Question about Craftsman 14 In. 5.0 Amp Electric Trimmer Weed Wacker Edger 900-74528 Type 2
Throws out all the line
I load the spool and with the first use, it throws out too much line that tangles around the head
Black & decker LST201 direction loading the string weed eater
when you are holding the spool on which you wind the string wind the string on in a anticlockwise direction
if it uses 2 strings ( one out of each side of the spool
wind in both strings together in the anticlockwise direction
that way , when you put the spool in the head and go to use it , the string is wound the right way to feed out and not get tangled
Sep 10, 2016 | Sewing Machines
How do you remove the spool on an echo srm-2100 trimmer
Most units like yours has a tap head feed spool. To get to the line spool, you need to push the spool inward and rotate it to release it. The line spool is spring loaded, hence the need to push it in and rotate it to get it to release. You return the spool to the trimmer head housing after loading new line on it the same way, in reverse. Hope this info helps.
Sep 17, 2015 | Echo Garden
How do I get my zebco to retrieve the line
Your reel has pickup pins on the spool that will guide the line onto the spool when you reel in.
Try holding gentle tension on the slack line just above your reel and start reeling in. If this does not work then remove the top cover of the reel and look to see if the line is tangled up on the inside around the center shaft underneath the pickup pin cover.
if this is the case, simply unscrew the pickup pin cover from the center shaft. It will be on the tight. Remove the tangled line and reassemble.
Sep 18, 2014 | Zebco 33 Platinum Spincast Reel, 5 Ball...
I have an Echo SRM 225 and the trimmer head just throws the line . After bumping it it will not cut the line with the knife on the guard -it just keeps slapping the guard and the knife until all of the...
You are winding the line in the wrong direction. It should be wound on the spool in the opposite direction of the spin of the head during operation.
Good Luck!
Aug 07, 2011 | Echo Rapid Loader, Trimmer Head
How do put the cutting cord on the spool so that it can be pulled out after wearing down
Hi, Robert I will try to explain the best I can. There are many different ways the manufacturers build the heads and spools for grass trimmers. Remove the spool from the head of your trimmer. Some just pull out, while others have different ways and adapters that screw out, if you have never removed yours look in your owners manual or if you don't have a manual you will have to find the way you remove the spool from the head. When you remove the spool, remember which way it goes.back in. Once the spool is removed if there is still a small amount of line remaining observe the way it is held on the spool. If no line remains look at the bottom of the spool for an eyelet or holes right at the bottom or on the side. If you see an eyelet just tie the line to it. If there is nothing but one hole that means that with the right size of line it will go in tight to hold line. If 2 holes are present insert in one hole and out the other. If you have a 2 line trimmer then 2 holes means in one hole and out the other which makes sense. Whatever is the way to hold the line in, sometimes it just doesn't hold the line on once you start winding line on. There are a few manufacturers I find you can use on all spools and is easy.Take some packing tape or any kind of tape you want to use. Wrap around line then tape to bottom of spool, the easiest way to hold on and works on any make of trimmer. Look at the spool and there is usually an arrow on outside to give you the direction to wind. It is important how you wind line on spool, try to wind neatly like back and forth in even rows so that later the line doesn't get tangled up. But it is also very important not to twist the line. What I mean by that is the way the line comes off the package it comes in. Wind the line the same way it is wound on pack. I hope I am explaining it properly and that you understand what I mean. Put the spool and pack end to end and unroll the line out of the pack the same it is rolled in the package. That is to prevent the line from getting always tangled up and you having to remove the spool to get untangled. I think you probably get what I mean. Do not put too much line on the spool, leave about 1/4" from top of spool. Install the spool the exact same way it came off. I hope I have helped you and that you understand the way I explained it. All the best and good luck. I will gladly answer any other questions.
Feb 06, 2011 | Garden
Spool does not release line when tapped
You do not need to bump the head to advance the line. The machine has automatic line feed. If the line will not advance, then there is a problem with the line spool, possibly a tangle inside on it. Here is your instruction manual.
http://tinyurl.com/2vz3fhb
Sep 27, 2010 | Black & Decker String Trimmer Cordless 12"...
How do you advance the string
These little electric machines have an automatic line feeding system. Do not bump the trimmer head on the ground attempting to make line advance. If the line advance is not functioning like it should, then the string head should be removed and the spool inspected for snags and tangles.
Sep 25, 2010 | Black & Decker String Trimmer Cordless 12"...
How do you cast it? I kept getting tangled...the ...
Put thumb on spool, flick into free spool. look at spot you want to cast too. Cast SMOOTHLY taking thumb off as you get to about 45* to front. *IMPORTANT8 THUMB ON SPOOL THE INSTANT THE TERMINAL END OF LINE HITS WATER!!!!!!!
May 19, 2010 | Pinnacle Solene SLP10 Baitcast Reel
Line gets tangled in gear under feed spool
Problem solved. We noticed something was broken off a small part inside the spool holder. My husband took it to the local hardware store, and one of the employees gave him the part from a trimmer that had been returned.
Apr 06, 2009 | Black & Decker St7000 13'' Automatic Feed...
Craftsman 14 In. 5.0 Amp Electric Trimmer Weed Wacker Edger 900-74528 Type 2 Logo
21 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
