Question about Dishwashers
Kenmore dishwasher model 665.16379301
No power indication, buttons do not respond
4 Suggested Answers
SOURCE: Kenmore Elite dishwasher model 665 touchpad buttons falling off
WE HAVE THE SAME PROBLEM. DID YOU FIND A FIX FOR YOURS?
Posted on Mar 27, 2010
SOURCE: On my Kenmore Ultra Wash Dishwasher model 665 the
http://appliancejunk.com/forums/index.php?topic=2933.0
Hi. please find above your service and repair manual, below is a self help how to repair your dishwasher website, between the manual and the self help site, you should be able to isolate and repair your issue. You may have a blocked pump, or a faulty sensor, but there is no way of knowing until one performs the troubleshooting steps to isolate the problem.
http://www.acmehowto.com/howto/appliance/dishwasher/dishwasher.php
Sometimes this fix works below, it's always worth a try?
Ok so your dishwasher won't do anything... it justs sits there and "Hums" you can't make it respond to any controls, and the ONLY way to Stop it. is to unplug the unit, replugging back in it simply "Hums" again and will do nothing.
Now this happens because, the STOP Button, is pressed and the "Door Opened", during the Wash Cycle. This should NOT be done. You shouldNEVER TURN IT OFF MID-CYCLE. you should instead, Simply, pull on the handle, to Open the door, the system will take care of everything, after, you close it,and pick up where it left off. The turning OFF, makes the machine "Think" that a New Cycle, is going to be done, before the old one is finished, and resets itself to do it all again. But it still has water, that's not meant to be there so it must dump it out.
Now, the FIX. Take the Dishwasher, out, and tip over on it's side, tip to about a 45' angle. Water will come out from underneath, this is from a small "Overflow" reservoir. this reservoir has an "Anti-Flood" switch. The removing of this water will "Reset" this Switch, and allow the dishwasher to work again.
So what happens, is this, when the STOP button is pressed Mid-Cycle, the machine must "Dump" whatever water is still in the machine, into the "Overflow Reservoir". This water then causes the Anti-flood switch to jam, and this stops the machine, until it is reset,by the above method.
Posted on Jul 20, 2010
GodBlessU
  • 3513 Answers
SOURCE: My Maytag Dishwasher model #: MDB7100AWB Serial
Thank you for contacting Fixya.com.
It does sound like the panel (keypad), Item 1 in the "Control panel" section is going.
The tech sheet shows how to check it with a meter.
Could also be that one of the door switches is just making and pushing on the panel shuts the door enough to activate the switch?
Here are your parts
Replacement parts for MAYTAG MDB5600AWB ' AppliancePartsPros.com
Here is a tech sheet and a manual
http://www.servicematters.com/maytag...s/16023063.pdf
http://www.servicematters.com/maytag...s/16021814.pdf
Please get back to us if you have any further query.
Posted on Dec 13, 2010
The smart wash light on my kenmore elite model 66513753K602 is flashing. I have tried the suggested button sequences to reset it and they have not worked. How do I troubleshoot it to determine which...
From the tech sheet:
CHECKING KEYPAD
OPERATION
A rapidly blinking LED over
one of the keys of the keypad
(or sometimes a "dead"
keypad/console) indicates one
or more key switch lines are
stuck or shorted on either the
control or the keypad. To
determine if the control or
keypad is faulty, do the
following test:
1. Unplug dishwasher or disconnect
power.
2. Open the dishwasher door.
3. Open console and disconnect the
keypad ribbon connection from
the control (at P1). Make sure all
other connections are made.
4. Put console back together. Do not
close the dishwasher door.
5. Plug in dishwasher or reconnect
power.
6. Wait 5 seconds.
7. Close dishwasher door.
8. Monitor the control's response:
? If the control is OK (no longer
sees shorts with the keypad
unplugged), it will respond by
turning on a Drain Motor for
2 minutes. Check and/or
replace the keypad if the
control responds OK.
? If the control is not OK (still
unplugged), then the drain
motor will NOT respond and
will remain off. If no response,
replace the control.
Jan 21, 2015 | Kenmore Dishwashers
Kenmore Dishwasher Model 665.16719000 pushpad buttons lights flashing and won't work.
Press "high temp wash, heated dry, High temp wash, heated dry, high temp wash, heated dry, high temp wash, heated dry, high temp wash"
All the lights will go solid at which point you press cancel to reset the board.
**NOTE** if you don't have a "heated dry" button, use the "air dry" or "energy saver dry" button instead.
Apr 03, 2014 | Kenmore Dishwashers
Kenmore dishwasher panel isnt responding
>> Unplug dishwasher power cable from wall mount also from dishwasher (if applicable).
>> After 10 minutes - plug the power cable from dishwasher to wall mount
>> Turn on the dishwasher
>> Try to operate the panel.
Mar 29, 2014 | Kenmore Dishwashers
Reset for dishwasher
What model Kenmore dishwasher?
Jul 10, 2013 | Kenmore Dishwashers
Kenmore Dishwasher locked up
Sounds like the washer CPU is defective, have it diagnosed by a local repair technician.
Jul 28, 2017 | Dishwashers
How do i reset the board on my kenmore dishwasher
Remove power and keep aside for some time, then when the power is switched on then hold down the start/stop button. If the control panel does not respond it is possible that the controller processor is faulty.
Nov 29, 2011 | Kenmore Dishwashers
Kenmore 16359 dishwasher
The blinking buttons indicate the buttons are bad. The console will have to be replaced.
May 30, 2008 | Kenmore 24 in. 16352 / 16354 / 16359...
Buttons don't respond
I have same model, same problem. The appliance repair person came today and said it was caused by a bad touch panel, which is one of the most expensive parts on the dishwasher - around $200 (plus the service call and labor = $340) and must be special ordered and will take about 2 weeks. Sorry. He said that this is a frequent problem on Kenmore dishwashers.
Dec 06, 2006 | Kenmore 16639 Built-in Dishwasher
Dishwashers Logo
23 people viewed this question
Top Dishwashers Experts
Owen Barnes
