Question about Vehicle Parts & Accessories
Search Fixya...dei 467 how to program the remote to open the garage door
Dei 467 how to program the remote to open the garage door
  • 18 Answers
SOURCE: remote garage door opener
1-800-355-3515
www.homelink.com
1. Position vehicle within 10 feet of garage door- engine off and battery on.
2. Press/hold 2 outside buttons of Homelink transceiver until red indicator starts flashing rapidly, then release button. This should take about 20 seconds. This erases any previously learned codes.
3. Press/hold remote control and press/hold button of Homelink transceiver simultaneously. Slowly move remote control from 5" away to 1" away from Homelink transceiver. Release both buttons after red indicator starts blinking rapidly. This should take about 5 seconds. I discovered that the Homelink in my TL is a bit faulty because it took much longer to accomplish this than when programming the Homelink in my MDX. My TL's Homelink may "unlearn" it's code in the future and the needed proximity of the TL to the garage door may be much closer than desired until I get the Homelink fixed.
4. Press training button on garage door opener unit until the indicator lights illuminates- this should be immediate.
5. Within 30 seconds press/hold the Homelink button for 2-3 seconds until the red indicator starts flashing rapidly. Repeat a second time. It should now be programmed. Check it by pressing the programmed button on the Homelink receiver.
6. When programming more than 1 garage door opener unit, disconnect power from unit before programming more units. By not doing this the programmed unit could conflict with the unprogrammed units commands.
Problems:
1. The Battery in the garage door remote may be too weak to program Homelink. However, the battery may be strong enough to operate the garage door. One of my remote controls had a weak battery- my system was installed today, fresh out of the box. I had to use the second remote control for the programming of Homelink on my 2 vehicles.
2. Antenna on the garage door opener unit must be hanging down, fully extended.
Posted on Dec 08, 2008
SOURCE: i have a pmx300IC genie
palm treo 700w off no open
Posted on Jan 19, 2009
glenmann62
  • 91 Answers
SOURCE: programing garage door opener remote
ok crystal,calm down this is an easy one! first locate the smart button on your openers , next you will press and hold down the smart button until you see an indicator light above it shut off, while your holding that button the light will be solid ,Now your ready to program your remotes ,first programm one side by taking each of your four remotes and pressing the smart button on machine then pressing the button on the remote you want to program,by doing that you will notice the lightbulbs on your machine shut off and go back on , This is an indicator that your machine has accepted the code , now do it with the other three remotes , after you,ve programmed all four ,go over to the other machine and repeat the process but this time you have to choose another button on your remotes since you,ve programmed all four remotes to the same button on each remote ,just choose the bottom button on your remotes this time to keep them seperated , hope this helps you and it is as easy as 1-2-3 your owners manual will describe exactly the same ,i know because i,ve installed over 27,000 machines working as an installer for sears, please leave a nice feedback rating if i was able to help you, good luck,Sincerely Glenn Mayer
Posted on Apr 01, 2009
  • 150 Answers
SOURCE: In following the Chevrolet Tahoe instruction to program a garage door opener, I am having problems with the system working. The codes are the rolling key type.
Press the outer 2 buttons untill the bink rate changes then release.
Press the button you want to train at the same time you hold down an unused button on one of your factory GDO remotes, hold untill flash rate changes.
Press learn button on GDO, press the button you just programmed in the Tahoe, should be programmed.
(Info should be in users manual under HomeLink.)
Posted on Aug 07, 2009
  • 3 Answers
SOURCE: remote missing on old dominator garage door opener
This is the most complicated way I know of coding a remote and I am a tech. who does this all the time.
Turn power off. Wait 3 sec's & turn back on. Quickly press program button on back of box twice. Lights will flash, bottom light will stay on. Press program button twice, & No. 3 light will start flashing. Press and hold your remote button until light stops flashing. Code will be accepted.
Posted on Feb 08, 2010
Transmitter quit working for my 3018,I put in new battery??? still lights red led on it but, not open the door...?
Ken, you may have to reprogram transmitter after battery change, check your manual, if you do not have manual, Google search your make and model# manual.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Garage Door Help How to Program Your Garage Door Remote Control
How To Program Your Garage Door Opener
How to program Garage Door Remote change battery LiftMaster Chamberlain
Programming Garage Door Remote DoItYourself com
May 21, 2016 | Building Materials
About a remote for a garage door opener, how to program it.Bought a new remote and programmed it and now the old one don't work. How do you reprogram the old one?
The same way you programed the second one.
DO NOT hold the learn button down, just press it once and release it. Then press the button on the garage door remote and it will program to the garage door opener. Do the same for anything else you want to program to the garage door opener. When you hold the learn button down it erases all of the learned codes and you have to start over.
Feb 19, 2015 | Building Materials
Garage door opener Chamberlain - programming problems
I bought a new keypad and 2 VISOR remote (30498). As to programming garage door opener, I did like here:
- it tooks me 20 minutes and works great
Feb 07, 2013 | Sears Craftsman LiftMaster Chamberlain...
I have a garage door opener model 41A4314-7C, just picked it up used. I wanted to use it with my existing two purple-button remotes. . I see from a quick Google search that this one has an issue with...
The number you give is a part number. The model number is on the opposite end of the opener and starts with 139. With the correct model number we may be able to help. Also the model number of your remotes would help.
Oct 17, 2010 | Sears Craftsman LiftMaster Chamberlain...
Cannot re-program remote transmitters for garage door opener
If both remotes quit at or about the same time then it is most likely the receiver that has quit. Especially if you have had electrical storms in the area. The receiver is part of your logic board.
Sep 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Reset garage door code
Hi, The opener, remotes and keypads have a set of dip switches that you can use to change the code. You will find the switches when you open the remotes and keypad and are in the back cover ( depending on the model) of the opener itself. Make sure that the codes of all the switches are set exactly the same. If you need additional help let me know! Good Luck.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Mar 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
Having trouble setting garage door opener to my 2004 trailblazer
Problems:
source:chalkstar100 (fixya mate)
Thanks for using Fixya
Have a nice day!
Mar 07, 2009 | 2004 Chevrolet TrailBlazer
Remotes won't open garage door, keypad will
If you look were the small wires attach to the opener there should be a red program button and instructions on how to program remotes.
Feb 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Need to change my remote code after divorce
Follow this link for the manual and look on page for programming.
http://www.google.com/search?hl=en&client=firefox-a&rls=org.mozilla%3Aen-US%3Aofficial&hs=oMg&q=liftmaster+garage+door+openers+manual&btnG=Search
Dec 16, 2008 | Sears Craftsman LiftMaster Chamberlain...
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
