Question about Sony MHC-GX450 CD Shelf System
Sound went out, can't get it back on
My sony is about two years old and just recently while using the FM the sound went off. CD or radio, no sound. I have tried turning it off and disconnecting the speakers but haven't had any luck.
  • ANNGI05 Mar 10, 2008
    I CAN ONLY HEAR A LITTLE SOMETHING OUT OF THE RADIO WHEN I TURN IT UP TO THE HIGHEST LEVEL, THE SAME IF I APPLY THE HEADPHONES.
    IVE RESETTED THE SYSTEM
    IVE CHECKED FOR ALL MUTED OPTIONS AND THE SPEAKERS WORK FINE ON ANY OTHER SYSTEM.
  • chambal Mar 16, 2008
    sound went off at all outputs and after two weeks it came back again....and now it went off again...You can hear some sound at above 22/max volume level.
This model stereo has problems,to fix it you must unplug it,remove the side panels and you will see a ribbon connector coming from the front panel and going to the side panel circuit board.You must gently unplug this from the side circuit board,use canned air to dust it and the plug itself and replace.You are now good to go!! Hope this works for you,cuz it did for me.
Posted on Jul 11, 2008
SOURCE:
Mitsubishi Outlander radio
Your Radio went bad. Happened to my Honda Radio when it was 6 years old.....
Jul 20, 2014 | Mitsubishi Outlander Cars & Trucks
Sony TA-AV521 I have had this stereo system with surround sound for years. Recently I am finding that the surround sound mode is not working right. There is a lot of fading in and out whether it is on...
CD's and FM radio are created in 2 stereo channels. To listen to them in Surround, artificial processing has to take place in your receiver, so artifacts and fading are quite common when you do this. When you turn the surround off, your stereo is processing the information properly and it will sound right.
Mar 02, 2011 | Audio Players & Recorders
How to wire a sony cdx-gt640ui in a 1999 dodge intrepid...I get sound with the tuner, but no sound with cd, aux, and usb. I'm assuming its only an incorrect wiring setup...
instead of used the blue wire on the Sony head unit to the car wiring harness use the blue/whit wire
  • Blue - powers on only when am/fm is active
  • Blue/White - powers on when when radio is on am/fm/cd/ ect.
Jun 13, 2010 | Sony CDX-GT610Ui CD Player
Sony CD Walkman-(portable Radio -CD player)Very low sound output.
Problem solved by trying another set of headphones.
Thanks anyway.
Gerda
Apr 05, 2009 | Sony (Personal Audio) Walkman AM/FM Stereo...
No sound
If you are getting AM sound, but not FM, its because the headphones you are using are shielded for interference. This shielding is what is causing you not to be able to pickup FM, as the headphone wires are what is used as an FM antenna for the unit. Try using a CHEAPER set of headphones (Yes, I said cheaper). Cheaper headphones usually don't have the shielding. Usually these types of headphones have both wires for the headphones bound together as one wire.
Apr 01, 2009 | Sony Walkman SRF-M37V AM/FM/Weather/TV...
Sony Xplod no radio in 2000 Ranger
if you have lost am and fm it sounds like the antenna connector on the back of the radio has come off, if you find that is the case put it back on and secure it with a strip of tape
Dec 04, 2007 | Sony XPLOD CDX-GT200 CD Player
Surround sound
It must be about the sound quality need of your amplifier. The sound processor simply needs to get clear signals from sources such as fm/am receiver, dvd/cd players etc. in order to manage'em to give you the optimum surround sound. If the fm receiver has an "FM MUTE" option, I recommend that you turn it on. By doing so, you'll receive only good quality fm stations, furthermore your amplifier will let you get surround sound. The second issue you mentioned has its own answer inside. Use a "new" cd player, you can get optical cables, digital coax cables to improve the performance if you like..
Jun 07, 2007 | Onkyo HT-SR800 System
Sony MHC-GX450 CD Shelf System Logo
192 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
