DsTV DSD 1131 is searching for signal for a long time I dont know whats going on
3 Suggested Answers
SOURCE: My decoder - dsd 1131
Don't worry about it. You have mistakenly pressed Shift + exit. What you need to do is to press Shift + i. What you have done is used by the people using two decoder. They use it to switch between the two decoders.
Posted on Dec 30, 2010
RALilja
  • 384 Answers
SOURCE: What can be the problem if my Dstv decoder model DSD 1131 doesn't have signal strengh or signal quality I'm staying in Pretoria how can I fix the problem
The best that I can give you is at this link:
http://hopeafrica.tv/index.php/component/content/article/40-schedules/202-dstv .
It should be noted that Africa does not have digital tv so you should probably hook an antenna to the tv without the box and have the tv search for analog tv stations as that will stand the best chance of picking up what few channels they do have.
Good Luck!
Rich Lilja
Posted on Jun 12, 2015
DSD 1131 does not respond to a new remote control which is exactly the same as the old one. the remote is not faulty because itworks with other decoders
Some remotes , while looking the same on the outside are much different on the inside. Example: Two remotes in a household with 2 decoders in different rooms. To eliminate one from interfering with the other, each remote is matched to its decoder.
Jul 24, 2016 | Televison & Video
Good Luck!
Rich Lilja
Jun 12, 2015 | Televison & Video
My decoder Dstv dsd 3u doesn't response to the remote what should I do cause i need to add volume
If you have extra batteries, try to replace the old one and install the new batteries. And if still doesn't work, try to clean the battery terminals of the remote control, because sometimes, those are the one that making the problem due to corrosion caused by leaked batteries.
Aug 04, 2014 | Televison & Video
How do I setup 2 tv,s on a single view dsd 1131 decoder, 1 tv and decoder upstairs an 1 tv downstairs. The dish is already installed and can rust very easily for the area.
very simple ,, the tv next to the decoder must be conected using a rca cable and then run normal tv cable (RF out ) to the other room
Apr 04, 2013 | Televison & Video
Is it possible to unlock dstv channels by entering the codes?
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Oct 27, 2012 | Cell Phones
Dstv decoder dsd 1131 is just flicking when put on power.cause of problem is that water dropped on mother-board.there was carbon but i brushed it with methylated spirit.but is still flicking and does not...
In most cases if there was water and the set was put on before the traces were removed , it is quite possible that some sensitive component could be damaged.
hence it is important to start from the beginning. Use a hair dryer to warm, use soldering iron to solder suspected joints and if you hear/see steam while the iron is used on the pins then it is for sure that water is lodged in the component base. You will need to do the work with caution till there are no traces. A slight short can result in flickering , if not there are failures in the board.
check this link for some tips;
http://www.fixya.com/support/r6041626-when_device_falls_into_water_when
Apr 12, 2011 | Televison & Video
My decoder - dsd 1131 does not respond to his remote control.Ive checked the batteries..they are ok.
Nov 28, 2010 | Televison & Video
Free to Air on a Dstv
how can i have codes to tune east african channels plis for free. am using dsd 1131 decoder of dstv. am in johannesburg.
Jun 18, 2010 | Televison & Video
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Electro Med Services...
