Question about kitchenaid.com
Dishwasher mod kuds301x558
What with the silverware basket. The divider for the silverware fall out or drop down. It is a mess. What is the solution?
A magnet the size of a quarter was in my dishwasher stuck to my silverware. This is 1 week old and I don't know where it goes.
I would save it and if everything works properly not even give it a second thought .sometimes in manufacturing they lose parts and can not find them .
Dec 16, 2015 | Whirlpool 24 in. DU1100XTP Built-in...
Replacement silverware tray
Best Dishwasher Replacement Baskets - Amazon.com
www.amazon.com/...Replacement-Baskets/.../2232353...
Amazon.com, Inc.2. GE WD28X265 Dishwasher Silverware Basket · 4.6 out of 5 ... Whirlpool 6-918873Silverware Basket · 4.7 out of 5 ... 4. Whirlpool 8531233 Silverware Basket.
Nov 24, 2015 | KitchenAid Architect? II S SERIES KUDS03FT...
Is there a replacement Silverware basket replacement for Frigidaire dishwasher model PLD4460REC2
Hey friend, thanks for your post!
I see you are looking for the silverware basket on your Frigidaire dishwasher, PLD4460REC2. The part number you need is 5304454326 I see that part is no longer available from the manufacturer. You may want to look online for the part to see if it available. Hope this information is helpful. -Matt
Sep 25, 2014 | Frigidaire Dishwashers
Spots on dishes, especially silverware
Rinse additives help with the spotting, a lime descaler will help, put it in and run a cycle empty.
There are also several different types of cleaners available for sale at your grocery store.
Check your baskets for rusting, there isn't another reason for that unless your pipes are causing it.
I’m happy to assist further over the phone at https://www.6ya.com/expert/gregg_78ecbb34e27be215
Jun 14, 2010 | KitchenAid 24 in. KUDP02CRBS Stainless...
Require replacement of cultery holder for dishlex G450 dishwasher Located Northern Beaches, Sydney.
Part number 5303282018 runs about $20 in the U.S.
http://www.bizrate.com/dish-washers/frigidaire-dishwasher-silverware-basket/
Sep 27, 2009 | Frigidaire 24 in. FDB126RB Built-in...
Soap door will not open
Chaney,
Make sure there is nothing in the way of the soap door when you close the dishwasher.
Close the dishwasher door slowly and look down in side with a flashlight, are any of the rack brackets or silverware basket directly in front of the dispenser door.
Take a look and let me know.
Regards.
Jul 21, 2009 | Frigidaire Dishwashers
The dishes don't get clean
Dishes not cleaned properly....
  1. Check the water temperature. Should be 125 to 140 F.
  2. Check pump re-circulation., Listen, see if it sounds like it is spraying the water around with enough pressure.
  3. Check water level when the fill cycle has completed. Should be just under the heating element. If not, possibly need to replace the water inlet valve.
  4. Check the spray arm and pump cover for splits or leaks.
  5. Check to make sure dishwasher is draining after each cycle. There should only be a little water in the bottom of the tub.
  6. Make sure the dishes are loaded properly, or dishwasher is not overloaded.
  7. Possibly try a different detergent. Some liquid-gels will bubble and a pump cannot pump bubbles.
Mar 31, 2009 | Whirlpool GU2400XTPS Built-in Dishwasher
Silverware caddy
goto partsdirect.com and use the dwb number to find the baskets..
Mar 13, 2009 | Dishwashers
I have a whirlpool dishwasher. It has a silverware basket that is too small to completely clean the utensils. I wondered if it could be replaced by a bigger basket. I am not entirely satisfied with...
no bigger basket availble, thorough whirlpool any way. a few thingfd to try to improve cleaning:
1. make sure air dry/ economy setting is NOT selected
2. run your hot water in sink proir to starting d/w
3. use a quality powder dertergent ( powder breaks down better in hot water. liqiuid in cold0
4 using a rinsing agent such as rise aid will also aid in overall performance
Apr 03, 2008 | Dishwashers
Melting dishwasher basket
I need to know what make and model to tell you if anything can be done.
Feb 11, 2008 | Dishwashers
kitchenaid.com Logo
37 people viewed this question
Top kitchenaid.com Computers & Internet Experts
David Payne
David Payne
Are you a kitchenaid.com Computer and Internet Expert? Answer questions, earn points and help others
