Beko washing machine wmb 81221 ls
Water leaking from detergent drawer
barkencoa
  • 3463 Answers
SOURCE: WATER LEAK
Probably slow to drain due to blockage or restriction, it is going into spin with more water in the drum than there should be.and the water is being thrown out due to centifrugal force.
If it has a filter, then check it and clean if required.
Posted on Nov 18, 2008
  • 108 Answers
SOURCE: Beko 727W washing machine. Washing still wringing wet after wash.
If it is still under warranty, by all means keep calling the company and complaining until they fix it. Trying to fix it yourself will risk invalidating the warranty altogether.
My initial guess is that there is something blocking or slowing down the drain pump, which is preventing spin cycle from working properly, but with a front loader that is only one of quite a few possibilities.
Posted on Mar 24, 2009
venexcsd
  • 1185 Answers
SOURCE: washing machine help
If it fills up while just standing it is the filler valve , they are easy to replace
You need to take the back off the machine and with no power on listen to hear if water is trickling in, if it is then change the valve.
If it fills up while working then you need to do the same as above only this time take off the pipe which runs from a small tube shaped plastic moulding at the bottom of the outer tub to what looks like a small flying saucer which sits near the top
Blow into the tube and you should hear a clicking sound as you blow and release
If you can hear that the switch should be OK and I would then go back down to the Air Bell and make sure it does not have undissolved soap clogging it up inside
Posted on Jun 23, 2009
  • 3 Answers
SOURCE: water remains in detergent drawer
bpkaplan - did you find a solutiion? I have the exact same problem with my LG Tromm WM2477HW front load washing machine. It is about 2 1/2 years old.
Posted on Jan 31, 2010
  • 105 Answers
SOURCE: water leaks around detergent drawer
Best off to call a reputable service company such as Sears.
Posted on Feb 06, 2010
Water leaks out of the washing powder compartment
it might from closing the powder drawer not completely and correctly
or having crack in the drawer
or having the high water pressure in the Water pipeline network
check all above , if not , call service center
thank you
Nov 05, 2014 | Beko Wm & Wma Models Washing Machine Motor...
Why dosen't Beko WMB 61631s washing machine work?
sounds like a software problem.
Try unplugging for 2 hours, then replugging and starting the cycle.
The long unplug is to drain memory voltage.
Aug 19, 2014 | Beko Washing Machines
I have a beko wmb washing machine that stops working as soon as its put on and then the wash and ready lights start flashing... what could be wrong?
Try reading the "troubleshooting" section of the instruction manual. If you don't have the instructions, go to the Beko web site and download them.
Oct 21, 2013 | Beko Washing Machines
How to reset Beko wmb 91242 LC? Machine won't do
My washing machine beko WME7247W won't do anything it said C on it won't start change tem do anything can you help me
Apr 08, 2012 | Washing Machines
Water is leaking out of the detergent drawer. It
i would say the outlet from the bleach area is blocked clean out drawer unit
Apr 12, 2010 | LG WM2277H Front Load Washer
Intello washer leaking water from detergent drawer. model no. WM10402F would like to know if a part needs to be replaced or would anew machine be better. the water only leaks when water comes into the...
Are you sure it is coming from the detergent drawer? It could be from your inlet water valves. They are very easy to see. Two screws on the rear of the machine will let you slide the top back and expose the componets.
Dec 29, 2009 | LG WM-2277HW Front Load Washer
Washing Machines Logo
120 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
