If it's a horizontal line across the face of the picture tube, your TV has a problem with its vertical output. Most likely, it's bad solder connections to the vertical output IC. Because this part gets very hot during normal operation, the connections to the circuit board can crack and the part quits working. All you see then is that narrow line across the tube. A few minutes with a soldering iron to repair the connections is usually all that's needed to fix the TV. It's also possible the part has truly failed, but the bad connections a much more common. A service shop could do the repair if you don't know anyone with the soldering skills.
