Konica Minolta Error Codes C-3910 - Office Equipment & Supplies
osiriscompu
  • 16 Answers
SOURCE: konica minolta 2430
Most likely you received this message after a toner was replaced. Reseat the cartridge and restart the printer. If that doesn't work remove all of the toner cartridges manually and reinstall.
Turn off the printer and open the top cover. Follow the toner cartridge all the way to the right side of the printer (on the white part). You should see a hole that looks like a cross. Take a pen or key and push down on the black button in that hole. While you are holding it down rotate the toner cartridge towards you. You want to get the colored roller on the cartridge about 1/2in away from the metal bar that says "consumable reorder". You should be in a position to take out the toner. Let go of the hole and remove the cartridge. Repeat the steps until all of the cartridges have been removed.
Turn the printer back on at this point. You are going to get toner not installed messages on the printer. Open the top cover and the cyan tray will be in place. Shake the toner and install. Close the cover and let it cycle to the next color (black). Repeat the process until all cartridges are installed.
If you are still getting the error you either have a bad cartridge or the carousel that the toners sit in is damaged.
Posted on Jul 19, 2008
jqsababa967
  • 145 Answers
SOURCE: KONICA MINOLTA
CD231 at power up.
Solution:
CAUSE: Complete fax kit was not installed.
SOLUTION: These three items make up the complete fax kit, FK502, MK706 and MK704. If not installed together, the C250/C252 will display code CD231.
hope that helps
Posted on Nov 04, 2008
SOURCE: konica minolta EP2010 error code c05
I have a Konica Minolta CSPRO EP1054 (in the Middle East)
I accidentally plugged the EP1054 copier into a 110V outlet instead of the 220V. Immediately the malfunction code (error code) of "C05" appeared along with the "Call Tec Rep" indicator light (wrench).
I followed the instructions posted by "Soul Visitor" ... i.e., I found the "Trouble Reset Switch" (not shown in the user manual) by opening the upper back panel and pressing the small black button in the lower right hand corner of the middle circuit board (green).
It worked perfectly!7df26b9.tif
Posted on Jan 16, 2009
herminio_hal
  • 210 Answers
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Posted on Jul 09, 2009
SOURCE: Konica Minolta Magicolor 4690MF gives 0502 error.
machine trouble 0092 service call
This happen after I cleaned the waste box for Konica Minolta Magicolor 1600W
Posted on Mar 08, 2010
Konica minolta c280 showing error codes 3423, 3334 and 2451 How can I clear the codes
2451 replace the cyan (Blue ) Image unit
3423 replace the fuser unit
3334 No such code
Jan 09, 2017 | Konica Minolta Bizhub C280 Color Copier /...
I would like a list of error codes for the Konica Minolta bizhub 350
http://www.printcopy.info/?l=en&mod=free&chap=erc&brand=Konica-Minolta&model=bizhub%20C350
Apr 14, 2015 | Konica Minolta bizhub 350 All-In-One Laser...
Konica minolta c 452 error code c 2161 & 2164
Hi
The descriptions for the two error codes you mention can be found at the two links below:
Error Codes Konica Minolta bizhub C452 Code C2164
Error Codes Konica Minolta bizhub C452 Code C2161
They would appear to be related to the same problem. For further information I think you would be best going to this page: Konica Minolta bizhub C452 Manual where there are many different manuals for this machine, which can be downloaded by clicking on the one you require and then following the instructions.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 20, 2014 | Konica Minolta Office Equipment & Supplies
Konica minolta bizhub 163 error 0045, what I do to work
from what I've read here:
Error Codes Konica Minolta bizhub 163
, this is a Fusing Cooling Fan Motor malfunction, which suggests, I'm afraid, that you have to have it serviced.
Kind regards,
Jon Erik
Nov 14, 2014 | Konica Minolta bizhub Office Equipment &...
Konica minolta bizhub c253
what is the question?
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Aug 21, 2014 | Konica Minolta Minolta Bizhub C253 Copier
Trouble shoot konica minolta error code 0500
need to know model number
most konica minolta 0500 codes is fuser related and a tech has to reset it
Aug 22, 2013 | Konica Minolta bizhub Office Equipment &...
Konica minolta bizhub c350 error codes c-0510
eror code c-0098 meaning ??????????????pls tell me the solution
Jul 31, 2012 | Konica Minolta Bizhub C350 Digital Copier,...
229 people viewed this question
jasbo
jasbo
