip (the electrical one, that is connected to the head, broked)
have to be replaced. and everything goes ok .good luck
Jan 15, 2013 | Roland VersaCAMM SP-540V
I want to know how involved is it to change the roland versacamm sp 300 print heads
Checkout the guide to replace the pump at:
http://www.decaldesigns.co.uk/img/Pump_replacement_procedure_sp_e.pdf
It also has the instructions to move Head Carriage
Sep 03, 2009 | Office Equipment & Supplies
I have a Roland Versacamm and as it's printing an image that is supposed to be a rectangle shape 40"x60"...as it prints out the image is not straight it actually looks wavey like a flag? The printer was OK...
this sounds like a scan motor error. clean encoding strip and test. If still wavy remove scan sensor the one that reads the encoder strip, clean with alcohol, replace and test. if still bad replace encoder strip and the eye that reads it.
Aug 02, 2008 | Roland Vs-2000CD Digital Studio...
k24674
jasbo
jasbo
